Replacing shifter cables with internal cable routing
Old 10-04-18, 07:56 AM
maartendc
maartendc's Avatar
Bikes: 1989 Cannondale 3.0, 2001 Trek 5200, 2010 BMC SLC01, Minerva MTB Hardtail
Quoted: 431 Post(s)
Hello all,
I'm looking for some advice on replacing shifter cables (Sram Force) on a BMC frame with internal cable routing, which I have never done before: I want to do it myself in order to learn how to service my entire bike.
1. Does it make sense to replace the shifter cables without also changing the housing? Or do you always replace both at the same time?
2. I am planning to use the method with a thin "cable liner" or "housing liner" to guide over my old cable, and then guide the new cable through the internal routing in the frame using this method: https://www.artscyclery.com/learning...tedcables.html
Planning to buy this liner for it: https://www.amazon.com/gp/product/B0...AVQ4OOHG&psc=1. Anyone know of a better method or liner?
3. Are you supposed to re-use the barrel adjusters at the ends of the cable housings? Or do you replace those?
4. Any other tips / tricks to look out for?
Thank you!
maartendc is offline
Old 10-04-18, 08:31 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1734 Post(s)
Liked 47 Times in 34 Posts
Sorry to hear that you have internal routing
1- As internal routing is a pain to deal with and that the casing does wear too I strongly replacing both at the same time.
2- The liner over the existing inner cable is the first method I go to. Only when it doesn't work would I have to use a more frustrating one.
3- Always have a barrel adjuster in a cable path. Unless they are damaged/rusted I would clean them up. lube the threading/spring and reuse.
4- Use SS inners. Use uncoated inners. Use new casing end caps. Do double check the adjustments and alignments of the ders after.
Andy
AndrewRStewart
Andrew R Stewart is offline
Old 10-04-18, 03:09 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 654 Post(s)
Liked 48 Times in 44 Posts
I replace both the inners and outers at the same time, my reasoning being that the inner wears into the outer (a major contributor to "stretch") and a new inner may not play well with the existing groove.
Agree with Andrew Stewart's cable choices, I use die-slicked/drawn inners. I use the tiny dab of lube which comes on Shimano housings, or none if not supplied. It is tough to find a lube which improves on steel vs PTFE's (Teflon) coefficient of friction of ~0.05.
dsbrantjr is online now
Old 10-04-18, 09:07 PM
Le Mechanic
Le Mechanic's Avatar
Bikes: Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 46 Post(s)
Liked 9 Times in 9 Posts
I made a video about a year ago with some tips as well as potential issues to avoid, but yeah, you should generally replace the housing when replacing the inner wires.
Le Mechanic is offline
Old 10-05-18, 03:31 AM
JoeTBM
Droid on a mission
JoeTBM's Avatar
Quoted: 55 Post(s)
Liked 4 Times in 4 Posts
I have replaced a number of internally routed housings.
Best is before you put out the old housing, attach a strong piece of string or cord with electrical tape. This will help you snake back in the new housing by taping it to the string. It is important to feed the new housing in as you pull the string. If you lose the string you are going to have to snake it.
Me.... I'm a retired electrician, that is why I use this trick.
JoeTBM (The Bike Man)
I'm a black & white type of guy, the only gray in my life is the hair on my head.
JoeTBM is offline
Old 10-05-18, 06:24 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1143 Post(s)
Liked 24 Times in 22 Posts
The worst internally routed cable I ever had to deal with was a late '80's Trek 560 where the rear shift cable was routed internally through the drive-side chainstay. There was no housing used, just the inner wire. There had been an internal guide funnel at the exit end but that had come loose as these frames were prone to do. It must have taken a half hour of trial and error and profanity before I lucked into the exit hole. I quickly learned to use the old cable to guide the new one through for future recabling.
HillRider is offline
Old 10-05-18, 09:39 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1163 Post(s)
Liked 32 Times in 24 Posts
Use the old cable housing to guide the new inner shift cable through the frame. Then pull out the old cable housing and use the new cable to guide the new cable housing.
My other trick is to figure out how to position the bike so that I can see the cable outlet and it's right right at the bottom. Then I push the cable through and watch as it comes past the exit hole. Then I snag it with something and pull it through. This has always been easier to do than it sounds. The most time consuming part is figuring how to position and clamp the bike so I can see the exit hole.
Retro Grouch is offline
Old 06-17-19, 10:42 AM
justridingalong
Originally Posted by maartendc View Post
Hello all,
Thank you!
I'm replacing a rear shifter so a new cable is required. I've seen videos that use tubing with a i.d. that slightly larger than the cable as a guide, magnets, thread fastened to cable, a vacuum. I think I'm going to remove the bottom bracket and have a look into the shell, then make my decision. Right now I'm considering fishing line connected to the end of the cable for removal and installing a new cable. I'll post my results in case I can help others. Unless there's something wrong with a barrel adj. I'd leave it. Replacing housing is recommended. I'll check that Amazon liner out.
justridingalong is offline
Old 06-18-19, 02:30 PM
maartendc
maartendc's Avatar
Quoted: 431 Post(s)
Just FYI, I used that liner cable from Amazon, worked absolutely perfectly!
The inner diameter is just ever so slightly larger than the shifter or brake cable. You just slide it over the old cable, through the frame. Then, slide out the old cable, and slide in the new cable. Very easy, and no risk of the cable getting lost at any point.
I would definitely use this method again in the future, and not bother with any other method.
Old 06-18-19, 03:58 PM
Retro Grouch
just fyi, i used that liner cable from amazon, worked absolutely perfectly!
but it took you 8 months!
Old 06-18-19, 04:10 PM
justridingalong
Jagwire housing liner
I ordered some Jagwire Black Housing Liner like you recommended, that seems to be the best solution for running cables through the frame.
Old 06-20-19, 07:23 AM
maartendc
maartendc's Avatar
Quoted: 431 Post(s)
Lol, yeah! I'm a bit slow..
Old 06-20-19, 09:25 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
use Magnets (as long as frame is not steel, or cable is non ferrous stainless.. )
fietsbob is offline
Old 06-23-19, 11:21 PM
justridingalong
Turns out that there is an internal tube running from the down tube to the chainstay on my bike for the cable- good deal
Monkey D.Luffy
Classic & Vintage
1
01-13-15 07:42 PM
Hoss Cartright
Classic & Vintage
13
12-30-11 10:48 AM
MONGO!
"The 33"-Road Bike Racing
1
08-20-08 08:49 AM
stringbreaker
Classic & Vintage
16
11-13-07 12:42 PM
