Ain't it great
resykler
Bikes: Bianchi Eros, Bianchi Reparto Corsa, Mongoose IBOC Campagnolo, Schwinn Super Sport, Mairag 4 Star, Canondale Criterium, Centurion Accordo RS, Specialized Hard Rock 1st Gen, Bianchi Special '81
Quoted: 101 Post(s)
Liked 59 Times
Ain't it great
When all you have left is cosmetic?
Finally sorted the Lotus
Thought I'd share the major tools I use. What would you folks class as absolutely essential? As for the Lotus went a different way using a mountain-L X Derailleur with a shimano HG 8 cog rear, Shimano 600 shifters and Suntour X-1 front. Was given advice on lowering the stem? Rides well , would appreciate input
Quoted: 472 Post(s)
Liked 1,028 Times
Love the mobile work bench. Nice bike. Last summer I rehabilitated a nice Lotus mixte for my daughter in law. Good bikes, even the entry level units. As you can guess, that Lotus is still up in my loft. Who knows when we'll travel to deliver it. Ugh.
Good start on the tools. Keep acquiring until you can put the adjustable wrenches and the vice grips away. Those are good for lawn mowers, not bikes. Also take care with that steel "tar arn". The steel levers can damage aluminum rims. Modern plastic levers work very well and are fine on aluminum rims. Steel levers are good for lawn mowers.
That bike will be great when you're done with the cosmetics. Post more photos.
Quoted: 3807 Post(s)
Liked 3,331 Times
thanks for sharing this update!
good to see it moving forward nearing conclusion
have never known the vendor for Lotus products; was there more than one?
iirc the company was based in upstate NY
EDIT:
ah, here we go -
https://en.wikipedia.org/wiki/Lotus_(bicycles)
https://lotusbikes.tumblr.com/
hast thee as yet commenced operations on the Garlatti?
EDIT:
ah, here we go -
resykler
Quoted: 101 Post(s)
Liked 59 Times
Garlatti ready for love
should I touch up the white?
Need Blue Bartape. Chrome on the Lugs not complying with my zTinfoil
This 50year old Gearset is far from magic
Liked 3,331 Times
hello & thanks for the update on the Garlatti
its stem looks as though it may be slightly too high
there should be about seven cm or so down inside steerer for safety
would expect that original brake levers may have been Universal brand
possible that a dealer mounted these levers at customer request at time of sale
the cycle's gear block appears it may be beyond the nominal capacity of the Campag Valentino rear mech. technical reference materials give this at 28T.
Valentino front mech's cage can be adjusted so that its curve more aligns with that of chainwheels
good to see that Mr. Rubik is there to assist...
Quoted: 1303 Post(s)
Liked 1,908 Times
Every mechanic knows that the tool box should be a roll around! Good on ya! Smiles, MH
