Such a thing *should* exist: freewheel that can be fixed/blocked.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
The main reason I didn't get into fixed gear cycling after trying it, was hills. We have some serious hills 'round here, and if I chose a gear ratio that it makes it possible if not really comfortable, to climb up on most, that same gear ratio will make the descent a hellish experience.
But if there was a freewheel of some sorts, that would be blocked and act as a cog fixed to the hub of the rear wheel, until activated with a cable - well that would solve this problem perfectly. I'd be riding fixed gear most the time, except when going downhill, when I'd activate the freewheel/release the pawls, and coast.
But did anyone make such a device**********
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
not cable actuated but yes it does exsist, I don't remember the name, i've seen two hubs, one has a screw that you thread in and I don't remember how the other worked.
Why not just get a S3X?
Edit* yeah Sram Torpedo
Insane Bicycle Mechanic
Quoted: 820 Post(s)
Liked 770 Times
Jeff Wills
Jeff Wills
Quoted: 5983 Post(s)
Liked 2,908 Times
No, you can't take your feet out of the pedals because you lose too much handling control by doing so, and besides it's very to pick up a set of spinning pedals if you need to. Ask children who can tell you how the backs of their ankles got beat up when they lost the pedals on their speeding trikes.
FB
Chain-L site
FB
Chain-L site
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
2. No, because my son is still a baby and I need to teach him a lot of stuff before I die.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Whoever solves this problem, can make a nice patent.
Well, apparently FG riding is not part of my immediate future.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
I suspect that it has not been done due to worry about lawyers. Going from fixed to freewheel should not be a problem but if the nut behind the bars does so the other way while not pedalling things could get "interesting". In today's legal climate it would have to be idiot proofed, thus the SRAM hubs requirement to stop to change modes.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Quoted: 1074 Post(s)
Liked 295 Times
The main reason I didn't get into fixed gear cycling after trying it, was hills. We have some serious hills 'round here, and if I chose a gear ratio that it makes it possible if not really comfortable, to climb up on most, that same gear ratio will make the descent a hellish experience.[/B]
3 gears, but no freewheel. Take the edge of both climbs and descents while retaining that degree of control you're after.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Have you looked at the Sturmey-Archer fixed 3-speed? https://www.sturmey-archer.com/produc.../id/47/specs/1
No market for it.
On a cross-country ride a young man from NY rode a fixed gear. We figured on a steep downhill he hit 44 mph spinning at 205rpm.
The flip flop hubs allow for two cogs or a freewheel on one side.
Such a thing used to exist, the FixFree Drive from Britain locked up standard freewheels. Made in the 1980s, it wasn't very popular. https://www.flickr.com/photos/78587521@N00/2909441848
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
https://www.wired.com/gadgetlab/2010/...-with-a-twist/
You still have to dismount, but it's a push and a twist. No screwdrivers or special tools involved. Except it's selling for like 200+ on Ben's Cycles.
