Help identifying lacing pattern
Excuse the rookie question, but can someone please confirm the lacing of this wheel (not mine), is it x3?:
Really Old Senior Member
Ya think you could take a pic where the rotor isn't covering the area of interest?
Sometimes a bit of thought can be useful.
Likes For Bill Kapaun:
Lol I did not take the pic, it's from the web, plus an area of interest is subjective, it so happens mine and his aren't the same...
Here's another one, perhaps x2?:
It'd be quite difficult to lace 24 spokes more than 2X.
Quoted: 2430 Post(s)
Liked 2,891 Times
Interesting that the wheel builder/manufacturer decided that interlacing the spokes was unnecessary. Might be nearly impossible to do, at that, given that hub design and the use of such heavy-gauge spokes.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Seems like the kind of hub meant to be built with bladed spokes only (to facilitate interlacing)
Senior member
Quoted: 937 Post(s)
Liked 652 Times
Straight pull wheels are often not interlaced. I build as many straight pull as J bend these days, and I do interlace when it doesn't cause too much distortion, but don't sweat it if you can't.
Likes For Dan Burkhart:
bike whisperer
Quoted: 1520 Post(s)
Liked 716 Times
Those spokes look way too beefy. That wheel will have no elasticity, and be prone to fatigue failure and spoke unwinding unless there's a hell of a lot of spoke tension.
...Hang on, that wheel is tiny. Is it less than 20"? Are those 14g spokes? Even so, butted would be nice, although I guess very hard to find in that length.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Hello
That looks like a Brompton Titanium Fork. It appears that the welds used for the add on disc brake have cracked.
You say Picture from the web, I hope they are explaining what they did wrong and are not planning to ride it.
Yep a 16" wheel, likely a proof of concept, when I look at the owner's more recent pics that particular fork setup is not being used.
Senior member
Quoted: 937 Post(s)
Liked 652 Times
Note that it says the hub manufacturer should give you the offset but more often than not, I have to determine it on my own. That means trying to determine where the center line of the hub passes through the post, inserting a spoke of a known length and measuring how much spoke protrudes.
