Spring pin substitute for Shimano TL-ST03
Old bikes, Older guy
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 254 Post(s)
Liked 172 Times
I’ve seen references for using a spring or roll pin as a substitute for Shimano TL-ST03. Any special instructions?
Thanks & regards,
Van
Thanks & regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Quoted: 4233 Post(s)
Liked 3,951 Times
Van- Thank you for answering a question i've had for a long time but had done nothing to solve it, until it solved it's self. Back in the day Shimano included this tool with each road STI lever set. I must have tossed out dozens. Forward some years and those levers began to suffer from lube gmuitis. So we would pull the lever/pod unit and soak it in solvent. Reassembly was a real trick what with positioning that lever return spring just so while you slide the unit into the body in that off set way you have to. I "discovered" that a ball inflator needle fits over that spring's leg just right and makes the lever unit so easy to slip into place. It was only then that I realized that I tossed out a tool those years before. Andy
AndrewRStewart
AndrewRStewart
A roll pin works well for this. Get the smallest size that will fit over the spring end. If it's really short, get another pin about 2 size larger and insert the smaller into the larger to lengthen it. Hint, get more that one since it can go flying if it slips out while using and is easily lost .
A ball inflator needle also works but is less durable.
Tip: During install, start by inserting the lever axle partially into the bracket body so it's ready to pushed through when you get everything lined up. Do the side with the grub screw first since this will help the axle line up for the second side.
Liked 3,951 Times
AndrewRStewart
AndrewRStewart
Quoted: 254 Post(s)
Liked 172 Times
Thanks guys,
We’ve had freezing rain the last two nights with lots of trees down this am. Hardware store closed, no power. Trying to find a ball needle in my junk.
Cheers, Van
Cheers, Van
Really Old Senior Member
Just the correct amount to fill 1 yard cart after cutting it up with the chain saw.
I know that this is an old thread, but it helped me, so let me share my 2 cents: Torx T20 with a hole works as a charm, only two attempts were needed. It is also heavy enough that it simply falls when it slips.
