Masi 2016 CX Comp - Steel Gravel Road/Adventure Bike
Quoted: 147 Post(s)
Liked 8 Times
Its not really a cx bike as it doesn't meet UCI rules for a cx bike.
But the Masi CX Comp is a capable gravel road/adventure bike. Helps that its made of steel and come equipped with Kenda Kwick Trax 38c tires:
Bikes: Newish steel.
Quoted: 117 Post(s)
Wow, they have really made that a nice package at a good price. The Tiagra 4700 stuff is pretty solid, and the new orange looks great.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
just curious, what disqualifies it for the UCI?
--oh, and me likey.
--oh, and me likey.
Quoted: 394 Post(s)
Liked 197 Times
so swap the tires, and discs are allowed as of this year* -- I do like the 'in between' geometry, makes for a very capable go-anywhere machine....
*sorta https://velonews.competitor.com/2015/...-august_366590
(and if you're in the States, you can run discs as long as it's not a UCI event -- https://www.usacycling.org/technical-...pdate-1502.htm)
It does look like a pretty cool bike. The current Masi lineup looks pretty nice in general...
but this statement is way off. Tires are an easy swap if you're racing a UCI specific event (most US cross races aren't), disc brakes have been in pro cyclocross for a few years now, and the trend of US cross bikes over the last few years has been to lower the bottom bracket.
Just sayin'...
Just sayin'...
Quoted: 175 Post(s)
Disc brakes have been allowed for cyclocross racing by UCI since 2011. And the maximum tire size allowed by UCI for cyclocross racing is 33mm. Used to be 35mm, but it was changed also for 2011 season.
I don't know if the Masi meets the other UCI geometry requirements for CX bikes, but most likely it does. So it would be UCI ok as long as you run proper tires. And, for what is worth, many CX bikes are sold with non-UCI compliant tires. Specially the lower spec models, because most people will not be racing UCI sanctioned races.
According to their website it comes equipped with Kenda Small Block Eight 35c tires.
Masi Bikes - Cyclocross - CX Comp
I've been ogling it for a commuter -- I'm assuming they cut corners _somewhere_ given that's it priced a few hundred bucks less than similar bikes, but the wheel/brakes actually seem kinda average?
I'd say you're ogling in the right place for a commuter.
The wheels aren't actually bad. Just not a big name like Mavic that's paranoid about every gram of mass. Weinmann makes fine rims that have seen abuse under me and stayed true. As for the brakes, what they have listed is actually the pads. The calipers look like Tektro which aren't bad at all.
