Recommend aero wheels for TCR
Hi All,
I have just purchased a 2020 TCR SL advanced frame set (disc) and built it up with spare parts - mechanical ultegra etc. I will update parts over time.
Not a lot of hills where I live so I have decided to get some aero wheels for the bike. I am after advice about 1) suggested brands and 2) the rim depth (I’m thinking 60 back and 50/55 front?). Thanks for any help.
Quoted: 1067 Post(s)
Liked 259 Times
Congrats on the new bike. I have just bought the same thing, but as a complete bike.
I would just be a bit wary of going over 50mm on the front if it is very windy where you ride.
Thanks Dean - not real windy where I live, I generally don’t ride if it’s over 30km per hour anyway.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Hi All,
For people in flatter areas looking to go aero and maybe save some money, I typically suggest a "fairing" style aero wheel like an HED or a FLO. They're often cheaper than full carbon sets at only a marginal weight penalty. Like the RC5 or RC6 disc brake sets they sell.
What is your budget? This can aid with suggestions.
Thanks for the suggestions.
Likes For Murf58:
Newbie racer
Liked 1,569 Times
If you want to run 28mm, go ahead and spend the extra money since you have it on aero wheels designed for 28mm tires. Or ones that take them nicely. With that budget that definitely gets you into all sorts of stuff. Off top of my head, the ENVE wheels and the HED Vanquish (not a fairing wheel, full carbon) measure out pretty good and I think can take a 28mm and stay aero.
Those RC5/6 stuff I suggested are 25mm at the tire interface and a hair wider at the widest part of the aero profile. Meaning, a 28mm would run fine but ruin some aero benefit. So, forget that then and spend the extra on something else.
Just research whichever you get to see how wide the profile is where the tire meets so that a 28mm transitions right nice.
Good luck and have fun, that's an awesome budget for some wheels!
Haven’t come across the HED vanquish so will definitely have a closer look at them as an option.
I appreciate the helpful comments - thankyou.
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
A little below that budget are the new FFWD RYOT wheels. I just got a set of RYOT 55s with the DT Swiss 350 hubs; those with 240s run about 1900 I think. I've got a few rides of varying distance on them so far, but have been very pleased. They are optimized for 28mm tires. I've ridden in some pretty strong crosswinds with them; while they definitely aren't low profile, I haven't had any scary moments. I have them set up tubeless with 25s (purchased for a different wheelset - don't ask), running 75 psi. They feel great. I have been really pleased with their customer service as well. So... take a look. And I've included the
gratuitous look at my bike / wheels photo.
Likes For ericcox:
Thanks ericcox, your bike looks awesome, love the colour!
I will take a look at these wheels and check availability - much appreciated.
Likes For Murf58:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Likes For Sy Reene:
Quoted: 20810 Post(s)
Liked 9,456 Times
+1 to the suggestion to look at something wider that's made to be aero with a 28mm.
I recently bought some Zipp 303S, I love them, but I would only recommend them (or the new 303 Firecrest) if you're sold on tubeless tires - they're hookless and can only be run with tubeless tires. Likewise with some ENVE - some are hookless, so make sure they're compatible with regular clinchers if that's what you're planning on running. Roval (specialized) also have some interesting new wheels, but you have to be aware of the opposite - some may not be compatible with tubeless tires, if you'd like to keep that option open. Bontrager (Trek) also have some interesting new offerings, with modern dimensions and a decent balance of weight and value.
Likes For WhyFi:
Trying to keep up
Quoted: 79 Post(s)
Liked 136 Times
Edit: nevermind - OP says it is a disc frame. The RYOTs are hooked - can be run tubeless or tubed. I will say installing the tubeless GP5000s was difficult- I had to get help. I now have some new tools to help.
Quoted: 1461 Post(s)
Liked 1,485 Times
A word of warning: Enve says if you buy today, these won't ship until August. This is probably a concern with any wheel in this range at the moment.
Quoted: 338 Post(s)
Liked 408 Times
Frankly, outside of the very top shelf wheels, I'd look for Light Bicycle wheels, would go for their AR series if you want to run 28s.
I've got a pair of R45s which pair perfectly with 23 rear / 25 front. It wouldn't have hurt to have gone deeper in the rear, front is perfect at 45mm though, very much rideable even when it's quite windy.
Liked 1,485 Times
Likes For msu2001la:
Liked 259 Times
For 28mm tires and disc brakes, a good choice would be Enve SES 4.5AR. They're optimized around 28mm tires, and $2550/set. You can spec 'em with Industry Nine or Chris King hubs if you want to customize. Depth is 49mm front, 55mm rear. Weight is 1500-1600g. I've never rode these wheels, but they look awesome.
Good carbon wheels have come way down in price in the past couple of years, you don't really need to spend $2,500+ on wheels to get really nice ones these days. A few less expensive options to consider:
Hunt 4454. $1,589
Bontrager Aeolus Pro 5 TLR. $1,300
Giant SLR-1 42. ~$1,500.
Thanks all. Apologies if it wasn’t clear in the first post but I definitely need disc brakes.
As mentioned above, availability is currently a major issue and will influence my final decision. Have had a look at the Enve’s but not keen on waiting until August!
On the shortlist at the moment is Campagnolo WTO 60, DT Swiss ERC 1100/1400 and Zipp 303 firecrest (local bike shop chasing up stock for me). I can’t find stock of HED or FFWD wheels.
Trying to keep up
Quoted: 79 Post(s)
Liked 136 Times
If you are in the USA, FFWD USA (FFWD Wheels Carbon Hand Built Bicycle Wheels | Fast Forward Wheels (ffwdusa.com)) sells direct to consumer. I had originally ordered a set of F6 discs in late December that were back ordered. A month later, I talked with customer service and switched to the RYOT 55s. They literally shipped them out that afternoon. But... I can't really judge compared to the others you have listed here.
I’ll have a look at the US site anyway.
Likes For Murf58:
To close this thread off I bought a set of DT Swiss PRC1400 65 wheels, they look very nice.
Haven’t put them together yet but have a set of Cont 5000 26 tyres to go on and have Ultegra discs (not sure of its worth putting lighter discs on? 🙂. Thanks for all the feedback and advice.
Likes For Murf58:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Sram's centerline XR rotors are even more beautiful IMO.
