Weinmann 610 brakes - pads suggestions please?
Hi
My daily bike - a 60s Claude Butler had worn out its brake pads, I had my LBS change them whilst it had a full service last week, I got it back and the braking is pretty slack – on hills it brings me to a gradual slow rather than a sharp stop and it's even worse in the wet - just slowing me down on hills. I took it back and after the mechanic had a good go at adjusting them he conceded the brake blocks they stock were probably the wrong compound for the old steel rims.
The brakes are Weinmann 610 centre pulls - i'm wondering if any kool stops or similar could be fitted to improve the braking?
Any suggestions?
Thanks
Mark
Any suggestions?
Thanks
Mark
The Kool Stop Salmon are not bad, but the original Matthauser formula is being produced now by Yokozuna for Scott-Matthauser. I just changed a few of my bikes last year and am glad I did. I like the solid feel of the old Matthauser blocks and they work better in the wet.
https://www.rivbike.com/product-p/bps1.htm
Marc
Marc
Quoted: 17 Post(s)
Liked 42 Times
I have used the Kool Stop Campy pads available from Harris in my original Weinmann holders.
IIRC, I had to pinch them closed just a bit to snug them. (Of course I took care to orient them in the proper direction - the old W. Shoes are open at one end.)
- Auchen
- Auchen
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Hi
Any suggestions?
Thanks
Mark
Any suggestions?
Thanks
Mark
https://www.koolstop.com/english/rim_pads.html
Quoted: 834 Post(s)
Liked 2,125 Times
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
I like the look of the HS33 Pro as well. Curiously, the photo of the HS33 Pro in the link you provided does not show a bolt or nut to attach to the caliper (whereas the other models do show bolts & nuts). Do you need to supply these, or are they included but just not pictured?
morksmith, Kool-Stop makes pads for Weinmann brakes, the 4 dot, 6 dot, and X models. They slide into the old holders. Use a hammer if needed.
AFAIK, Kool-stop and Yokozuna use the same Matthauser formula.
I use the Cross pads with Weinmanns and they work great. The steel rims put you at a great disadvantage when it comes to stopping in the wet.
"part timer"
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times
Kool Stop makes two different styles of pads (4 dot and 6 dot) that are direct replacements for your Weinmann holders. Available in salmon or black:
https://www.koolstop.com/english/weinmann4.html
Went for Kool Stop Continentals in the end in Salmon - fitted fine and the difference in braking is huge - they are great, went from a real limp slowing down gradually action to being able to skid to a halt instantly...
