Huffy AeroWind Rat Rod
Bikes: Yes
Quoted: 3300 Post(s)
Liked 4,084 Times
I'm starting this thread as a declaration of intent -- something to hold me accountable and get this project moving.
Some years ago - never mind how long precisely - having too much money in my purse, and nothing particular to interest me in the garage, I thought I would buy a Huffy AeroWind frameset that I came across on Craigslist.
This was before the days of the glorious Huffente and I'm not even sure what my original intentions were, but I soon decided that I would try to build it up with good components, the sort of components that I would use on a nicer frame. Then the Huffente happened, and I thought do myself, "Well, dang. I can't compete with that." And so the project got shelved.
But I didn't actually put the thing away. (Anyone who has seen my garage will have guessed that much ) It sat out beside a bookcase in the garage where I'd see it regularly and think "I should do something with that." Over time something like a plan has emerged.
I intend to build it as described above with good parts. I'm a resto-mod kind of guy, so they won't be period correct. I'm thinking Shimano 10-speed, probably a mix of 105 and Tiagra, because that's what I have on hand. The focus will be on functionality with nothing done for aesthetics. I don't intend to go out of my way to make it ugly, but it will be. Mismatched colors, silver and black components intermingling, a threadless stem adapter, whatever it takes. But I will be pursuing comfort and functionality to the full extent that the frame's dimensions allow.
...in which Doris gets her oats
I kicked it off yesterday by removing the bottom bracket and headset. No pictures today, but many things were learned.
I was pleasantly surprised that the bottom bracket came out without a fight. There was some sort of locknut arrangement holding the spindle in place. I didn't have a thin enough wrench to hold the inner flats while loosening the locknut, but amazingly I was able to get it off just by holding the splines of the spindle with a pair of pliers. With the spindle removed, a few taps on a screwdriver knocked out the cups. I've got an adapter on hand that will let me install a BSA threaded bottom bracket. I'm leaning towards an FSA Gossamer triple with external bearing bottom bracket.
The headset was a different matter. It had an aluminum locknut that was pretty stuck. I used my biggest adjustable wrench and held a wheel for leverage but it wouldn't budge. So I soaked it with penetrating oil and waited. A few hours later, I got it to move. Unless my eyes are deceiving me, I ovalized the locknut in the process, but it came off.
That left a knurled top race. I couldn't find my vice grips and pliers didn't provide sufficient leverage, but it was late and I wasn't going to sleep without seeing the thing done. I ended up using a long woodworking clamp to hold the race while I rotated the fork to unthread it Success.
Here's where it gets interesting. First, the top cup came out with the race. I guess the clamp was holding it too and it wasn't seated very tightly. The head tube measures 33 mm (not 32.6 mind you 33). What's really curious is the steerer. It has no raised edge for the crown race. The crown race was just sitting there loose with a fair bit of play. @AdventureManCO, do you know if that's normal for Huffy?
At this point I'm thinking I'll try to salvage the original headset. If I can shim the race into place, clean up the bearings, salvage the locknut and get the thing to turn smoothly, I'll call it a win. If not, I'll be looking for some other solution.
More to follow as it happens....
My Bikes
My Bikes
Bikes: Yes
Liked 4,084 Times
And, of course this is required for any Huffy AeroWind thread
My Bikes
My Bikes
Likes For Andy_K:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4719 Post(s)
Liked 5,980 Times
Bad example
Quoted: 899 Post(s)
Liked 426 Times
An excellent start. Following with interest!
Quoted: 1649 Post(s)
Liked 1,872 Times
You better measure the bottom bracket ID too. It looks kind of strangely oversized like the head tube.
Quoted: 179 Post(s)
Liked 337 Times
”Available at Toys R Us.”
That says it all.
There’s one on CL here for $35 but I’m not tempted. Let me know if you need any parts from it.
That says it all.
72+76 Super Course, 74 P-10+ 79 Tandem Paramounts, 84 Raleigh Alyeska, 84 Voyageur SP, 85 Miyata Sport 10 mixte and a queue
Likes For Schreck83:
Edumacator
Quoted: 2544 Post(s)
Liked 3,369 Times
Whoop whoop! Another horror thread has come! Awesome!!!!
I think Dura Ace AX, modified through trickery to support a 130 spaced, 10 speed Spynergy 4 spoke wheel, with Winspace integrated aero carbon bar-stem! It should be pretty cheap...
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 709 Times
Since it’s only a frame, it must not have come with the Huffy aero brake calipers. I would assume that you would spring for the Campy ones that are similar looking.
Quoted: 3855 Post(s)
Liked 6,976 Times
Once built, you definitely need to re-enact that promo video, Andy. Where might that bridge be?
