Heart rate training plans
Quoted: 28 Post(s)
If I do some sort of cardio every day what should my split look like?
Like Sunday would be active rest at zone 1 then Monday at 2 then Tuesday at 4 then weds 3 then Thur and fri would be 1 or 2 respectively and sat would be a long miles 3 day with some short hard efforts (like 4-5 efforts over the course of the hour)
Jedi Master
Check out these British Cycling Training Plans. I believe they are all heart rate based plans.
Quoted: 18883 Post(s)
Liked 10,646 Times
Jedi Master
I've been goofing around with heart rate training this winter with my fixed-gear on rollers for the past month or so. I have one of those old fashioned monitors (two fingers on the carotid artery) so I came up with this little cheat-sheet. BPQM stands for Beats Per Quarter Minute. Every few minutes I check my pulse for 15 seconds to see what zone I'm in. I'm going to try to calibrate it over the winter to see how accurate it is. I did a threshold test using the same approach, so I'm sure it's not super accurate to begin with. Curious if people with actual heart rate training experience think this seems about right or is seriously flawed in some way. I'm not planning to get a real heart rate monitor, I'm just doing it to make riding rollers slightly less monotonous.
just another gosling
Quoted: 3895 Post(s)
Liked 1,944 Times
Zone 1: sweating begins. Breathing is deep but easy.
Zone 2: Anywhere between Zone 1 and the point at which the rate of deep breathing begins to increase rapidly.
Zone 4: Deep, rapid breathing is necessary. Stressful.
Zone 3: Between Zones 2 and 4. Can keep this up for an hour or more.
Zone 5: Uncontrollable panting. 8-10 minutes is the absolute limit.
Results matter
Results matter
Liked 1,944 Times
The OP's plan is a decent starting point, but more complicated plans work better. Depends on current status, goals, timing, etc., etc.
Results matter
Results matter
Jedi Master
Whatever you tried to do, it didn't work. IME if you don't have a real HRM, you're better off estimating zone by your breathing than any other measure. With a HRM, once you figure out your zone limits, 2 beats one way or the other can make a difference in effect. You'd be better off paying attention to what you're doing than to your carotid. The nice thing about a HRM or PM is that you can see in a split-second glance where you are along the continuum without interrupting your concentration on the work.....
I took the first three columns are directly from training peaks with a threshold of 175 BPM. That may or may not be my real threshold, but it's probably in the ballpark. Assuming training peaks has the zones right, those columns are right. Beats Per Quarter Minute are just the training peaks Beats Per Minute divided by 4, so I'm pretty sure there's nothing wrong with the first 6 columns of the table. In column 7, I tried to estimate the speed at which I'm in that zone, which I think may be pretty close based on your breathing descriptions. Column 8 is cadence which again is just math based on the speed and the gear I'm running.
So here are my speed estimates based on your breathing descriptions:
15 mph - Zone 1: sweating begins. Breathing is deep but easy.
17 mph - Zone 2: Anywhere between Zone 1 and the point at which the rate of deep breathing begins to increase rapidly.
21 mph - Zone 4: Deep, rapid breathing is necessary. Stressful.
19 mph - Zone 3: Between Zones 2 and 4. Can keep this up for an hour or more.
25 mph - Zone 5: Uncontrollable panting. 8-10 minutes is the absolute limit.
I may be one mph low across the board, but this still seems pretty close to me. I already have a zone training program from British Cycling that seems pretty good so I don't need any help with that. I have all winter to calibrate the estimates. It's 1F in Chicago right now, which is close enough to my 0F cutoff that I'm riding the rollers this morning instead of going outside.
Liked 1,944 Times
As always, I really appreciate your insights, but you may be dismissing the table too quickly. The MPH column is the only column in the table that isn't either taken from someplace else or a calculation based on that. The point of estimating the speeds for each zone is so that I don't have to actually measure my heart rate, which by the way is not terribly difficult to do with my method when I'm just riding rollers. Based on the math, 2-3 beats-per-quarter-minute (8-12 beats per minute) is actually all that separates the zones.
Results matter
Results matter
Jedi Master
I rode for 1:45 on the rollers this morning. I was planning to ride for 2:30 but gave up with 45 minutes to go. It's just so uncomfortable not to be able to move around or really get out of the saddle. Anyway, most of the ride was Zone 2 with a few Zone 5 efforts. While I didn't attempt to check my pulse during a Zone 5 effort. I spent most of the time around 17 mph and my HR was consistently at about 38-39 BPQM (152-156 BPM), so I feel pretty good about my calibration of roller speed - HR for Zone 2.
Liked 1,944 Times
Hmmmm. This happened before when Google photos changed the way they manage permissions. I'll look into it. In the meantime I have attached the .jpg
On the HR thing, I find that some days my breathing, as in my previous post, doesn't agree with HR, HR usually being a bit low after hard workouts. In which case, I go by breathing more than HR.
Results matter
Results matter
Jedi Master
If you start panting a couple beats above 174, I'd say that looks good. Your rollers must have a resistance unit? Those speeds look very close to what I get at those zone boundaries on my ancient fluid resistance set. That is a nice thing about resistance rollers: being able to go by power, i.e. speed.
Jedi Master
An E-Motion Rollers System just popped up on my local CL today.
Turns out I kinda like riding rollers better than riding outside in really crappy weather. Is it worth the upgrade from my cheap nashbar rollers to the to the E-Motion resistance rollers?
Liked 1,944 Times
Results matter
Results matter
Jedi Master
Jedi Master
Jedi Master
I rode the e-motion rollers for an hour this morning, and the ability to get up out of the saddle is pretty great, but I still don't get the advantage of resistance. There are three manual resistance levels that seem to just make it harder to pedal. On my cheap nashbar rollers I can do essentially the same thing by using higher gears. What am I missing?
Liked 1,944 Times
Results matter
Results matter
Jedi Master
That sounds hard
I'm more of a spinner, but I'll give it a try. All of my geared bikes have fat tires, so I have been using my FG. Sounds like gears would make these rollers more versatile. I have a frame and a box of parts just waiting to be a bike that would be perfect for this, so I may need to bump that project up in the queue. Thanks as always for your advice.
Viking55803
Training & Nutrition
6
09-03-15 03:19 AM
greenlight149
Road Cycling
43
03-07-15 11:20 AM
PaddyyD
9
05-15-10 06:13 AM
