Brushes and cleaning supplies
I'm in the market for some new scrubbing brushes for dirty parts and wondering what you use. Once upon a time I had the Park gear cleaning brush which was nice and stiff but it wore out and is too expensive to replace all the time.
I was disassembling and scrubbing cassettes last night and was thinking my current dollar store brush was on its last legs and perhaps there was better option for all components.
Quoted: 1607 Post(s)
Liked 2,216 Times
After cleaning with mineral spirits, I use an old rag and slide it between the sprockets. The back and forth motion uses the ratcheting of the freewheel to rotate the block. Old tooth brush on the sprocket teeth.
A majority of the cleaning is done with a rag and toothbrush, even some polishing with mothers to get to hard places like around the spokes on the hub.
Quoted: 1199 Post(s)
Liked 1,354 Times
The wife got mad at me for stealing her dish scrubbing brush. But I told her the bristles were long enough to clean in between the freewheel sprockets.
So I put it back and bought myself 2 new ones.
99 cent store is my go to place for bike cleaning stuff like scrub brushes, zip ties, rags, 0000 steel wool and sometimeswd40 is in stock.
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Honestly, I don't bother with brushes on freewheels anymore. For as little as $6 you can get a cheapo set on Amazon, search their site for: B07H2X9LJX
Regular cheap paint brush to paint mineral spirits or your choice of grease solvent info the gaps, the steel handle paint brushes work great. Let soak. Use the plastic tool from the kit above through the valley of the cogs to break crap up. Run the spine of a cheap red shop towel through each valley. To get the front/back sides of the cogs in said valley, wrap the shop cloth around the plastic tool, reinsert, wipe. No brush needed.
On brushes, I've got a gaggle of old toothbrushes, but the detail brush kits you get at any auto parts store with one steel, one brass, one plastic bristled brush for $3-5 are perfect for every aspect of working on bikes not requiring long reach. But using a brush with long reach is a futile task: The bristles get jacked up quickly.
Likes For francophile:
Liked 2,216 Times
My favorite part of that ad is the second picture that states " The bottom brush can clean the dust in the frisbee"
Likes For SJX426:
Quoted: 874 Post(s)
Liked 2,287 Times
Rag with some solvent method works well, though I like to add in a sheet of card board for some rigidity to really get in there. It helps to cut the carboard into the shape you need, like a gear scrapper half circle kinda shape, or if its a tight fit the cardboard by itself works pretty decent too.
https://sundaybikeride.wordpress.com/
Old rag with mineral spirits works great. For things like cassettes and chainrings I use a toothbrush. I don't use any brushed larger than that, but the toothbrushes can't get deep down between the cogs.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,482 Times
I go really high tech with my cleaning supplies: paper towels and WD-40.
Likes For SurferRosa:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I like to use a thin steel rule as a scraper to peel away the gunk that has settled and hardened just below the tooth valleys.
Then it's on to a strong cleaner of some sort, and the flossing methods and brushes.
Only by removing the cogs can you make an old freewheel look like this though (this one was a custom Shimano "Ultra-6" build, so had to come apart anyway).
Quoted: 107 Post(s)
Liked 151 Times
When I was in high school, a friend would load all his components into the dishwasher and run it with Cascade and no dry cycle. Came out clean and his mother never suspected.
PM me your cotters
Liked 590 Times
Not entirely true. Slow cooker on low will with heavily diluted degreaser get you similar results. But will also purge the entire outer body and internal workings of all grease. Without a tool such as Stein's freewheel injector or manual disassembly and repack you'll never get that back.
Quoted: 107 Post(s)
Liked 151 Times
Looking for solvent suggestion for old, sticky, dried oil
Recently I've been working on a 1970 Gitane that had been in storage for over 25 years. The drivetrain and brakes were covered in a tan/light brown sticky oil? that does not dissolve in citrus cleaner, kerosene, or mineral spirits. Kerosene softened this stuff, but certainly not what I was expecting. Everything was heavily coated in it (including the right chain stay) as if it was applied as a preservative and it smelled a bit like linseed oil. Also, the grease in the headset and bottom bracket was dried out and wax-like, but that was easy to clean out.
Thanks for all the suggestions. I have used mineral spirits on a couple very caked on bits but I prefer to use stuff that can go down the drain and dont need to worry about stinking up the house or disposing of at the haz waste drop off.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I don’t use any brushes or cleaning supplies...other than a bit of mineral spirits on new chains and an occasional trip to car wash when the cow crap gets too thick...on my bikes because I don’t need to. These shots were all taken without prior cleaning to the picture being taken. I can go out and pull the same bikes off the wall right now and they would still be as clean.
Not the closest picture but you can see that it’s clean.
This one I just got back from the frame shop and rebuilt it. No cleaning of the drivetrain nor the frame were needed before I took it to the welder.
Here it is being built.
Same bike about 9 months ago.
Touring bike. I put a new chain and cassette on it about 5 years ago. The chain was replaced because it had worn out but the cassette was part of a gearing upgrade.
This one is actually “dirty” comparatively. It does have about 3000 miles on it.
The key is to not use a lubricant that makes a mess and to use it sparingly. Life is easier...and a bit boring...if you don’t have to clean everything all the time.
Stuart Black
Stuart Black
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
between cogs on a cassette I used 1/8" braided rope. I leave the cassette or the freewheel on the wheel and use the rope like floss. I also use an old toilet brush and an old bottle brush.
Long time part timer
And like others I try to get things like brushes, scrubbers, etc. at the dollar store. My local store even has citrus degreaser that works surprisingly well also.
