Fuji America geometry changes over the years?
Quoted: 753 Post(s)
Liked 737 Times
Anyone know how how the Fuji America's geometry changed over the years? I'm trying to figure out how a pre braze on's 1978 America would compare to a 1980's fuji S12-s with braze on's. I'm primarily looking for relative fork rake and tire clearance. Thanks, Woody
Quoted: 753 Post(s)
Liked 737 Times
I found this info from I think 1981. which is when the braze ons appeared.
https://classicfuji.posthaven.com/fu...echnical-guide
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
I have a 76 or 77 America frame in the cave. Perhaps I can take it's measurements to give you a useful comparison.
Quoted: 753 Post(s)
Liked 737 Times
That would be great. Thank you.
Photographer
Quoted: 105 Post(s)
Liked 98 Times
Scott
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
Quoted: 753 Post(s)
Liked 737 Times
It took a little digging on your site. I wouldn't have found it if I had given up on the first dead link or the corrupted wayback machine snapshot of said dead link. I dont know if you can do "sticky's" on your blog but this is some great info. Thanks for hosting it.
The 1986 Touring Series V has the same geometry as the America and the S10S models listed above with one exception. Fork rake is 55mm. Chain stays and frame angles are the same. Looks as though they settled on a standard for touring frames and stuck with it.
Phyllo-buster
Liked 2,054 Times
So I don't have accurate means to measure angles so here's the approximate measurements for a 54 cm '76 America. Most numbers are similar except the chainstay length is longer. To me, that implies the angles have to be different since the dropout to dropout length (wheelbase) is the same. Perhaps a lower bottom bracket? Hope this helps.
Quoted: 753 Post(s)
Liked 737 Times
Thanks for taking these measurements. Unfortunately some one closer to the bike got there first.
