Modern Bike Frame Size vs Vintage Bike Frame Size
Quoted: 80 Post(s)
Liked 9 Times
I have a couple of modern road bikes but I would like to find a nice vintage steel frame and restore it or update it a bit depending on what I find. I want something like a sport tour or touring frame that I can run 32 or 35mm tire on it. I may use it as a winter bike.
I am just over 6' tall and at that size it seems like I take about a 58cm frame most of the time in a modern road style frame. Something around a 580 stack and 385 or so reach. At 56 I ride with the saddle and bars about the same height.
From looking at vintage frames for a while on c/l and the BAY I get the feeling that sizing was measured different then. I don't mean just the fact that they used inches vs cm.
Can you folks give me some assistance in how I know what size vintage sport tour/touring frame I need to be looking for? What measurement do I need from the seller? It seems like many of the sellers don't really understand bike sizing or know for certain what size their bike is.
BTW: Any suggestion on brand/models to keep a look out for would be appreciated.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
I always tell people to look at old Peugeots and Raleighs. Nearly any road bike made before the early 1980's will have pretty generous tire clearance capable of runnig a 32 at least, if not a 35 mm tire.
A 58 cm frame is a 58 cm frame, provided it's measured center to center and not center to top. Sellers of used bikes almost always list the wrong size, I pay more attention to the size of head tubes than to advertised size. Where are you located? Someone on the board who lives near you might be able to make you an offer on something in your size.
Quoted: 80 Post(s)
Liked 9 Times
I live near Harrisburg, PA.
When you say "center to center" I assume you mean center of the crank (spindle) to the point on the seat tube which intersects the center of the top tube. However, I think my modern bikes (where I ride a 58cm) are measuring effective top tube length.
For example my Salsa Casseroll is a 58cm the effective top tube length is 580mm but the seat tube length is 600mm. My other bike is like a 575mm top tube and 560 seat tube length.
I seems to me that seat tube length could very by a few cms and you could just expose more or less seat post. But you cannot really change the top tube length - well I guess you can change stem length to some degree.
I guess this is where I am getting confused. I might be making this harder than it has to be but I am having a hard time reconciling the two.
Sophomore Member
Liked 1,059 Times
If you look at the differences between various frame sizes, the top tube length does not change that much. So I would not worry about that being a limiting factor, the main thing is that your legs can clear the frame when you're standing over it.
It seems as though tall people have most of their height in the legs, while torso length remains relatively constant. There are lots of frames too "tall" for me, on which I would have no problems with the amount of "reach".
In ye olden days, say the mid to late 70s, you were sized by being asked to stand over the bike. Then you grabbed the bike and pulled it up lifting both wheels off the ground. At that point the space between the floor and the wheels was measured - usually eyeballed. The standard was typically 1 inch to 1.5 inches. 1 inch was more touring; 1.5 more sporty. That gave you the frame size. With that in mind you picked from one of the several bike lines sold at a shop to find one with a top tube length and general layout suited to you. There was a tendency for everyone to want to get on the biggest bike possible. During the 80s there was a general trend to ride smaller frames. Thank Greg Lemond for this.
As a very very rough rule of thumb, I usually figure add about 5cm to your modern sloping TT bike size to get your vintage size. Obviously it depends on many factors.
BTW 99% of bikes sold in bike shops BITD were measured center to top. Only a few exotic Italians used CTC.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
As previously mentioned, one straddled the bike standing straight up. The general rule of thumb was you wanted 1-2 inches of top tube clearance in case you came off the saddle, you didn't land on the family jewels. Thinking was much different 20-30 years ago. Case in point--I have a 36 inch inseam and ride a 25 inch frame (the tallest Peugeot made). I bought that bike new 35 years ago. It's my one and only bike and it still fits and is comfortable to ride all day long.
Jon
Jon
As you are aware, vintage bikes had true horizontal (level to the ground) top tubes while most new geometries have sloped tubes. Generally top tube length refers to actual length of the tube centre to centre, but it is not uncommon on Geometry charts to see "effective" top tube length, which is also level to the ground.
