Wheel seems off-center
I am not too sure if it was like this when I got it, but it seems weird. My rear tire has plenty of clearance from the chainstay on the drivetrain side, but on the disc side, there is very little. This becomes a pain when I'm in the mud. Could this be part of the bikes design, or does something smell odd about this? Could there be something wrong with the hub's alignment, or is it a bent frame? Can you fix a bent aluminum mountain bike frame?
I can't see whether or not the wheel is aligned with the seatstay. The toptube obstructs my view.
Quoted: 1572 Post(s)
Liked 643 Times
My bet is that your rear wheel's "dish" is off. A quick, dirty way to check is reinstall your wheel in the frame backward. If the clearance is now on the non-drive side you need to have your wheel's dish corrected.
Really Old Senior Member
If the QR isn't tight enough, you can "pull" that side forward under hard pedaling.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
The surly karate monkey is that way.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
Well, I flipped the wheel, and when I do, it is almost centered (there is still a bit less on the left chainstay, where the disc would have been.
So... bent frame AND unaligned wheelset? I think I might just take it in to the shop and have them set up the wheel so the clearance centers.
Bikes: k2 Zed 3.0
I was going to post a similar thread; but I think I have the same issue. If I look down the back of my bike, and the rear wheel is 1/4" off center from the top tube. I'm 100% sure it's not a bent frame, because the wheel is on there perfectly (parallel to the frame), it's just 'pushed' to one side. The interesting thing is that I'm also 80% sure (still need to double check) that the wheel fits perfectly on my other frame.
