Totally Tubular
#1801
Quoted: 1924 Post(s)
Liked 1,954 Times
Thanks (I think. Since it postpones n+1) for that. I just ordered 3 Roubaix for a future Eroica CA.
#1802
Bikes: many
Quoted: 1435 Post(s)
Liked 1,363 Times
I have to replace the base tape on a couple tubular tires. It seems to me that the material is basically ¾-inch bias tape, likely available at most fabric stores. Are there other properties I'm missing? What sort of adhesive is used to attach it to the casing?
#1804
Ride, Wrench, Swap, Race
Quoted: 1554 Post(s)
Liked 1,274 Times
Some tubulars have a molded casing/tread, which likely includes the base tape in the molding process.
I would note how much glue that different tape materials might tend to absorb. Some tires have a base tape already saturated with cured elastomer of some type, which cuts the amount of glue required (and greatly reduces drying time).
Gluing on a full length of base tape sounds like a lot of work. I have a new 22mm Sprinter tire with the tape falling off from age, even though it's been in a bag for at least as long as I've had it.
#1805
“Senior” Member
Merlin Cycles has Veloflex Vlaanderen on sale for $52.31. I thought they were out of production?? Veloflex website doesn't show them. $27 shipping to US a drag but I ordered 3 so $61/per tire still not bad. I think your order has to get somewhere north of $300 for free shipping to US.
#1806
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 345 Post(s)
Liked 170 Times
#1807
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,782 Times
hey hey hey
stop the Merlin talk.about tubular tires
Two weeks ago, I ordered a bunch of tires and the site (in a red banner) said I couldn't order because of quantity. Only ordered 1 or 2 of each tire.
So I emailed customer service - got an auto reply of CoVid restrictions.
Just did the same again with a new order. Same banner
What's up with you guys being able to buy???
#1808
“Senior” Member
hey hey hey
#1809
Quoted: 378 Post(s)
Liked 1,407 Times
Perhaps Off Topic, but my tubular rims run from basic old-school to deeper carbon.
The newer stuff is deeper and uses valve extensions. I use the replaceable core type.
However, they still leak. Even with Teflon tape.
Most leaky: Zipp Tangente
Least leaky: Tufo Carbon Composite
Any suggestions out there?
#1810
Veteran, Pacifist
Liked 4,782 Times
Not off topic at all.
Sorry, i have no firsthand with valve extensions on deep aero wheels, but since all valve cores should be the same on new tires, a good Pro shop's recommendation would apply across tire brands.
Good topic.
note: my quick search yielded lots of ads, but nothing i would consider adequate info or reviews for current product.
Wow. If valve core won't seal with tape, something sounds amiss.
Maybe my presumption that all new valve cores are the same is not accurate. We are just talking road tires, presta valves.
I've only ever had one valve core problem on a new tubular tire - across maybe 35 sets of tubies over the years (eh, not all were new).
#1811
Veteran, Pacifist
Liked 4,782 Times
Regarding my order with Merlin UK --
It was a quantity 2 on the Veloflex Roubaix that bonked the earlier order. somehow it ended up being a hassle. Maybe I'm dumb. But I did finally get another set of Vlaanderen and 1 Roubaix. Also gonna try the Conti5000 clincher, too.
#1812
Quoted: 1814 Post(s)
Liked 923 Times
Try some different extensions? More wraps of teflon tape. Use two pliers to make sure that the extension is on tight.
I assume that the problem is the extension onto the stem, and not the valve core.
#1813
Bikes: many
Liked 1,363 Times
I have a problem similar to RobbieTunes, but no deep carbon rims are involved. I have a pair of Clement Futurα tires mounted to some AVA rims. The rims are shallow box rims, but, Jiminy Crickets (avoiding BF censors here - you know how I really want to express myself) the valve stems are the shortest I've ever encountered. I can pump the tires with my Zefal HP (locking chuck) but not with the Silca chuck on my Park floor pump (relies on the full engagement possible with a longer stem). I know I should probably just spring for a new locking chuck (Hirame?) but the current chuck also rather clumsily does schrader when I need it.
Unless I've gone completely blind, I believe these tires have removable valve cores. What are the shortest valve stem extenders I can get?
#1815
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,443 Times
#1816
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4311 Post(s)
Liked 2,954 Times
Nope. Think of it as "primer".
I did some maintenance yesterday. Tires were fine but the glue looked sub-optimum so I did a refresh using the craft syringe method.
Sub optimum old glue
Craft syringe method
Refreshed and sticky.
Bar tape matches tires FTW!
#1818
Liked 1,954 Times
If that wheel came to me like that, I'd clean it off and start fresh for my own use. If I was replacing a tire that I had glued on that wheel, I'd leave it.
#1819
Quoted: 2304 Post(s)
Liked 2,742 Times
brass wire brush wheel on drill is fast and safe
#1820
Liked 2,742 Times
here is what 30mm Vittoria corsa control look like with 5800 105 brakes (spec is 28mm max) on 85 team miyata
Likes For squirtdad:
#1821
Liked 2,742 Times
jannd tubular bag....says it holds 2 but tight fit with the 30mm Vittoria Corsa Control
#1822
If I own it, I ride it
Bikes: Lejeune(14), Raleigh, Raysport, Jan De Reus, Gazelle, Masi, B. Carré(4), Springfield, Motobecane(2), Greg Lemond, Andre Bertin, Schwinn Paramount
Quoted: 591 Post(s)
Liked 656 Times
I would like to know how you got two tubulars in that bag. I can barely get one in and often do not close it.
#1823
Liked 2,742 Times
LOL didn't mean to confuse.... I got one 30mm in.....and it is a tight fit with in the bag a multitool, patch kit (good samariatn) lever and bag of caffelatex
#1824
Quoted: 4745 Post(s)
Liked 3,861 Times
Do you make a neat fold of your tires? I'd think two neatly folded tires secured with a toestrap around both wouldn't be too hard to get in and zip up. (There was a thread not too long ago on neatly folded tires. I know DiabloScott posted a photo of his.)
Likes For smontanaro:
