Wahoo Elemnt Bolt Turn by Turn Directions?
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 07-01-20, 01:46 PM
kosmo886
Quoted: 82 Post(s)
Liked 3 Times in 2 Posts
I just got an Elemnt Bolt and uploaded a few routes from Strava. I can access them but they donít seem to be providing turn by turn directions. Is the only way to figure out the route to just look at the picture on the map on the screen? Any tips would be appreciated. Thanks!
kosmo886 is offline
Old 07-01-20, 01:52 PM
Plainsman
Plainsman's Avatar
Quoted: 75 Post(s)
Liked 12 Times in 7 Posts
Strava does not export turn by turn cues. This was the case back in 2017/2018 anyway. The Elemnt does not have those built in. If you use Kamoot or Ride with GPS (created from Scratch) it will work. You can't try to back door it though by putting the Strava file through Kamoot or Ride with GPS. This video from GP Lama helped me. If this has been updated and someone else knows the trick, I'm all ears too!
Plainsman is offline
Old 07-01-20, 02:39 PM
MidTNBrad
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 103 Post(s)
Liked 39 Times in 26 Posts
This is one of the big reasons I'm moving away from Strava to RWGPS.
MidTNBrad is offline
Old 07-01-20, 05:22 PM
kosmo886
Quoted: 82 Post(s)
https://www.youtube.com/watch?v=ccDMxcW1BuM
That seems like a big missed opportunity for Strava. All my friends are on Strava. Would this mean essentially running ride with GPS and Strava at the same time?
kosmo886 is offline
Old 07-01-20, 05:30 PM
Steve B.
Quoted: 1624 Post(s)
Liked 334 Times in 236 Posts
You can save completed rides to Strava but use RWGPS to create rides.
Steve B. is offline
Old 07-01-20, 05:51 PM
WhyFi
WhyFi's Avatar
Quoted: 13063 Post(s)
Liked 2,499 Times in 1,336 Posts
No. I never run RwGPS on a ride. I simply create routes with RwGPS on the computer and have my Wahoo and RwGPS accounts linked; the created routes will migrate over to the Wahoo.
WhyFi is online now
Old 07-01-20, 05:56 PM
kosmo886
Quoted: 82 Post(s)
Got it. I just got my Wahoo so sorry for the basic questions! I just created a route on ride with GPS and linked to my Strava account and Wahoo. I will test shortly, but assume I just start the route on the Wahoo and should have everything all linked up and audible turn by turn directions. Is this the best way to do it? Thanks!
kosmo886 is offline
Old 07-01-20, 06:45 PM
kosmo886
Quoted: 82 Post(s)
Is it possible to set a start and end point (likely the same) and desired distance and have RWGPS set a random route to those parameters?
kosmo886 is offline
Old 07-01-20, 06:49 PM
WhyFi
WhyFi's Avatar
Yup. You can either select the route from your Wahoo or from the Wahoo Element companion app.
Oh, to be clear, though - it's not giving spoken turn instructions; it's beeping at you when a turn is approaching and giving you instructions (left/right, street name) on-screen.
WhyFi is online now
Old 07-01-20, 07:00 PM
Steve B.
Only way I know to get an audible TBT is on a Garmin that is BT connected to a phone that you can connect headphones. I’ve heard of this, never done it. Maybe some of the smartphone GPS cycling apps can do this as well.
Steve B. is offline
Old 07-02-20, 12:09 AM
woodcraft
woodcraft's Avatar
Quoted: 1425 Post(s)
Liked 434 Times in 266 Posts
No, but it's possible to plot a route on RWGPS and have it make some pretty random jumps while you're working on it.
woodcraft is offline
Old 07-02-20, 02:12 AM
SurferCyclist
Bikes: Canyon Endurace CF 9.0 Di2, Cannondale CaaD 8, Diamondback MTB(ancient)
Quoted: 24 Post(s)
Liked 53 Times in 16 Posts
This. However bear in mind the navigation on the Bolt is not brilliant. If you miss a turn it'll tell you but won't redirect back onto route. I rarely use it for navigational purposes, if I ride somewhere completely new I find it helps to check over some OS maps etc and get a rough idea of area. Plus have phone with Google maps on if you'll really stuck.
SurferCyclist is offline
Old 07-02-20, 07:11 AM
kosmo886
Quoted: 82 Post(s)
Just took a ride using RWGPS route pushed to the Wahoo. Worked quite well. Syncing that to Strava was also smooth. Only outstanding question is if I can get Apple Watch HR data to the apps...
kosmo886 is offline
