Wth?
Wth?
I was putting air in my tire with this new pump I purchased, and the pump heated up like hot dog right off the grill.
Can someone recommend a pump – or a catcher's mitt?
Tire size is 26" x 2.0"
Bikes: Jamis renegade, surly big dummy, giant talon 29er
Quoted: 62 Post(s)
Liked 42 Times
Topeak road morph. Just replace mine with the same one after 10yrs of service.
Likes For Chris!:
Maybe a little silicon lubricant on the pump’s piston! Also maybe slow your “cycle rate” down a bit.
Quoted: 2479 Post(s)
Liked 2,947 Times
Physics. If you were to inflate a 26 x 2.00 tire from 0 psi to full pressure, any mini pump of that size would heat up as much as yours did.
A larger mini pump would get the job done faster and probably wouldn't reach the same temperature, but for keeping your tires properly inflated, a floor pump with a gauge is the way to go.
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Just do a CO2 chaser and hold the cartridge bare-handed.
Likes For Sy Reene:
Quoted: 2952 Post(s)
Liked 3,106 Times
Isn't that just Charles' Law?
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
My Topeak road morph is actually still going strong after ten years so that’s another mention/vote right there.
Likes For Rage:
Quoted: 608 Post(s)
Liked 352 Times
My Lezyne heats up and when I get to about 75% I stop and let the pump cool down. Two reasons for this, I don't want to wreck the pump and second I need a rest. If you are replacing your tube at the side of the road, use the old tube and wrap it around the pump to insulate it from your hand.
Likes For blakcloud:
Likes For alcjphil:
That particular action on those frame pumps make guys revert back to their teenage years and they go way too fast...slow it down son.
LMAO
On the Topeak website there are 33 mini pumps that have a capacity ranging from 60 PSI to 160 PSI.
My tires have a PSI range from 35-70.
Does it matter which pump I get?
Quoted: 6935 Post(s)
Liked 10,940 Times
Lots of people around here love the Topeak mini pump that's been mentioned.
I have a couple of Silca Tattico mini pumps, and they don't heat up -- very intelligent design with a heat sink and some insulation between the air chamber and the grip.
Quoted: 1943 Post(s)
Liked 2,164 Times
I use a Topeak Peak DXII as a portable pump for a mountain bike tire. Even though 26x2.0 is that large of a tire, I think the mini would just make it take even longer.
It only goes to 90psi, but I would think that is more than enough.
John
John
Bikes: two blacks, a blue and a white.
Quoted: 444 Post(s)
Liked 844 Times
home: floor pump road: CO2 Even a cold minipump is a major pain to use. Touring, OK, maybe. But if I can't get done with 3 cartridges on the road, I'm using the phone.
Quoted: 18397 Post(s)
Liked 15,493 Times
I discovered the Road Morph G in 1999 when I rode across the U.S. with twelve others. Two members of the group had them The rest of us would frequently borrow them. When I got home I picked up one for myself. Like you, I have only had to replace it once. My only complaint about it is that the pressure gauge is not nice to aging eyes like mine.
Quoted: 576 Post(s)
Liked 1,001 Times
Clark W. Griswold
Quoted: 4332 Post(s)
Liked 3,956 Times
Normally yes Topeak road morph but I think the Mountain Morph is the better option for this situation. However any pump will generate heat after prolonged usage.
Never heard of Pro Bike Tools but Shimano does do tools under Pro but they also do some saddles, bars and other stuff as well, kind of an odd choice of names but it doesn't look like a terrible pump.
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
PV = nRT. It's not just a good idea. It's the law.
Likes For genejockey:
Quoted: 6177 Post(s)
Liked 4,794 Times
I wouldn't fill any tire with a pump that size. I might top them off. Or if my CO2 didn't inflate it enough on the road, I might use that. But again, just to top of the partially filled tire.
If you don't want to use CO2, I'm okay with that. But carry a bigger frame mounted pump so you can get the tires inflated before dark.
Half way there
Quoted: 985 Post(s)
Liked 879 Times
That's why air compressor cylinders have cooling fins. It takes a lot of work to fill those big tires with such a small pump. Mini-pumps are great - I have quite a few, but I do prefer a larger frame-fit pump.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
Not really. Charles law describes the change in temperature or volume for a constant pressure. What you are looking for is the combined gas law which combines Charle’s Law (V=kT), Boyles Law (V=k/P), and Guy-Lussac’s Law (P=kT). Whip them all together and you get the Combined Gas Law: PV/T = k.
Won’t matter. The above doesn’t depend on rate. Increase the pressure by deceasing the volume and you end up with a higher temperature. You lose some heat due to radiation and convection but that’s only a small part of the equation.
Stuart Black
Stuart Black
Likes For cyccommute:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Likes For Phil_gretz:
