My 1973 Favorit
Likes For tricky:
Quoted: 634 Post(s)
Liked 444 Times
Thanks for posting; these are lots of fun.
If located in U.S. importer would have been American Jawa of Valley Stream NY.
Hub barrels may be marked ESKA.
Note how pump pegs also serve as housing stops.
Original rear mech would have been a Favorit PWB (Prague-Warsaw-Berlin) model.
please keep us posted as you work with the new arrival
Quoted: 1324 Post(s)
Liked 927 Times
My sister has a hexagonal frame tubing ladies Favorit bike. She likes it a lot.
Cheers
Cheers
Likes For oneclick:
Likes For tricky:
Quoted: 1106 Post(s)
Liked 1,326 Times
You might want to check that that green isn't supposed to be blue. I went with the box as shown, but it may have faded, and I've seen that circle-F with red -and-blue.
Likes For oneclick:
Quoted: 634 Post(s)
Liked 444 Times
Liked 1,326 Times
Almost complete
All it need now are pedals. It came with Atom 600s, and on dissassembly I found one had a broken cone (see the ISO sticky thread). It'll probably get some Lyotards.
Favorit made pedals and it would have been nice to have them but probably too much bother; besides, I'm gonna sell this one. Whoever buys it can look for the pedals, and the hoods, and the pump, and the Barums, and the Favorit seatpost...or maybe just ride it.
Pics were taken just after a bit of woodworking in the yard which is the source of the tiny white flakes in the pictures:
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
I am going to pick up Kveta Favorit this weekend (no Slovakian-Czeck names starting with an F). Not sure why I did it, but I couldn't resist...it's not like I don't have 20 projects, bike and other, rolling around.
Quoted: 3810 Post(s)
Liked 3,336 Times
the combination of Favorit and Rapido transfers is interesting
"usually" the Favorit badge is employed for sports machines
the Rapido bage is commonly seen on adult transoportation type biycles such as one-speed coaster brake models, planetary 3-speeds and derailleur 5-speeds
when you have the factory and all of the transfers to hand for the various marques it must be tempting to make some combinations...
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 589 Times
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Edumacator
Liked 3,119 Times
My other inclination is to fit it out and ride it as a city bike, which is one bike type I have not ventured toward.
Edumacator
Liked 3,119 Times
Could be. Wish it had a few more parts to go with it to indicate what it might have been, but as I said above, this one is on slow motion as far as the build.
Edumacator
Liked 3,119 Times
Beauty! Like I said, not sure why I picked it up (the price sucked me in), and I am not sure what I am quite going to do with it.
Liked 3,336 Times
Likes For juvela:
Bikes: HVZ Meteor 1979, HVZ Champion 1962, HVZ SS Moskva80 1981, Dürkopp 1936
Quoted: 41 Post(s)
Liked 350 Times
One of my Harkov road bikes had been painted in a Favorit livery for some reason, guess they had more cool factor back in the soviet days. Did Favorit have any higher end stuff also?
Liked 3,336 Times
at the time of the cycles discussed in this thread they had a top model whose frame was eleven-tube 531c and whose kitting was all Campag NR
this was the machine employed by the Czech national team
there was a model one down from this which was kitted with a mix of Favorit and Campag NR components -
https://www.sterba-bike.cz/item/favo...rchive?lang=EN
had the opportunity to view a new example of the one down from the top model at me lbs ~1972. frame was full Reynolds 531 with some scrolly lugs (may have been NERVEX Professional but did not know lug names at the time).
finish was a deep red flambouyant with no chrome.
kitting included Campag NR chainset, gear ensemble and hubs. Favorit brakes & pedals. can no longer recall the balance of the machine's componentry.
have a 1985 price list from the importer. at that time the top pro model had a wholesale cost of $550.
Liked 3,336 Times
@oneclick
the RNK marking on the cycle's gear block and the RENAK marking on the hub barrel refer to a subsidiary of Fichtel & Sachs called Reichenbacher Naben & Kupplungwerke located in Chemnitz.
information from disraeligears.co.uk:
Trivia - Renak
there are also RENAK branded derailleurs
@oneclick
Trivia - Renak
Quoted: 351 Post(s)
Liked 589 Times
The Tear Down Begins
I have started the process of bringing the '73 Favorit back to life. I've seldom seen any bike that was harder to get apart than this one. Every major part has been a struggle, and without the help of my heat gun it would have never come apart. Whatever grease was used for assembly had hardened into some kind of glue that only brute force and heat could break! I thought I would never get the bottom bracket out. It had been hanging in a workshop unused for at least 35 years.
Weighed the bare frame at 5.2 lbs, not bad. Other than some light rusting and really terrible looking factory welds it looks good. Unique stops look pressed in place cable .
I will update as I go and find out new things about the bike.
BB weld
Some of the epoxy grease!
Different style headset.
Welds all over.
Crimp on original shift cable looks like pressed cable.
BB weld
Welds all over.
Quoted: 351 Post(s)
Liked 589 Times
Work is progressing . Cleaning rusty spokes is just not fun. Front hub looks like Velo marking?
Quoted: 351 Post(s)
Liked 589 Times
Things are coming together on the Favorit. Both wheels have been cleaned, trued and new bearings. I had to modify an extra Park FR4 freewheel remover to get the freewheel off. It is a 13T to 23T and won't go back on. I'll take advantage of the SR rear derailleur and put a SR 14T-28T I have surplus. The CR is 52-46 and doesn't give very low gearing. The original pedals cleaned up very nicely.
Liked 3,336 Times
great to see it moving forward!
thanks very much for posting these updates
fine work being done
do the pedal dust caps snap off so the pedals can be disassembled?
freewheel removal tip -
on these two notch types with the raised ring never attempt removal with a tool which lacks a guide ring. use one with a guide ring such as Campag, Shimano DuraAce, Bicycle Research, etc.
without a guide ring things can shift under load, no matter how tight one makes the tool, damaging the removal ears and rendering removal more difficult in subsequent attempts
Likes For juvela:
Quoted: 7348 Post(s)
Liked 2,463 Times
I don't think I would have the patience to work on something at this quality level. I admire that.