Many of the on line frame size calculators seam to use effective top tube length and generate a recommend frame size as a the seat tube length similar to vintage geometry. I have used this one before and it seamed to generate the right size for me. https://www.competitivecyclist.com/S...ulatorBike.jsp
Quoted: 80 Post(s)
Liked 9 Times
Okay. So just focus on my inseam for vintage bikes because that is the way they were sized back then. So if I have a 33" inseam no shoes I am probably goood with a bike around 32.5" max since my shoes probably add about 3/4". If I look at the vintage size charts they say about a 57 or 58 max then. I also saw something about bikes not being made proportional to size until the mid-80s. Before that the bike companies did not change the lenght of the top tube as the bikes got bigger. That adjusting of the top tube (proportional sizing) for long reach on bigger sizes did not start happening till the mid-80s from what I just read. Do I have that correct?
So the seat tube size give a good indication of the standover clearance I will have on a vintage bike because the top tubes were flat. But the real tell is the standover height needs to be about 1" less then my inseam so around 32.5" of stand over.
Is that it in a nut shell?
Quoted: 378 Post(s)
Liked 1,410 Times
Sizing is the same across the market spectrum.
Inconsistent.
Fitting methods are the same across the market spectrum.
Inconsistent.
I've used Colorado Cyclist's chart for modern fits, the "Merckx Fit."
Otherwise, it's hit or miss, and has cost me a few stems and a couple of seat posts.
Once you have the fit, it's like a new bike.
Inconsistent.
Inconsistent.
Bikes: Current Stable: 1973 Mercian Vincitore;1985 CIOCC Designer'84;1988 Raleigh "531c USA" ;1990 LeMond Maillot Jaune Z Team; 1991 Fuji Titanium;1996 Calfee LunaPro-Lemond Z team Tribute Replica; 2013 Wilier Zero.Seven
Quoted: 47 Post(s)
Liked 31 Times
Here’s some info from one of Greg Lemond’s books. Keep in mind the old adage YMMV depending on the type of riding you do and your overall flexibility. According to his recommendations I should be on a ~58cm, but I tend to prefer my two larger bikes (59 & 60cm), both with 130mm stems.. so go figure. Anyway, here’s the book, and the charts
Quoted: 47 Post(s)
Liked 31 Times
I like their write-up, it explains the methodology that’s behind the charts from Lemond’s book
Quoted: 502 Post(s)
Liked 466 Times
Note that with a horizontal TT vintage bike, the smaller the frame, the harder it is to get the bars up near saddle height. Nitto Technomic, and the slightly less tall Soma Sutro stems help, but you’ve got to be close to the low stand-over clearances mentioned in other posts. And some would say that that stand-over clearance is not really needed. I’m fine with an inch or less.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Also note that often the riding position where you were expected to spend the majority of the time was usually the tops. A slack head tube also put the bars closer since if it was rotated about the tt/ht junction. The slacker head tube also gave the bike more stable handling when reaching for downtube shifters. So it was done for good reason. So bar height & reach was different back in the day. A 58cm top tube put the bars closer in reach more on par like a modern 54.
Modern bars are, in general, in a more agressive riding (longer/lower) position owing to better ergonomics of brake levers & the expected riding position of being on the hoods near the shifter/brakes.
These are just broad stroke generalities. I claim no actual expertise, just observations of various bikes I have come across. I ride a 57-58 effective top tube bikes usually, but have found vintage bikes that fit are usually 60-ish top tube & still need 130mm stems to be passable.
Quoted: 80 Post(s)
Liked 9 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
"Reach and stack" are useful - and would be more useful if all the current brands used the same conventions.
the dimensions can be transferred to lugged steel level top tube bikes but some drawing is required.
self propelled lifer
Bikes: 1962 Dawes Galaxy; 72 Gitane Interclub;73 Peugeot PR10;78 Torpado Luxe;73 Grandis; 81 Raleigh/Carlton Comp; 85 Bianchi Stelvio; 87 Bianchi Brava; 73 Bottechia Special; 1969 or70 Bob Jackson
Quoted: 10 Post(s)
Liked 12 Times
I was measured for a 54" frame by my LBS but can ride a 56 to 58" vintage bike comfortably with just a small adjustment in saddle height. I actually feel more stretched out on the smaller modern frame and find the vintage geometry way more comfortable for my vintage body.
