Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Riding position change animation
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 03-09-19, 10:57 PM
Clem von Jones
Quoted: 91 Post(s)
A couple animations with implications for fit and position to contemplate. In both animated gifs the riding position is identical yet pivoted forward or backward relative to the center of the bottom bracket. Notice that as the handlebar comes up the stem has to be shorter, the rider is shifted backwards, the saddle moves back and down, and there's a hell of a lot more weight on the rear wheel.
Clem von Jones is offline
Old 03-10-19, 09:04 AM
GailT
Quoted: 103 Post(s)
Liked 10 Times in 7 Posts
The riding position is not identical if you change the height and set back of the saddle. Seems like you would want to keep those constant if they were set correctly initially.
GailT is offline
Old 03-11-19, 10:46 AM
berner
Quoted: 300 Post(s)
Liked 33 Times in 27 Posts
I like your animation. It helps visualize the effects of changes in position. After a number of years and miles I have arrived at a very comfortable position but it was a painful struggle to get here. It makes sense that a small change in position can have a major effect on comfort during a long ride but I have found that a small change can have a significant effect even on short rides. To help with those changes, I've marked, using a whiteout marker, various locations on the bike for seat post and saddle location and handle bar. This has made it easy to make changes on the fly to those locations and get back to a previous location.
berner is offline
Old 03-12-19, 03:32 PM
Doge
Doge's Avatar
Bikes: 1979 Raleigh Team 753
Quoted: 2935 Post(s)
Liked 41 Times in 32 Posts
More/less weight goes to the arms too. What is missing here is the power that rider is putting out. The force on the pedals is lifting for the arms. A high power low front is more comfortable than a low power low front.
Doge is offline
coasting
Foo
0
07-28-09 02:25 AM
fosmith
Road Cycling
0
06-06-08 06:50 AM
