Bullseye Monster LTD brake setup
I just purchased this frame from bike island. Can anybody tell me what I need for size rotors for front and rear? Is there a hydraulic kit that I can buy to bolt on and go?
You can install whatever rotors you want. the rear may be limited in size depending on the frame. forks typically have a manufacturer limit. My recommendation is 203mm front and 180mm rear. note you need caliper adapters. Many bikes are made fro 160mm rotors and any larger rotor requires an adapter to bring the caliper out. 160mm rotors, are too small for serious off-roading, or any riding, unless you weigh 100 pounds and ride slowly.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Bikes Direct equipped them with 160mm rotors:
https://www.bikesdirect.com/products/...onster-ltd.htm
