What's the easiset way for me to remove my tire for a knobby one?
Old 09-03-15, 02:44 AM
DreamRider85
DreamRider85's Avatar
Quoted: 261 Post(s)
Liked 11 Times in 4 Posts
I have a mountain bike, but it has road bike type slicks. Wouldn't it be better to put back the knobby tires, since I plan on using it for mountains and dirt trails?
So would I have to take the whole wheel off? Or could I just deflate the tire, take it off, and put the other one back on?
DreamRider85 is offline
Old 09-03-15, 02:51 AM
CliffordK
CliffordK's Avatar
Quoted: 11517 Post(s)
Liked 939 Times in 729 Posts
  • Remove the wheel from the bike.
  • Deflate.
  • Pull the tire off the rim (I can usually just pull it off the side of the rim).
  • Move tube to new tire, and remount
  • Reinflate.
  • Make sure bead is properly set.
  • Remount wheel.
(note, sometimes if brakes are problematic, deflate before removing wheel, and remount wheel before inflating).
CliffordK is offline
Old 09-03-15, 09:19 AM
stockae92
Quoted: 48 Post(s)
maybe this will help
https://www.youtube.com/watch?v=ueGfr70TJBQ
stockae92 is offline
Old 09-03-15, 11:41 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1961 Post(s)
Liked 522 Times in 361 Posts
That would be a neat trick.
Genesis 49:16-17
Darth Lefty is offline
Old 09-03-15, 12:11 PM
sw686blue
Liked 7 Times in 2 Posts
No need to take off the wheel. Follow these easy steps.
1) Deflate the tire
2) Cut across the width of the old tire with scissors or a sharp knife
3) Cut across the width of the new tire
4) Wrap it around the tube and wheel
5) Duct tape the cut
6) Inflate the tire
7) Hit the trails!
sw686blue is offline
Old 09-03-15, 01:27 PM
Registered User
Bikes: 2017 Nishiki Maricopa.
Quoted: 63 Post(s)
Liked 4 Times in 3 Posts
No, I get it. He's just been riding around with the knobbies wrapped around the forks and chainstays. OP, you're fine with plan B!
700 is offline
Old 09-03-15, 02:36 PM
SpeshulEd
SpeshulEd's Avatar
Quoted: 686 Post(s)
Liked 3 Times in 3 Posts
Pulling an Aaron Gwin...just keep both tires on the bike and switch as needed. ...or don't even bother and just ride the rim.
Hey guys, lets go play bikes! Strava
SpeshulEd is offline
Old 09-03-15, 08:21 PM
DreamRider85
Quoted: 261 Post(s)
1) Deflate the tire
6) Inflate the tire
7) Hit the trails!
Can't tell if being sarcastic. Use scissors?
Old 09-03-15, 08:38 PM
SpeshulEd
SpeshulEd's Avatar
Quoted: 686 Post(s)
He's being sarcastic. If you want to remove the tire from the rim, you need to remove the entire wheel from the bike. The axle gets in the way if you don't.
This shouldn't be that difficult, if it is, then you should practice anyway. Put the chain on the smallest cog in the back, take the wheel off, swap tires, put the wheel back on, put the chain back on the small cog, done.
Old 09-03-15, 08:41 PM
DreamRider85
Quoted: 261 Post(s)
W
What does smallest cog mean? I'm sorry, I'm not the most bike literate. I saw a video though for Trek that says put bike in highest gear
Old 09-03-15, 09:57 PM
DreamRider85
Quoted: 261 Post(s)
  • Deflate.
  • Reinflate.
  • Remount wheel.
All the steps seem reasonable, but removing the wheel seems like it has 10 steps and many different scenarios. What's the most reasonable and easy way to remove wheel?
Old 09-03-15, 10:11 PM
CliffordK
CliffordK's Avatar
Do you have something like a bike co-op that would help teach you some basic bicycle care and maintenance? Or as your local bike shop if the would be sometime you could work on a few simple things with supervision.
Some schools also have bike maintenance courses.
Old 09-04-15, 12:25 AM
SpeshulEd
SpeshulEd's Avatar
Quoted: 686 Post(s)
W
Smallest cog is the little ring (gear) on your sprockets (cassette) on your back wheel. Same as your highest gear. Basically you put the chain in that gear so it's easy to get on and off when you remove the wheel.
This video was posted earlier. It seems to cover things pretty well. Give it a watch.
Changing your tires will be good practice for a flat tire. It's definitely a skill worth learning, especially if you're out by yourself on a trail.
Old 09-04-15, 03:30 AM
DreamRider85
Quoted: 261 Post(s)
So I can see you put it on highest gear and just spin wheels backwards? But what is he doing with the levers exactly after that? That's the tricky part. I can't see it well and all bikes are different. What if I don't know what I'm doing? Also I have no idea how he put the tire back on bike.
Old 09-04-15, 05:08 AM
Bradleykd
Bikes: '89 Eddy Merckx Professional, '12 Felt Z85, '16 Niner Air9 Carbon, '17 Ridley Noah
Quoted: 76 Post(s)
post a few pictures of your bike, both sides. We will be able to tell you step by step for your specific application
Bradleykd is offline
Old 09-04-15, 05:49 PM
DreamRider85
Quoted: 261 Post(s)
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 09-05-15, 10:14 PM
DreamRider85
Quoted: 261 Post(s)
bump
Old 09-06-15, 05:15 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 5336 Post(s)
Liked 1,033 Times in 556 Posts
Here's an overview:
Park Tool Co. ParkTool Blog Wheel Removal and Installation
More in-depth video on using QR skewers:
Even more on QR skewers:
On swapping out tires:
Park Tool Co. ParkTool Blog Tire and Inner Tube Replacement
LesterOfPuppets is offline
Old 09-06-15, 05:16 PM
LesterOfPuppets
Bikes: everywhere
Just get this frame, and put a Lefty fork on it!
RowdyTI
Northern California
4
09-17-17 02:58 PM
bikecommuter13
Bicycle Mechanics
15
12-11-16 09:19 AM
Johnny Alien
Bicycle Mechanics
15
08-20-13 09:31 PM
dannymctrance
Bicycle Mechanics
7
05-28-13 10:23 AM
Cyclist75354986865
Road Cycling
5
04-03-11 07:41 PM
