Power Meter is way off
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 928 Times
Up until today's ride the PM on my new Canyon Endurace (4iiii) has been reporting power that is inline with what I was seeing with my previous Endurace with the same model PM. Today, on a more casual ride with a friend my watts were showing as 40 points higher than normal. My Garmin recorded today as the best PM Curve I've ever had. I was not pushing it at all and something is really off. When I got home I recalibrated the PM and went for a quick trip up and down the block and it was still reporting back way too high. My HR, Cadence and Speed confirm that today was nothing out of the ordinary. Since this bike is new with only about 350 miles on it I'd like to find out if this is something that others have experienced and if I should remove the crankarm and possibly request an RMA?
Quoted: 6199 Post(s)
Liked 4,816 Times
If you bought it with the 4iii from Canyon, I'd ask them what they think you need to do to. If you bought the PM from 4iii, then ask them. They usually answer my questions. Sometimes takes them awhile to respond though.
Not a case of your friend not pulling their fair share during the ride is it? Bikes are pretty much the same weight?
Liked 928 Times
I've got an email out to 4iiii customer service and see what they say. I wasn't sure if this was the correct forum for it but since most people who "train" frequent this area I thought someone might have seen this before. There seems to be a lot of Band-Aid solutions that work, but in their FAQ section they say if you're seeing really big jumps to contact them. My NP (and everything else) went up a little over 40 watts compared to the previous days hard ride and that was just not right. I have all the other metrics i.e. HR, cadence and speed to show that it wasn't the effort the PM is showing.
Quoted: 4421 Post(s)
Liked 4,874 Times
Yeah it sounds odd. One thing I would try is a fresh battery. I have had mine give odd power readings on a low battery and it was pretty sudden.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
I'm not disputing that the pm may be at fault, but none of these are as consistent or reliable as power. HR variability from day to day can be quite large - hydration, rest state, nutrition, etc. (caffeine?), all cause significant day to day changes. speed depends on terrain, wind, drafting, and more. Cadence is not much help unless you are also recording the corresponding gear ratios.
Liked 4,874 Times
Liked 928 Times
I was also concerned (as mentioned above) that temps and other variables may be causing these results. The good news is that 4iiii in Canada, after looking at the additional metrics I sent them along with the wattage results are giving me an RMA opportunity so that they can further examine and test the unit.
"Unfortunately, this unit cannot be diagnosed further by our customer service team. Your crank will need to be returned to our HQ factory in Canada to be repaired. Please complete the Return Merchandise Authorization (RMA) form attached to this link:"
They are covering all costs. My only regret is that I won't have a bike to ride for probably at least 2 weeks. I'm going on a ride tomorrow and I will test the unit one more time before sending it back. I'll also have to find another NDS crank arm. I'd hate to lose 2 weeks or riding.
Liked 4,816 Times
I currently run a 105 5800 drive side crank/spider with Ultegra R8000 rings and left side crank. The profile of the rings doesn't match the spider. But if you can tell that as you ride next to me, then you have much better eyes than I do. And are looking where you shouldn't be. Eyes on the road!
Liked 928 Times
As a follow up... I decided to run the PM on several more rides and it seems to have settled back to normal after that 1 day anomaly. Ever since then I'm getting results where I would expect them to be. Because of that I wrote 4iiii and let them know I wouldn't be sending it back. Everything looks good for now. I've been on 6 more rides since then and things are fine.
