Trek 800 conversion?
Old 11-13-13, 09:52 PM
ken72
ken72's Avatar
Bikes: Trek
Hey, I recently purchased a late model Trek 800 for only $50 on craigslist. The bike looks brand new other than the busted rear hub and it almost looks like its hardly seen any riding time. I would like a hybrid and i was in the market for to spend $300 but now I am thinking about taking this bike and making it a hybrid. What i would like to do is add a mosso aluminum fork with a new headset and neck. Right now it has an older mountain bike wheel set with slick road tires. Is there a thinner size wheel I can use for better road use?
Alternatively I have considered flipping this bike for about $100 since I have it running and spending about $350 on a used hyrbid. Problem is there are not a lot of options on craigslist and I really dont want a walmart or target bike.
I really like the idea of building this bike into something for me but I wanted a few opinions or some of those classic "what i would do if I were you" answers.
ken72 is offline
Old 11-14-13, 03:25 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Its a MTB pre suspension fork just put nice street tires on it and ride it.
My old MTB of that sort wears the studded tires for the Black Ice on the street.
fietsbob is offline
Old 11-15-13, 07:42 AM
BaseGuy
BaseGuy's Avatar
Bikes: 2013 Cannondale CAAD10; 1987 Cannondale R400/600; 1997 Specialized Rockhopper Homemade Hybrid
An old Trek 800 will make a GREAT hybrid. I did the same conversion to my 1997 Specialized Rockhopper (also a steel, no-suspension MTB).
1) With your current rims, which are kind of wide, you can use 26" x 1.5" tires well, and might find some 1.25" wide slicks out there. Instead of fixating on width, look instead for max pressure. Many MTB slicks only allow 65 PSI or so. But there are a few that allow 95 or 100 PSI, which makes a big difference in rolling resistance. I found some at Performance Bike, their "Forte" house brand, and they were inexpensive, too. I run them at about 90 PSI and they feel great.
2) If you ride fast on the flats, you might find your stock MTB gearing is a little short (i.e., you'll spin-out the high gear), especially given the smaller rolling diameter with your small tires. If you ride hills, you'll probably like the short gearing.
If you've got to replace the rear freehub, get one with taller gearing (i.e., fewer teeth on the smallest cogs). I'm guessing you have a seven-speed in back? It's a little tough to find that stuff (it's getting old), but it's still out there, and even amazon.com might have it.
Otherwise, you are good to go. These bikes feel great, and will show you why so many older cyclists rave about steel frames. Do it!
BaseGuy is offline
Old 11-15-13, 08:14 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1793 Post(s)
Liked 1,267 Times in 874 Posts
Specifying WHICH 800 would be useful.
IF it has a suspension fork, I'd pass. It appears those models are NOT CR MO tubing, thus heavier.
You really don't want useless weight on a commuter. An 800 SPORT is HEAVY!
IF it's an earlier model, just throw on some 1.25" slicks and give it a ride. Then you can decide if it's worth throwing more money at it.
Many of the earlier 800 series are good candidates.
Bill Kapaun is offline
Old 11-16-13, 02:23 PM
ken72
ken72's Avatar
Bikes: Trek
Thanks for they replies.
Bill, this is a Trek 800 singletrack. Seems to be a later model but no suspension. I like the frame because it has some slope in the top tube and wider in the frame body.
I have ridden aluminum frame bikes in the past when I owned a nice Giant full suspension mountain bike and a decent Schwinn road bike but I like this steel frame quite a bit.
I know it sounds crazy because after I spend what I plan on this bike I could have purchased a much newer / used hybrid. But I just like the idea of making this bike my own. Plus I enjoy wrenching on stuff and I like projects. For me there is nothing like the sense of pride you get from doing your own work.
What I have ordered: a set of aluminum wheels (cheap zerolites) but still better than whats on it now. A new threadless quill and stem, and a new seat. Thinking about replacing the fork with an aluminum but I think I will ride for a while.
ken72 is offline
Old 11-16-13, 04:06 PM
oddjob2
Still learning
oddjob2's Avatar
Bikes: Still a garage full
Quoted: 847 Post(s)
Liked 66 Times in 44 Posts
Start here. Obviously, you can use whatever handlebars you want. Most are steel.
https://www.bikeforums.net/showthread...ar-Conversions
Here is a late 1980's Miyata Terra Runner I converted, running $10 Panaracer 26 X 1.5" tires.
oddjob2 is offline
Old 11-18-13, 06:08 AM
dr1445
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times in 12 Posts
the selection for the 26" road tires is ok but 700c has more choice. i have one converted mtb with 1,5 x 26, another mtb converted to 35mm x 700c, a bianchi hybrid with 28mm x 700c and an old puch converted to a hybrid with around 32mm x 27 tires. the mtb with 700c is going back to mtb as i have a nos hybrid frame i am building up. out of the lot i like how the old puch rolls with the 27 and mtb with 26 the least. i plan to send the 26 to the philippines where the 26 tire is more common and large frames are not common.
