Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
racing without a power meter?
Old 03-20-19, 09:24 AM
TimmyT
Keener splendor
TimmyT's Avatar
Bikes: Black Mountain Cycles Road, Cannondale CAAD12, Nigel Dean Tour Ace, Lemond Poprad
Quoted: 240 Post(s)
Liked 8 Times in 5 Posts
Originally Posted by Doge View Post
I appreciate hearing your data as a person that actually uses one in a race. I had not heard that much (can't recall at all) before. I found that while many use them for training, few changed how they road in a race because of what the number said.
To be clear, you are saying the number you see makes you ride differently than if you saw another number. Or...if aliens hijacked your display, you would do different things based on the number.
The pros do look at them and react / maintain based on the numbers. It increases the boring factor. They should be banned from pro races, as they are from track.
This only works if you know your power zones. If you're out there without guideposts on your power, the number is irrelevant. I've spent time staring at Golden Cheetah trying to understand what my body is doing. Think of power zones 1/2/3 as "save" and 5/6/7 as "spend." Zone 4 is threshold and can be either depending on how it is used. Strategies in a race against others (as opposed to a time trial) come down to "save a lot and spend wisely." In terms of that, then I can modify my strategy, so in that regard it influences my race.
Originally Posted by Craigslist View Post
Note to you BLOWHARD MORONS out there: The fork is not bent. Most PEUGEOTS of the '70s forks DID NOT line up with the head tube angle. This is normal. The last pic is from the 1972 Dutch catalog showing this EXACT MODEL in diagram. Keep your comments to yourself......
TimmyT is offline
missbliss
Bicycle Mechanics
55
04-14-13 07:24 AM
speed mode
Road Cycling
4
08-26-10 02:55 PM
funrover
5
10-27-09 07:36 AM
Steuben
Recumbent
0
04-18-09 02:19 AM
squegeeboo
Foo
73
10-04-07 04:27 PM
