what exactly is "too tight"
Old 05-27-08, 05:21 PM
chevahh
Let's keep it in Zone 2
chevahh's Avatar
Bikes: Bosberg 3.0
I think my chain is pretty snug (how I like it because I do track stands a lot and I had a semi-loose chain once and it was a lot harder to do), but I've been reading around and having a chain that's too tight isn't good. Here's a picture...can you guys tell me if that's too tight? thanks for the help
File Type: jpg
chevahh is offline
Old 05-27-08, 05:23 PM
cc700
Ths Hipstr Kills Masheenz
cc700's Avatar
Bikes: tirove
Liked 3 Times in 3 Posts
yes, i can't see any slack.
you're just looking at increased wear and decreased efficiency. if you don't mind chains snapping on you while bombing hills you'll be fine.
btw a nicely tensioned chain isn't that much harder to trackstand with, you just have to have good balance and smooth crank pressure.
cc700 is offline
chevahh
chevahh's Avatar
Bikes: Bosberg 3.0
gotcha. so too tight = not good = my chain.
chevahh is offline
Old 05-27-08, 05:24 PM
Ride Among Us
Don't Hate.
Ride Among Us's Avatar
that looks way too tight - i bet its loud. i keep mine so that it moves up and down 1/2 inch when you tug at it.
Ride Among Us is offline
Old 05-27-08, 05:56 PM
bryanhayn
^posier than thou
bryanhayn's Avatar
Bikes: black 62cm IRO Angus w/Fusions on Phil hubs, Sugino 75 cranks, Soma track drops
https://www.urbanvelo.org/issue3/urbanvelo3_p64-65.html
bryanhayn is offline
Old 05-27-08, 06:01 PM
johnnytheboy
johnnytheboy's Avatar
Quoted: 443 Post(s)
Liked 12 Times in 7 Posts
johnnytheboy is offline
Old 05-27-08, 06:39 PM
NewYorkMantle
NewYorkMantle's Avatar
yeah, i usually tension for minimal play on the tight spot; translating to around 1/2 inch of play on the rest of the ring.
NewYorkMantle is offline
Old 05-27-08, 06:43 PM
sivat
Geek Extraordinaire
sivat's Avatar
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
Spin the wheel while holding it off the ground. You should get bored before the wheel stops spinning. If the wheel slows down after a few turns, the chain is probably too tight.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
sivat is offline
Old 05-27-08, 06:56 PM
ralphm2k
Lamb of God
Flip the bike upside down, spin the tire slowly (watch the fingers),if it slows the wheel, it's too tight, if you can push the chain sideways and have it run off the chainring it's too loose. Anything in-between is preference.
I like a little click when the chain engages.
Your chain looks wicked tight btw.
ralphm2k is offline
Old 05-27-08, 07:50 PM
mikesbikester
Bikes: one road bike, one cruiser, one fisher mtb, one track bike, one shogun mtb with studded tires for the winter
watch the tight and loose spots. spin the cranks slowly and make sure its not binding at any point of the cranks rotation
please watch your fingers
mikesbikester is offline
Old 05-27-08, 08:16 PM
RichPugh
Nymphomaniactionhero
RichPugh's Avatar
Bikes: 07' Specialized Langster Comp, 04' Bianchi Pista Concept
Liked 6 Times in 4 Posts
Skip and Skid more... it'll loosen up LOL.
RichPugh is offline
Old 05-27-08, 09:46 PM
ryansexton
ALL PARTY
ryansexton's Avatar
Bikes: Douglas Touring Cross Wise, Urbanite Fixed Gear
Is it like a 5 man job to get it that tight?
ryansexton is offline
Old 05-27-08, 09:52 PM
onetwentyeight
blah
onetwentyeight's Avatar
Liked 5 Times in 3 Posts
half and inch of up and down play is my ideal. too tight and it binds, slowing you down, and causing stretch in the chain, and wear in the cog and chainring. to quote juvi, "once you go slack, you never go back." if you cant trackstand with a little play in your drive, you arent very good at trackstanding. i cannot tell you if your chain is too tight from a photo, as i need to feel it, and also the stock IRO chainrings are generally a bit out of round, so there will be tight and loose spots in your crank rotation.
onetwentyeight is offline
Old 05-28-08, 12:31 AM
chevahh
chevahh's Avatar
Bikes: Bosberg 3.0
um. apparently you don't know how to tighten chains
chevahh is offline
Old 05-28-08, 12:59 AM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
It looks like it's set up too tightly... there should be a little sag.
Sixty Fiver is offline
Old 05-28-08, 09:11 PM
wheelsucker
SiteMod
wheelsucker's Avatar
Bikes: Mark V,DeBernardi
Originally Posted by thehappyrobot
OMG that is a camaletoe!
wheelsucker is offline
Old 05-28-08, 09:14 PM
str8flexed
actually, you just looked at valley formed by his two nuts.
str8flexed is offline
Old 05-29-08, 04:54 AM
idiq
IRL Banhammer
idiq's Avatar
Too loose:
If you have the bike in a workstand (or upside down) spin the crank with one hand, and try to pull the chain away from the bike about ~6 inches from the chainring as it comes forward (watch your fingers). If the chain comes off, it's too loose.
Too tight:
If you ride and your frame creaks it's too tight. If you use chain tensioners, I see this a lot. Most people with tensioners just crank them all the way back and the chain ends up 'too tight' - this is probably what whoever you were talking to was referring to.
If you actually tension your chain correctly, then it will not be "too tight". By correctly I mean: Slide non-drive side back as far as it will go, tighten down. Pull wheel toward drive side, which will let the drive side of the axle slide back. Tighten down, then release. The wheel should be in the middle. If it's not, loosen the non-drive side and adjust. If it is, just crank the bolts down.
saddle sores bike club | prepare to be rode
idiq is offline
Old 05-29-08, 07:36 AM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
I believe that is called a ************.
Old 05-29-08, 07:38 AM
the_don
the_don's Avatar
Quoted: 7 Post(s)
My drivetrain makes an intermittent creaking sound(well, most of the time), when riding, nothing when on a stand.
I have been to 2 bike stores asking about it and 1 guy said that the chainring was slightly imperfect, meaning that it gets a little tighter on one part of the revolution, I asked about changing it, but he said that was not necessary, and that it was fine. The other bike shop dude said the tension seemed perfect to him also and that there is no problem.
I am running SS, not fixed, so I thought that maybe it had something to do with the freehub (although i have never heard a freehub making those sounds before on a MTB).
Should I try slackening it off a little?
the_don is offline
Old 05-29-08, 08:08 AM
jpdesjar
Guest
Posts: n/a
Quoted: Post(s)
It might not be your chain tension it could be your chainring bolts, from what I have learned chainrings are supposed to be a little irregular, I could be wrong, I know on my fixed gear there is a point where the chain is slightly tighter when I rotate the pedals.
When do you hear the creaking, is it on the downstroke?
Old 05-29-08, 08:11 AM
the_don
the_don's Avatar
Quoted: 7 Post(s)
not so predictable, I have tried reading a few related threads and saw the chain bolt thing, but they are tight, so no worries there.
How much play should it have, I want to see if at the tightest point, it has enough, perhaps it is just slightly too tight at that point.
the_don is offline
Old 05-29-08, 08:22 AM
Rick@OCRR
www.ocrebels.com
Rick@OCRR's Avatar
Bikes: Several bikes, Road, Mountain, Commute, etc.
Quoted: 83 Post(s)
Liked 5 Times in 2 Posts
I just converted my single-speed to fixed gear yesterday, and from what I'm reading above, my chain is too tight. It was making a metallic rattle noise as I rode, so I will loosen it up this evening!
Thanks for all the posts with such excellent information!
Rick / OCRR
Rick@OCRR is offline
Old 05-29-08, 08:32 AM
idiq
IRL Banhammer
idiq's Avatar
'Play' is relative, even my chain I can squeeze down. If you tension it correctly [see earlier post] you'll be fine. If you use chain tensioners, take them off, re-tension on your own, and see what happens.
idiq is offline
Old 05-29-08, 08:44 AM
andrewssohip
FREE SSFG
Bikes: IRO Angus, 46/18, promax sb to deep v
it probably is not your drivetrain making the creaking sound, but if it is, it is likely that your chainring bolts aren't tightened down correctly. Not a very big deal, at all. Also chainrings aren't "supposed" to be a little out of round. It's just an issue that shoes up in cheaper chainrings, the more expensive you get the less out of round it's going to be, but no chainrings are perfect. (like a rocket ring versus a sugino 75 ring). The test I always use is flipping the bike over, or putting it on a stand and spinning it, it should spin smooth and for more than a few rotations. As has already been said in this thread, the only thing you have to worry about is just making sure you won't throw it. The looser the chain the faster you are (to a point).
andrewssohip is offline
