Help in ID: Colnago or Fauxnago?
hi i need help in id or knowing if the bike is colnago or in any way linked to colnago or what bike is it The clover stamp can only be found on the lugs on the headtube going to the downtube. Nowhere else. There is a clover cutout on the bb shell but it also has tiny dots or holes forming a triangle maybe as the stem of the clover cutout? I cant upload any image since im still a new member. Sorry.
Id appreciate any insigjt ir help please, thank you
Half way there
Quoted: 989 Post(s)
Liked 884 Times
You will need 10 posts to enable posting of pictures. It looks like you only need 6 more so you are on the way. I'd like to see the pictures.
maybe this will do it
ibb.co/ZHC2LHS
ibb.co/HrcVCv9
ibb.co/jLkg0c0
ibb.co/NN1KsGM
ibb.co/hY6qxpG
ibb.co/x5FKzRn
ibb.co/ZHC2LHS
ibb.co/HrcVCv9
ibb.co/jLkg0c0
ibb.co/NN1KsGM
ibb.co/hY6qxpG
ibb.co/x5FKzRn
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
Here are your images...
...yes, those image links work. It does not look like any Colnago I've ever seen from the 70's or 80's. The fork crown looks like what shows up on a lot of French bikes. Otherwise, I can't help much.
Quoted: 3464 Post(s)
Liked 2,831 Times
Not a Colnago.
I owned a bike with an inverse "clover" not that brand either.
On the bottom bracket cups will be most often a thread type stamp. Report that and the seat post size if can be found.
Fork looks earlier, then drilled to accept the recessed nut.
Always a chance the fork and the frame were mated long after the two were built.
Quoted: 1641 Post(s)
Liked 831 Times
Fauxnago for sure!
The "clover" under the BB looks to have been done by some guy named Duffus Schmaltz.........in a van.....by the river.......next to the highschool........
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Half way there
Quoted: 989 Post(s)
Liked 884 Times
Nope, not a Colnago. Clues to identity may be hinted at by stampings on dropouts and BB shell dimensions and threadings. Seat post diameter may help, too.
Good luck.
Good luck.
Likes For Moe Zhoost:
LOL! i knew it from the start, im looking for clues what this frame could be. Anyway thank you so much
Not a Colnago.
1/2 as far in 2x the time
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
there has been some lug thinning, i can't tell if it's haphazard or consistent, probably due to the mess of paint. I particularly can't figure out what was done on the lower head tube lug. Maybe a frame-building class bike. Better photo of that lug cut out might help;
I seem to have lost what little mind I had left before this all started.
Seems like the tail of the clover is atrached to the clover
This bb shell is the biggest mystery to me
Here are some more pics 😊
Likes For NormanB:
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times
Thoughts on your frame.
It would explain the bottom bracket, and lug details. The builder was referencing a Colnago, not trying to truly make a "fake". I hope you are not disappointed, by my guess, I think you have something pretty unique on your hands. There may even be a way to trace it back to the builder. Take a look at my recent track bike thread regarding who may have built it. Someone may remember the guy who loved bikes.
Best regards, Eric
Likes For Last ride 76:
Norman, I just noticed that you are in Manila. (I can be somewhat slow at times.) Mostly locations don't affect things much. This time, I am going to venture it does. I said before I thought it looked possibly like "student" work. Now I'm going to guess, local enthusiast. Bet almost anything. The small size of the frame forces the head lugs to intersect. I have read professional frame builders, noting how difficult it is to make that conjunction smoothly, there are so many factors at play. The Philippines in general, and Manila specifically, has a very active and inventive welding industry, from Jeepneys to commercial and domestic custom fabrication, there is an abundance of skilled artisans who work with metal. I think this frame was the work of one such.
Best regards, Eric
Best regards, Eric
Likes For NormanB:
