Imagining the evolution of discontinued product lines
Quoted: 378 Post(s)
Liked 1,409 Times
The Ironman was pretty much a train on / race on / century on bike. It was affordable, steel, and well balanced, with excellent quality across the spectrum of models. It was offered for 5 years.
The Ironman did not evolve with the times, but perhaps, if it did....it might be this:
Keeping the flame alive, Adam Eldridge of Stanridge speed decided to make a frame affordable, steel, and well balanced, with excellent quality across the spectrum of models. He's now in his 5th year, I think, with Wraith.
Quoted: 2338 Post(s)
Liked 2,822 Times
more like steampunk alternative gruppos
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
Delta disk brakes!
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Give it time. Time heals all perfection.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Quoted: 7348 Post(s)
Liked 2,463 Times
In my view, MAFAC went out of business because they didn't update their products frequently enough. People want new stuff, and it's necessary to grab their attention. The trouble is, bike brakes were pretty much perfect already, so MAFAC didn't see the need.
Quoted: 378 Post(s)
Liked 1,409 Times
I wish for the continued evolution of the down tube shifter.
Shimano has its pretty and efficient 6sp to 10sp Dura Ace. Would be nice to see 11 and the inevitable 12.
Campagnolo failed miserably in regards to indexing, but Bike Forums ingenuity has it working with converted bar ends, at least for 10sp; 11 and 12 should be possible.
What say you, Shimano? Campagnolo?
Quoted: 786 Post(s)
Liked 519 Times
I've wondered whether friction shifting would have persisted had Shimano perfected it's hyperglide cogs before they got into SIS. A 7s HG freewheel with Simplex or Doppler retrofriction DT shifters is pretty much unbeatable.
Quoted: 3241 Post(s)
Liked 2,512 Times
Not C & V related, but,........
Since we already have some wireless electronics on the bike...and we evidently have disc brakes that require very little physical pressure needed,....
Why can't the shifters and brake levers be eliminated completely? Replace them with handlebars embedded with sensory pads or something similar. Maybe a thumb pad for braking and a couple of finger pads for shifting? Maybe a strip that runs the entire length of the bar that controls both? Maybe a "smart" handlebar. The technology is there. It will come in the future.
Quoted: 1163 Post(s)
Liked 442 Times
+1 to that. Those of us in the "classic and vintage" category often times are rabid collectors. I know I am. But we're often damn good bike riders. Being a bit iconoclastic in our choices makes it kind of fun to make these subtle parts substitutions . We're mechanically inclined enough to know what it takes to execute/implement the build we're setting out to implement. I'm from the birth place of the Wright Brothers and their bike shop! We're innovators, its in our blood. Steam-punk, YES! If I could use more brass parts, titanium parts, brushed unpainted, stainless, chrome plated - all that stuff tastefully done but functional. We've seen it done and note its absence today. So we set out to set the record straight.
I'm just waiting to set my next wheel build into motion using Winner hubs. Not SunTour Winner but Winner (manufacturing?) from California. These odd needle bearing, zero backlash hubs have an 8 speed Dura Ace Uniglide freehub body. They are very high quality. The few reviews of these that I have seen on-line, are negative. They says they can't handle riding in the rain and that the clever zero backlash roller bearing freehub "pawl-less" design isn't durable. Odd thing is - I still want to try it out for myself. I'd love to order some Araya Super Aero polished aero profile rims from Japan to put an exclamation point on the wheel build.
Quoted: 378 Post(s)
Liked 1,409 Times
Since we already some wireless electronics on the bike...and we evidently have disc brakes that require very little physical pressure needed,....
But you are my friend and probably right.
Liked 2,463 Times
@seypat, how are you imagining the brake actuation? We need to modulate the brakes, so are you imagining finger pressure will indicate the amount of braking needed?
We already have electronic shifting, so is your proposal to have it accessible over a greater area of the bar?
Quoted: 18373 Post(s)
Liked 4,507 Times
In fact, in some senses, friction works better than indexed as one naturally selects the gear and adjusts as needed.
Liked 4,507 Times
Perhaps it would be worth sending them a note.
As mentioned below, I have have vintage 9-speed shifters in use on one bike. It seems like just about anywhere I throw the lever, I'm in gear. I'm quite pleased with the ease of use.
I've been also experimenting 11s using bar end shifters (+ M8000 RD). I had some cable pull issues with my Suntour shifters. So, I have been using a right Shimano really springy shifter. It does reasonably well, except it uses the full range of motion, and is too springy on the high end, and not springy enough on the low end.
Anyway, friction will work with the 11s. The MTB derailleurs take a little extra cable pull which may be a good thing, but is hard for some of the vintage levers.
Liked 2,512 Times
Liked 2,512 Times
For me, it would eliminate a lot of the enjoyment from the riding experience. It would not be something I would use. But, I think the industry is moving in that direction.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
There are lots of electronic controls and generally engineers have found that people need to have movement and feedback. A gas pedal in a car (like the ones lately blamed for unintentional acceleration) has both a spring and a friction assembly so it resists movement, emulating cable friction and throttle return spring and whatever a throttle body does on the inside. The first generation of fly by wire aircraft had basically feedback free joysticks with only spring action, so the airplane’s surfaces moved in response to how far the stick was pulled. The second generation used strain gauges on the stalk to sense input load and didn’t move at all. The current fancy version has force feedback.
Quoted: 378 Post(s)
Liked 1,409 Times
The "fly by wire" of birds like the F16 is, of course, now "old," but there are joysticks out there that don't actually move, instead responding to pressure, like any laptop mouse pad. I supposed this could be made to work. But heck, if going that far, just program a helmet with heads-up display and use a power meter/cadence sensor/biometrics to set automatic shift points and speed/altitude sensors to modulate braking.
All customized per the rider. Solving Pat's climbing issues.
But wait, since it can be optimized for one rider, it can be predicted for others, and tactically programmed in real time. Which is about where they are now, with Bluetooth shifting controlled by a pad in the team car, based on what software has predicted other riders are capable of doing. A lot of riders simply ride and do what is told via their earpieces. Perhaps they'll just be asked to pedal, and be considered an engine on a bike, to be controlled like any RC car.
Teams have a lot of statistical data on what other riders can do, analyzed vs. the data on what their riders can do, and orchestrated in the team car.
And a chimp wins the TdF. Beating other chimps.
Liked 2,512 Times
Liked 2,512 Times
Servo, and ABS, powered by the front wheel dyno?
The only thing that will solve my climbing issues would be an E-bike.
Liked 2,463 Times
But braking requires modulation of pressure. It's not an on-off function.
Liked 2,512 Times
https://www.theverge.com/2018/3/18/1...box-controller
https://medicalfuturist.com/the-tech...ure-of-surgery
Liked 2,512 Times
Speaking of discontinued/dying product lines, my opinion is that the industry will move back to 3 rings in front/less cogs in the back eventually. If, if, electronic shifting becomes good/fast enough where the system/computer takes over the shifting of the FD, then I think we will see 3 or 4 ring cranks with 6-9 cogs in back. If the rider is not shifting the FD anymore, why do they care how many gears are in each place? If there is no weight penalty, that is no longer an important issue. The industry could go back to a rear spacing in the 115/120 range and have plenty of future room for disc guards/ABS, etc, etc. The current rear spacing issues are holding back frame evolution now.
Quoted: 378 Post(s)
Liked 1,409 Times
CVT is now becoming fairly common for cars, after a lot of attempts, products, etc over the last 80 years.
Perhaps the synergy of all this technology, biometrics plus CVT, power meters, sensors, etc, will develop the automatic bike. You set your power/cadence, and ride. The bike shifts when it senses that changes need to happen.
I was once a guinea pig on a treadmill, in a human performance laboratory. After fairly controlled benchmarks were set (VO2), the computer was set to run me at 80% VO2 Max until I dropped. Not sure how that worked, but if I got into a groove, the computer both sped up and raised the treadmill, and if I had a problem, it lowered and slowed it down. It was perceptible, but hey, it was 1986. 30 years later, no doubt the same can be done with cycling, at a much more precise and consistent level.