Likes For nlerner:
Edumacator
Liked 3,369 Times
Probably collapsed from the weight of the Huffy after the shoot.
Likes For jdawginsc:
Bikes: Yes
Liked 4,084 Times
Yeah, it's a BMX size, 50.8mm. Fortunately, I was able to find an adapter on the cheap.
My Bikes
My Bikes
Bikes: Yes
Liked 4,084 Times
Nah. I'm ignoring their attempts at aero. Not looking for anything fancy in the components, just functional.
My Bikes
My Bikes
Bikes: too many
Quoted: 417 Post(s)
Liked 249 Times
Let us know how it goes.
Likes For uncle uncle:
Edumacator
Liked 3,369 Times
Yeah, I don’t blame you. I was just kidding in an AMCO sort of way!
aka: Dr. Cannondale
Quoted: 2175 Post(s)
Liked 3,535 Times
I think you’ve found the ‘Ultimate Riding Experience’.
Likes For rccardr:
Quoted: 823 Post(s)
Liked 1,056 Times
Wait..... that was intended to be a snide remark, but it actually could make this Aerowind a better riding and less cumbersome bike. And solve the sloppy crown race issue.
Likes For Velo Mule:
Bikes: Yes
Liked 4,084 Times
Likes For Andy_K:
Liked 5,980 Times
I think @gugie knows where it is. Somewhere in California. Probably on the Tourica route.
Bixby Bridge, Big Sur Many a commercial filmed on it
Likes For gugie:
Bikes: Yes
Liked 4,084 Times
The Depoe Bay Bridge in Oregon might be a serviceable fill-in.
My Bikes
My Bikes
Likes For Andy_K:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1332 Post(s)
Liked 3,805 Times
I can't answer any important questions just yet. I'm too busy crying tears of joy.
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
Bikes: Yes
Liked 4,084 Times
I got a little bit of work done on the headset tonight, and now I have pictures to share. Let me start with the visual reference of what I'm working with.
Following the classic rat rod tradition, I don't intend to do anything about the rust, apart from scraping it away from the threads. I guarantee it will not cause structural damage within the expected service life of this bike. On close inspection, there may be a slight taper at the bottom of the steerer, but that may just be deformation. The crown race itself has a lot of internal taper. It's downright conical. I honestly have no idea what the design is here. The good new is that the chrome is in great shape!
Does this look round to you? The threaded parts came unscrewed so it must not be too far off, but it looks kind of ovoid to me.
A test fit with the stem adapter seems to confirm, but I've definitely seen worse.
The pieces of the headset cleaned up reasonably well. As is typical for a bike that has seen more neglect than abuse, there's no pitting or other serious damage.
The fork ends have the usual 95-ish mm spacing. The good news is this gives me motivation to break out my fork tools.
No, no, no. This will not do.
Better? You'll never see an AeroWind with better alignment, and I don't mean that in a good way.
(I probably should have prefaced this with a trigger warning for any OCD readers.)
In case you are concerned that I'm not treating this project with the dignity it deserves, let me put your mind at ease by showing you the precision shim I used for the crown race.
With everything cleaned and greased, I was ready to put it back together. Unfortunately, my woodworking vise wasn't strong enough to get the top race back on.
I'm going to need to find the vice grips before I can go any further. I can't imagine how they would get lost in my garage.
My Bikes
My Bikes
Likes For Andy_K:
Bikes: Yes
Liked 4,084 Times
Found 'em! They were put away in a logical place, which accounts for the difficulty locating them. This is why I leave things out.
There's a bit of a gap between the upper cup and its race, but if I tighten it down any more it starts binding, so I guess this is the way it's meant to be. I triple checked that I didn't have either set of bearings in upside down.
The top race was a struggle through every single turn. It felt like I was cutting new threads as I went, and maybe I was. I'm very confident it will hold its adjustment. The lock nut went on without a problem. The damage you see to the lock nut is from the removal process.
My Bikes
My Bikes
Likes For Andy_K:
Edumacator
Liked 3,369 Times
Second, is my guess is that the ovalization of the steering tube was a purposeful attempt to properly misalign the headset at the factory...
When a SN is that long, quality control is not considered...
Likes For thinktubes:
Bikes: Yes
Liked 4,084 Times
It’s important to have the right tools available when you need them. Sadly, this one doesn’t even work correctly. The lava sticks to the side. It was my daughter’s and I took it into the garage to see if I could fix it. I couldn’t and just haven’t bothered to dispose it. I guess I’m waiting for Ridwell to make lava lamps their category of the month.
My Bikes
My Bikes
Likes For Andy_K:
