Shimano 6800 Ultegra Derailleur Pulley Bolt Set Query
Old 11-20-23, 11:27 AM
Natronious
Which pulley get the longer of the 2 bolts? I am thinking the guide pulley
Natronious is offline
Old 11-20-23, 02:19 PM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times in 534 Posts
test fit them.. find out in about 10 seconds or less!
maddog34 is offline
Likes For maddog34:
Old 11-21-23, 10:20 AM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
I thought this would be definitive, but not quite:
https://si.shimano.com/en/pdfs/ev/RD...6800-3608E.pdf
Unfortunately, it lists both bolts as #9, but bolts are of different length. They should've given the two bolts different numbers, as they are not the same part.
MudPie is offline
Old 11-21-23, 11:15 AM
smd4
Quoted: 3514 Post(s)
Liked 2,927 Times in 1,776 Posts
Why the need for two different bolt lengths?
smd4 is offline
Old 11-21-23, 01:46 PM
Natronious
incorrect
Likes For Natronious:
Old 11-21-23, 01:47 PM
Natronious
Larger bolt on bottom / tension pulley
Old 11-21-23, 01:55 PM
maddog34
maddog34's Avatar
incorrect
ahh... i was not considering your lack of mechanical prowess... my apologies.
Take it to a competent mechanic before you screw things up worse.
A Co-Op will help YOU reassemble it correctly, and not charge you a penny.
but donations are always welcome!
and next time you tear something apart, lay the parts out in the positions and order they came off the assembly.
i place the top roller/hardware at the left, bottom roller/hardware on the right.
maddog34 is offline
Old 11-25-23, 01:39 PM
Natronious
ahh...
Your attempt was at best pathetic ...I do though remain faithful that despite your apparent shortcomings at present that your future offers hope
Old 11-25-23, 02:16 PM
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times in 1,470 Posts
Enough with the insult trading. Since Natronious found the answer, tread closed.
StanSeven is offline
