When I pedal, I can't shift into gears
Old 08-29-15, 08:31 PM
DreamRider85
DreamRider85's Avatar
Quoted: 247 Post(s)
Liked 9 Times in 4 Posts
Now this problem has happened before. It's always after going up a steep hill. Why is that? Do I need to take it into LBS or is it fixable? Basically I don't know how to explain it. When I pedal, I can't get into any gears. My bike cannot generate any power and I'm just spinning my wheels.
On a side note, my saddle bones aren't sore. I just rode 45 miles on my new ALR Emonda with my new padded bike shorts and I don't feel sore. I feel less sore after 45 miles now then I did after 25 miles. So I think that my saddle is good, maybe I just needed better shorts and a little getting used to the bike. But now I have the gear problem and it happened at the end of my workout.
DreamRider85 is offline
Old 08-29-15, 08:46 PM
f4rrest
Farmer tan
f4rrest's Avatar
Bikes: Allez, SuperSix Evo
Quoted: 2870 Post(s)
Liked 24 Times in 20 Posts
Good news on the lack of soreness.
It's not very clear what you are describing regarding the spinning wheels gearing issue.
So, is the problem happening going up the hill or after the crest going down?
f4rrest is offline
Bunyanderman
Bikes: NeilPryde Alize Raleigh Misceo 2.0
Quoted: 5 Post(s)
You are probably dropping the chain of the small front ring. It can be adjusted to perform and shift correctly. Bring it to a shop, or try and learn online.
Bunyanderman is offline
TheRef
TheRef's Avatar
Quoted: 120 Post(s)
Liked 12 Times in 7 Posts
Maybe the derailleur got damaged when you hit the little girl.
TheRef is offline
Old 08-29-15, 08:54 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3118 Post(s)
Liked 338 Times in 215 Posts
You've dropped your chain.
Put it back on and take the bicycle to an LBS to have them adjust it so that you don't drop your chain.
Machka is offline
Old 08-29-15, 08:56 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 988 Post(s)
Liked 265 Times in 203 Posts
If the chain came off, you would see it flopping around. A bit more observation and information would help.
Homebrew01 is online now
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1188 Post(s)
Liked 46 Times in 31 Posts
Could be your freehub, too. If your chain is properly in place everywhere, that's the only other possibility. Why it happens after climbing a steep hill, no clue. Just be happy it didn't let loose while climbing said hill.
joejack951 is offline
Old 08-29-15, 08:57 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
True ... that's happened to me before, but I had put a lot of kilometers onto those freehubs in all kinds of weather.
Machka is offline
Old 08-29-15, 09:22 PM
DreamRider85
Quoted: 247 Post(s)
Look guys. When I peddle, I'm just spinning my wheels. I can't generate any power even when I shift the gears. It's as Simple as that.
Old 08-29-15, 09:29 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
To sum up what we have said above ... either you have dropped your chain ... or your freehub is kaput.
Or ...
Is your bicycle still doing that now? Or did you shift enough times to get back into a gear that does "generate power"?
Machka is offline
Old 08-29-15, 09:40 PM
rms13
Quoted: 274 Post(s)
When you pedal, the desired outcome is that your wheels spin. Am I missing something?
rms13 is offline
Old 08-29-15, 09:43 PM
DreamRider85
Quoted: 247 Post(s)
Or ...
How does the chain drop? How much do BS charge?
DreamRider85
Quoted: 247 Post(s)
I can't change gears, It's like the gears are all 0
Old 08-29-15, 09:48 PM
rms13
Quoted: 274 Post(s)
If chain dropped, I assume he'd stop and put it back on and I would assume he'd recognize that. Is it front or rear that's not shifting or both? Something makes me think user error...no offense
rms13 is offline
Old 08-29-15, 09:49 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
So you climbed the hill, and then all of a sudden you could no longer change gears and still can't. So you coasted home or walked or something?
Is that right?
Go look at your bicycle. What does your chain look like? Is it taut or is it just hanging there? Take a photo and post it here.
Machka is offline
Old 08-30-15, 04:29 AM
DreamRider85
Quoted: 247 Post(s)
Is that right?
I walked the last half mile. Once I climbed a hill, I couldn't spin at any gear I wanted. It was like every Gear was set at 0. When I turned the wheels backwards it was making a strange, rough sound.
Old 08-30-15, 04:35 AM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Did you look at the chain? Go look at the chain now. Is it sitting on the gears with the teeth of the gears peeking through the holes of the chain, or is it lodged between two gears, or off the gears all together?
Machka is offline
Old 08-30-15, 05:03 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 988 Post(s)
Could be that the chain is riding on top of the small chainring. Not shifting properly between rings.
The chain usually drops off the front chainring because the limit screws are misadjusted, allowing the front derailleur to push the chain too far. The LOW limit screw controls shifting to the smallest chainring. The HIGH limit screw control shifting to the biggest chainring.
Old 08-30-15, 05:05 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 988 Post(s)
Look at the bike.
Hold the bike with 1 hand, and turn the pedal with the other.
Does the chain appear to be properly on the rear cogs and front chain ring ??
Or has it come off the front chainring ?
How did it get fixed last time ?
You don't need experience or technical terms to explain this, and it would be helpful to know.
Old 08-30-15, 05:12 AM
hokie cycler
hokie cycler's Avatar
Bikes: 2018 Giant Stance 1, 2011 Trek Madone 3.1, 2004 LeMond Nevada City, 1980 Peugeot Course single speed, 1978 Peugeot AO-8
Quoted: 5 Post(s)
Peddle: To sell something.
Pedal: Move by working the pedals of a bicycle.
hokie cycler is offline
Old 08-30-15, 06:20 AM
Quoted: 11383 Post(s)
Liked 3,020 Times in 1,681 Posts
I am not buying what you're peddling.
Old 08-30-15, 06:22 AM
Pretty poor trolling on the part of the OP. Can't believe so many people bit.
Old 08-30-15, 06:41 AM
gregf83
Quoted: 1051 Post(s)
Liked 174 Times in 104 Posts
At least someone noticed early on. Others were a little slower.
gregf83 is offline
Old 08-30-15, 07:00 AM
rms13
Quoted: 274 Post(s)
Apparently LBS that charges a couple hundred every time a bike falls over also cant set a limit screw.
rms13 is offline
Old 08-30-15, 07:08 AM
PepeM
PepeM's Avatar
Quoted: 2723 Post(s)
Liked 99 Times in 47 Posts
Should get yourself a set of eyes. Might help you troubleshoot these issues by yourself in the future.
PepeM is offline
