Chain + sand
Bikes: 2004 ORYX SPITFIRE 33
Chain + sand
My bike has a minor roughness feeling while pedaling in some gears. Anyway I have had the entire bike tuned up including the BB bearing checked, everything producing positive results. My shop said the apparent cause of the roughness is sand pebbles or fine grit caught in the chain and that it should decrease or completely go away after a few rides. I have had a number of bikes and have never came across a problem like this. Just wondering if anyone else has ever had something like this happen?
Anyhelp is good thanks
Dismember
Bikes: Kona Kikapu/hoss deluxe mix, 1950's Malvern Star gent 28" turned into a stealth commuter with drums and a three speed.
First, sack your bikeshop. "it should decrease or completely go away after a few rides" is not a maintenance schedule of any description. Second remove the chain, soak it in kerosene or similar, next lubricate the now clean chain with your choice of lubricant.
Edit: Forgot to mention I ride in sand all the time.
Mmmmm...shiney new parts...mmmm
Just biking along....
Bikes: Scott Scale Ltd custom build.
I've had this problem before. I agree with your bikeshop's diagnosis but not their cure. As Harov said, just clean the chain and re-lube. Maybe also worthwhile to check that your BB area is clean.
Rouleur
If I took my chain off and soaked it everytime it got sand in it I would be broke from buying stupid chain pins.
Keeping it clean is the best solution but I think anyone who rides trails is going to get fine grit in their chain and never get it all out.
i use finish line teflon lube after every ride. and it works ok. i ride in all diffirent kinds of sand everyride.
but if it is really gritty, i would clean it up and re-lube it.
BUT can you feel that its caught up in your gears?
Rouleur
Yeah, I'm not sure how you could be getting roughness in some gears, If there is dirt on a cog its going ot be picked up and distributed amoung all the cogs in your cassette. The roughness is comming from your chain. Your shop is probably right, as your ride the small bits of sand and dirt will be ground up into finer and finer particles eventually becoming so fine that you don't feel it. Of course if you regularly trail ride the sand will be replaced while this happens so it will always be rough.
I just cleaned my chain with my park snap on chain cleaner. If was rough from my last ride, the chain cleaner got alot of the dirt out but even afterward it was still a little rough. After relubbing it felt pretty smooth but nowhere near as my road bike.
I wouldn't bother with this after every ride but cleaning your chain regularly will make it last way longer and feel smoother.
Ok, yeah its just I really havent been riding in much sand ETC and have never had this happen with any of my other bikes. I was thinking maby something has some damage and thats why it only does it in certain gears?
fitter, happier
Bikes: I have more bikes than fingers. So I can't count em
I ride in sand also. Clean,clean,clean..... and plan on replacing chains as needed.you know I never feel the sand at all. It just causes lot's of extra wear.You might have something else going on.
Bikes: Giant Yukon
IMO, If you had the bike "tuned" by guys who said what they say, about taking two aspros and it will
go away, I wonder about the tuneup.
Sand will grate. IME you hear it as much as feel it. It will also grate in any gear. I very much doubt it
would be feelable while pedalling until it was really serious...I mean really!
Bearings/brackets/pedals would grate in any gear.
Chain path is quite a "rumble", and will actually vibrate the chain under light loads (bike on stand and
pedalling lightly by hand) and can be worse in some gears than others.
If the chain is vibrating in some gears (mine did it more noticeably on the smaller back cogs) it
sounds like:
* derailer alignment
- the derailer is not _quite_ "ghost" changing gears for you, but is constantly pushing the chain a
bit.
- this can cause a "grating", "grinding" _or_ vibration under heavy loads, as flex of the bike can
make it worse, especially if the pressure is on the way down to smaller cogs. Just a little more, and every time you pedal hard the bike will partially "shift up a gear" on you.
- the chain path at the rear should be as close as possible to straight, across the chosen
sprocket, and the two derailer sprockets/idlers. Look down on the bike, and line them up so you see
if it's straight.
- IME, this will get worse as you go to the smaller cogs, as the derailer sprocket gets closer to
the rear cogs as the chain slackens, and the chain also attacks the sprocket at a sharper angle.
* technique
It may be "crossing up" of the chain. With a triple chain ring you should not really ride with the front
set to the large chainring, and the rear on the largest 1 (7 speed?) or 2 (8 speed?), or the front on
small ring and the rear on the smallest 1 or 2. This causes the chain to have to grind against the
sides of the sprockets, because it crosses the full width of the two sets as it travels along its length.
Place the front in lowest gear (smallest) and then place the back in highest (smallest) then look at
the chain.
Hope this helps.
BTW, soaking the chain won't affect any particulate matter in the chain. It will just break down the grease. In order to get that stuff out, you have to flush fluids through it.
I use isopropyl alcohol with a chain tool. It's cheap, it's mild (so it does NOT break down perfectly good lube (I use extreme purple)) and it flushes water out which protects the chain from rust.
Finally you can get a SRAM Powerlink or Connex Link to thwart Shimano at their money extorting racket (replacement pins).
Bikes: Giant Yukon
All my rides (about 6-years worth), save for about 6-weeks in the mountains each year, are on sand covered hardpack. I never have this problem in the gear train, much less in the chain. The chain tolerances look too small to allow grains of sand to get into the works IMO. I use White Lightening and have for about 5 years.
If it was me, I'd throw away the chain, use SRAM or the German Stainless chain and check all the cogs/rings for wear. I've been using that Stainless Steel chain for bout a month now. Really nice. It seems more rugged than the SRAM and now I don't have to worry about water crossings and rain.
Al
Al
first thing
1. get a SRAM "powerlink" so you can take your chain off in a snap
2. get a pop bottle and a little degreaser
3. put chain and a little degreaser in bottle and shake vigorously
4. take chain out wash off with water and let dry
5. put chain on bike... oil it with tri flow (or whatever) let dry over night
6. go ride... after spray it with GT 85 (which is a degreaser and lubricant with teflon) let sit for a few... then wipe the chain, pulleys, and cassette off really good. its a quick and easy cleanup
7. after a few time with the quick clean up, start form step 3
hope this helps
I live in the Adirondacks and there is sand all over the place for some reason
hope this helps
Journey Man
Bikes: S Works M2
Agree with most of the responses on here r.e cleaning it and not leaving it to "go away". I got caught in a sand storm about 3 weeks ago as I cycle along the beach road here. My chain went from slick to gritty and crunchy in seconds. Got the bike home, first wiped the excess oil from it (which could have been part of the problem as it was a wet lube and not a dry one), flushed it through with WD40, dried it again and then lubed it.
It still took another 2 rides for it to go and I will likely replace it soon to be on the safe side. Also thoroughly clean the cassette and jockey wheels.
HTH
HTH
HTH
HTH
Al
I used chain wax for my dirtbikes and could not ask for a better product, never had any problems. I should have used it for my MB from day 1.
Thanks
Thanks
Bikes: 1980s 15 speed road bike, and 21 speed, Iron Horse Outlaw mountain bike and 24 speed Felt F90 road bike
You know you can just remove the guide wheel on the rear derailuer and you can remove the chain off the bike. No chain breaking at all.
