Cassette switch, trainer headache
Old 07-23-18, 11:15 AM
The next level
Quoted: 24 Post(s)
Hello,
i could use some help to reduce frustration. I have a 2017 diverge and trying to mount to a trainer. Picked up a cassette to mount to the cyclops hammer. First I noticed that my drop out width doesn't match the bushings. My axle isn't long enough to catch threads. Called cyclops support they said use a longer axle. Ok grabbed one off my mtb. Little apprehensive about spreading frame a bit for that. Next the cassette I grabbed is 11-28 not 11-32. Is this a chain compatibility issue? It isn't as smooth and I can't get to the 28t with the derailer in prior adjustment. Any guidance would be appreciated. I only have one good arm at the moment hence the trainer....
The next level is offline
Old 07-24-18, 04:20 PM
The next level
Quoted: 24 Post(s)
Well learned alot about putting a diverge on the trainer. With 135mm thru axle obstacles......
Jesse101
Road Cycling
1
03-19-19 07:17 AM
mrje1
General Cycling Discussion
8
12-15-18 08:47 PM
Noonievut
Bicycle Mechanics
1
05-04-18 02:07 PM
ogcsmith
8
04-22-18 05:06 PM
cwcaesar
Training & Nutrition
2
09-14-12 08:19 AM
