Tire Changing and Arthritis
Bikes: Klein
The tire jack is used to install the last few inches of the second bead on the rim. It is very useful when istalling new tires, but, to my knowlege, it cannot be used to remove a tire.,
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
That is correct, removing the tire has not been a problem.
The tire Jack has arrived and is amazingly effective but is to large to fit in a saddle bag. My first thought was OMG where has this thing been all my life. I may carry it anyway it works so well.
I have been racing and riding seriously since the 70's. My daughter is passionate about road, cross and velodrome racing. I have changed more tires than I can begin to count and can't believe I never saw this before. It would not help with sewups but nothing can really make that easy.
Tire Jack is great. What is REALLY needed now for us arthritic folks is a way to break the bead and remove tubeless tires. Any thing available? Tips? Tricks?
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
https://www.amazon.com/VAR-Nylon-Tir.../dp/B004YJ30M8
I have one of each. The Kool Stop lives in the shop; the VAR rides with me.
Liked 927 Times
VAR makes a portable bead jack/tire lever. It doesn't have as good leverage as the Kool Stop tool, but fits in a saddle bag or jersey pocket.
Pre-stretching tubulars is the best way to make mounting easier.
Cheers
Lubricate the tire/tube/rim. Soapy water is better than nothing but is not the easiest to work with. Or the best. Use talcum powder. Pour it right into the tire, all the way around. Remember there is already talc inside the tube and this is only good for the rubber. Talc makes it seem like the tire just got half an inch bigger. Some have forgotten it, there was a period when many pro teams only gave tubulars to the captain. All team mechanics kept the talc nearby.
Start with tires and rims that are easy. In general wider tires are easier. In general wider rims are easier. Some combinations are just too much trouble. Don't use it if it's just crazy hard. In this house right now every clincher installs easy with no tools and my wife can do it too. She does have arthritis and is not a gorilla. For removal she can do most of them no tools. I can remove any of them no tools. There are emphatically combinations that would take me time and cursing to mount and those combinations are not present.
So I bought all three. Of the three recommended the Kool Stop Tire Bead Jack by far the easiest to use but the TyreKey Tire Lever Tool also works well and fits in my saddle bag.
I will post pictures of them together after I get past 10 posts.
These are the three tools side by side. The koolstop on the left is the easiest to use. The Var on the right I found to be the most difficult.
The Tyrekey in the middle now
lives in my saddle bag.
This is a video of each tool being used.
https://photos.app.goo.gl/wdxoBLUkQ7TapRbn7
https://photos.app.goo.gl/PCg6keEAK4wLqs7z7
https://photos.app.goo.gl/hG48q1yYtxkanWRw9
Likes For Babbitt:
Quoted: 569 Post(s)
Liked 581 Times
Babbitt, outside hand arthritis flare ups I have little trouble once a tire has miles on it, now that I focus on thin rim tape (kapton tape) and deep rim channels. I am only using the Koolstops in bike bags of bikes with newish tires and have cut the handle down to fit my bags (still work fine) except the one in my tool chest at home.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Now for some conflicting advice...
The first time i tried a foldable tire, it was dann near impossible to get on the rim. It was a Continental Gatorskin, 700x28. My hands were worn out from the extended exertion, so I resorted to a tire Jack, also for the first time, as I've never needed one for wire bead tires. I didn't get the tire on with the Jack, but did bend the lip of the rim trying.
I don't intend to use a foldable tire again once this one wears out, and if I resort to a tire jack, will be wary of using too much force. Your results may vary...
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 927 Times
So the tire jack gets a hard to mount tire onto the rim but is no good for getting the ire off again. No thanks as I don't want to be stuck miles out in the country with a flat tire I can't get off the rim. For me, if a tire is that hard to mount I'll use a different tire. Being able to repair a flat at the side of the road is a need I want in a tire/wheel combination.
YMMV
Cheers
YMMV
Cheers
Quoted: 887 Post(s)
Liked 335 Times
I am approaching 71 years now, and tire installation is not as easy as it used to be (arthritis). IMO kevlar bead tires are the most difficult to mount unless you use a jack. I only use wire bead tires now.
My riding does not require high performance tires, but I still enjoy the rides that are left in my legs.
Enock
I made a video of this tool if anyone is curious to see how it works!
https://www.youtube.com/watch?v=wvA81TqO-CE
Bikeman, I like all your suggestions.
I want everybody to stop struggling with crappy "tire levers". I am lucky enough to have this Park tool which they quit making. It will get any tire - no matter how stubborn - off the rim.
but by all means get the Park tire levers - or the VAR tool - along with the black bead jack described above.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Likes For enock111:
