I Own a Supercycle KrossRoads, How Can I Make The Gearing Suck Less?
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Yeah now I'm remembering other problems with it. The brakes haven't failed after a summer of riding, but they are loose on either side of the tire, so it's half braked most of the time.
This isn't my first time on an internet forum. I'd really appreciate it if we can cut past the elitist forum bashing and focus on the facts though. I started this thread because I want to learn what is causing the problem, and how to avoid it in the future. It looks like I'm going to be replacing the bike. So getting back to the task at hand, where does this problem typically arise from? Is it typically an issue with the rear 7 speed derailleurs, or the front 3 speed derailleurs?
My initial assumption is the more cogs you put on a gear set, the higher the margin for shifting errors. Is that an accurate starting assumption folks? I imagine it is even more complex when you need to align 2 sets of cogs with each other. Single speed is simply not an option for me, and 3 speeds probably isn't enough either. I want a new (or slightly used) bike that I can get over the local hills with. So what should I be looking for? Should I avoid anything with a rear derailleur, front derailleur, multiple cogs, greater than 5-6 gears per cog? Is it better to have 2 cogs with 3-5 gears, or one cog with 7-10? I'm here to learn what to buy, not just to learn all the specifics of why my particular bike is garbage.
Here is the most basic explanation of what the parts are and what they do in a derailleur transmission:
https://www.sheldonbrown.com/gears.html
You won't be able to get good information until you know how to ask the right questions, and for that you need to know the proper names of the parts. Note that "chainwheel" isn't used too much; you'll more commonly see "chainring." And "sprocket" is pretty much exclusively used in reference to the rear end of the drive system.
Maybe someone will post more and/or better references.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
I stripped the Shimano 333 stuff off of a Wards Hawthorne and made it a single speed, Bam! It was a ladies frame and a gift to someone though. Too bad, that frame was strong.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,029 Times
The rear derailleur is removable. Here's a link. If you use the zoom tool you can almost zoom it big enough to tell what kind of RD it is, but you can definitely zoom in enough to see the attachment bolt.
-Matt
-Matt
Canada is huge, are you near Toronto by chance? Police auction has occasional decent bikes for little money. This one will probably go for around 150 bucks https://www.policeauctionscanada.com...d-Bike-176547D
Check kijiji gor local bike repair people, and for used parts.
Quoted: 522 Post(s)
Liked 227 Times
The picture of the bike clearly shows it had a derailleur hangar attached to the rear dropout and the derailleur bolted to the hangar. If you think that everything you need to know you learned by Kindergarten, that's really sad I hadn't learned the parts of a bike by then. . Over the years I have gone from a one speed to a 3 speed to a 10 speed and now to a 30 speed drive train. With quality parts, the 30 speed shifting works even better than my first 10 speed. Also had one with 48 speeds due to using internal hubs.
Senior member
Quoted: 942 Post(s)
Liked 656 Times
So, I happened to be in a Canadian Tire store this afternoon, and I wandered over to the bike aisle, which is one area I usually avoid. Sure enough, there was a Krossroads in the rack, so I pulled it out to have a look see.
Aluminum frame, vertical dropouts and no removable derailleur hanger. Bottom of the line direct mount Shimano derailleur to match the build level of the rest of the bike.
SE Wis
Quoted: 2740 Post(s)
Liked 3,388 Times
The gears will never work correctly if the derailleur hanger is out of alignment. The pulleys need to be aligned vertically and horizontally with the freewheel. So check that first.
If the derailleur is aligned OK, then you could be looking at simple adjustments. Find some videos on Youtube and get to work. Ditto with fixing your brakes. Don't expect us to diagnose all your problems remotely and teach you how to do simple tasks that a normal person could teach himself by futzing for 5 minutes.
Quoted: 24 Post(s)
My apologies; on my part, at least, I failed to help you with your actual problem, and you seem to be at the steepest part of the learning curve, since you aren't using standard terms to describe the parts of the bike's transmission.
Quoted: 24 Post(s)
The rear derailleur is permanently bolted to the frame with a flimsy bolt, I've said this right from the start of the thread. I don't understand how some of you can get so far off topic and so damn confused. I'm not here to become a damn bicycle mechanic, I'm here seeking basic information regarding the reliability of various gearing configurations.
Administrator
Quoted: 11952 Post(s)
Liked 6,603 Times
@rollagain Please leave the thread. Do not respond further in this thread. Thanks!
Quoted: 24 Post(s)
My conclusions: 1) Single speed is always going to be the most reliable, though not particularly practical for the hills of Halifax/Dartmouth. 2) The more gears you have on a cog/set (or whatever the hell you deem the correct terminology), the greater the required precision and cost of components for smooth shifting. 3) We have quite a few of the best bicycle mechanics on here, who also have the prestigious achievement of completing grade school under their belt, and they're here to ensure we all become top notch bike mechanics as well
Administrator
Liked 6,603 Times
Guys, the OP has made it clear more than once, if you don't have anything helpful to say don't say anything at all.
Quoted: 2236 Post(s)
Liked 1,314 Times
Thank you! Finally we have forum members with confirmation, and a reasonable comprehension of the problem, and it only took 2 pages of repeating it!
If the derailer is permanently attached you have a problem but if it's a removable bolt you can just buy a cheap used donor bike for parts or even a low/mid level derailer to replace it. For basic commuting there is a point where spending more on parts doesn't get better returns. At this point it may be a lesson learned and you will know more of what to look for/avoid in the future. Let's wait to hear what Dan says about the derailer.
Senior member
Quoted: 942 Post(s)
Liked 656 Times
A question Dan. Is the derailer permanently secured to the hanger by a rivet or some sort of non removable post or is it a hex drive bolt?
Don't let the crazies get you down. There are some good folks too.
My observation was that it mounts directly to the frame without use of a removable/ replaceable hanger that aluminum frames usually have.
I should also note that direct mount has more than one meaning when it comes to Shimano derailleurs. The other type is much more recent and applies only on the top end.
Liked 1,314 Times
The derailleur is not permanently attached. It's a standard direct mount (bolt on) type which can be easily upgraded.
Mikjames. Your problem is just a crappy bottom of the line derailer and the solution is easy enough. Replace the rear derailer with a new mid grade model (don't cheap out but also no need for high end on that level of build). Perhaps look at another shop just for a change and even better a family oriented or old school shop that is comfortable working on lower level/older bikes. The mechanics often have a better knowledge of workaround fixes.
You don't need a removable bolt hanger, many good frames from the 70s and 80's did not have them. To secure the hanger bolt better use some loctite and if the threads are stripped you can probably use a longer bolt and squeeze a thin nut behind the hanger.
Quoted: 24 Post(s)
Wonderful!
Liked 1,314 Times
On the next bike, if it has shimano components, look for at least Claris or Sora labeling. There is better of course but that will be good enough while not buying another future low grade problem.
Fwiw as to terminology. The one piece bolt hanger is fine. That's the part of the bike that extends just past the wheel axle and is solid. The problem is the derailer itself. That is the whole thing attached beyond the black bolt with the hex hole in the middle. It's just poorly machined with too much play to be adjusted for any amount of time.
Quoted: 1815 Post(s)
Liked 1,693 Times
The bolt/hanger looseness is a result of the low quality of the derailleur, nothing else. What I fail to understand is why bikes shops that you have been to did not explain this. It is entirely possible that there was a misunderstanding between you and the shop when you brought the bike in. They may have thought that you were unwilling to spend enough to replace your poor quality rear derailleur and other shift components for more reliable parts. It might have been a communication issue on both sides. I have looked back at your original question and one point that I wonder about is how much you rode this bike before you encountered problems. The bike was not designed for someone who would use it almost every day and in all sorts of weather conditions. It is designed for occasional use for casual cycling. Used that way, it would probably provide years of enjoyable service. However, it is not made for everyday all weather cycling. If you have been riding it regularly in Halifax/Dartmouth in poor weather conditions, you will have exceeded its design specifications. Fewer speeds will not equate to better reliability, only to buying a bike with cheaper parts unless you decide to buy a bike with a good quality internal rear hub with 5 speeds or more. If you are talking about bicycles that use derailleurs to change gears, you always have to have a rear derailleur, you cannot have a viable bike with a left hand 3 speed shifter unless you also have a rear derailleur. Fewer "speeds" (7 or less for your right hand) pretty much relegates you to low quality parts unless you are looking at a bike that is over 20 years old. 8,9,10 speed shifting requires better precision, but component manufacturers have pretty much abandoned anything less than 8 speed to cheap department store bikes. The good news is that very good high quality rear derailleurs designed for as many as "9 speeds" will work very well with your 7 speed shifters
Liked 1,314 Times
MEC, a Canadian company, sells Shimano Altus and Tourney rear derailers for $38 and $25 respectively. There's no problem getting a 7 speed RD for the bike.
SE Wis
Liked 3,388 Times
The bolt isn't flimsy, but it could be loose. Especially given the reputation that department stores everywhere have earned for their conscientious assembly practices. (Not!)
Quoted: 24 Post(s)
I don't why the bike shop would declare the same problem time and again. I offered on multiple occasions to buy a better derailleur from them along with other components, and they keep saying the same thing about the derailleur bolt hanger. They are the highest rated shop in Dartmouth/Halifax. Since I live in Dartmouth it hasn't made any sense to travel to Halifax for repairs. It's possible they just really wanted to sell me the entry level Brody bikes they've mentioned.
I'm going to start a new thread on the local bike brands, though I'm not optimistic on getting advice within my budget. I simply won't spend more than 600$ on a bike taxes, and it would have to be a hell of a 600$ bike to even justify spending that.