dr1445 is offline
Old 11-18-13, 06:21 AM
ken72
ken72's Avatar
Bikes: Trek
I wanted the 700c but did not realize they made a brake modification for them. I found this out after I ordered the new 26 inch wheelset. Im keeping my eyes open for a good used set now that I know.
ken72 is offline
Old 11-18-13, 06:36 AM
dr1445
Quoted: 18 Post(s)
the mtb to 35mm x 700c was a on trek 3700, i tried the wheels on my jamis komodo mtb but they would not fit. i have a $30 19" 800 in the basement and i am 99.9% sure 700c would not fit that frame. since you already have the road tires, ride it as is for while and form your own view before putting more $ into it.
dr1445 is offline
Old 11-18-13, 06:48 AM
phoebeisis
New Orleans
Quoted: 157 Post(s)
Liked 3 Times in 3 Posts
the earliest Trek 800 had mainframe cromo tubes
later on trek cheaped out and did SEAT TUBE cromo-the decal will tell the story.
and later still went to aluminum
The mainframe cromo would be most desirable
but frankly I can tell any RIDE DIFFERENCE between ANY of them-certainly not the seat tube vs all 3 tubes
Yeah they are nice bikes.Ride well-sturdy-great "better than beater" bikes.
phoebeisis is offline
Old 11-18-13, 08:03 PM
ken72
ken72's Avatar
Bikes: Trek
Thats good advice. I had an aluminum 700c hybrid that I loved riding about 4 years ago. It was the last bike I owned until now. I remember the bike was fast but right now I am doing this fun. Plus my daughters is riding now and this is a great way to spend time with her. Think i will just get the thinnest tire I can buy and run that for a while on these new wheels.
ken72 is offline
Old 11-21-13, 09:28 PM
ken72
ken72's Avatar
Bikes: Trek
Here is my before and after. Of course we are looking forward to some very cold weather over the next couple of day. Hope to ride soon.
File Type: jpg
File Type: jpg
ken72 is offline
Old 11-22-13, 07:38 AM
BaseGuy
BaseGuy's Avatar
Bike looks good. I've got those wheels on my own converted-MTB-hybrid, and they seem to be pretty good. I've got two decent road bikes, but the old hybrid is a great utility bike and wet-weather device, and still a lot of fun to ride.
BaseGuy is offline
Old 11-23-13, 03:52 PM
ken72
ken72's Avatar
Bikes: Trek
Thanks Baseguy. It was a cold day but I finally got to take it for a ride. The wheels ride as well as the stock ones. I am looking at adding some disk brakes but only because I have always wanted a bike with discs.
ken72 is offline
Old 11-27-13, 08:27 AM
Beic
Kona Hoss Conversion,
Gone are the heavy front suspension forks, fat tyres and clipless pedals.
Added a steel rigid fork, ergo grips, cheap bar ends, skinny tyres and flat pedals.
I could probably squeeze 29" wheels on it!
Nice and light and responsive, well twitchy.
Beic
File Type: jpg
Beic is offline
Old 11-27-13, 03:55 PM
ken72
ken72's Avatar
Bikes: Trek
Beic
I really like the fork. Bike looks good as well. I wanted a fork like that for my Trek.
ken72 is offline
Old 11-27-13, 04:48 PM
Beic
Hi Ken,
The fork is a UK On One cromo fork, available from Planet X and On One who now have a USA outlet.
Cheaper than a Surley Instigator here at approx $100.
Beic
Beic is offline
Old 03-24-19, 07:47 AM
JamesB722
Bikes: 2015 Giant Defy Advanced 2, 1999 Trek 800
Quoted: 11 Post(s)
Liked 2 Times in 1 Post
Call me the Resurrector! I also have a Trek 800 that looks exactly like yours. IF you still own this bike and remember the changes you made, can you tell me about the headset/stem upgrade. Did you use an adapter? is it 1" to 1 1/8"? Thanks!
JamesB722 is offline
Old 03-26-19, 03:23 PM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1533 Post(s)
Liked 1,528 Times in 916 Posts
@JamesB722, the OP has 13 posts; I suspect he is long gone. Sounds like he switched out the wheels, stem and saddle. It really shouldn't be too difficult to do, and you can still find 1" stems; my husband found a nice one on eBay for cheap. Please, do start a thread for your build; I'm sure you will get lots of advice, whether you ask for it or not.
Korina is offline
Dyniel
General Cycling Discussion
5
09-05-18 09:07 AM
Danekger
Classic & Vintage
5
04-20-17 07:51 AM
Cycle_of_life
17
03-12-15 08:51 PM
warneral
Hybrid Bicycles
7
04-12-11 10:49 AM
ericg2000
Hybrid Bicycles
48
02-20-11 07:24 AM
