Go Back  Bike Forums > The Lounge > Blogger's Forum
Occasional ride log and other cringey babbling
Blogger's Forum Whether it's a cycling blog, or just your personal page, this is the place to share ideas and links.
Old 05-10-19, 08:20 PM
  #101
Phamilton
Gone
Quoted: 355 Post(s)
Liked 15 Times in 12 Posts
We have several friends and some family members who have been able to quit their 9-5s and make a decent living driving for Lyft and Uber and grocery delivery services and such. Rideshare has taken off here more than people anticipated.
Phamilton is offline
Old 05-10-19, 08:22 PM
  #102
Phamilton
Gone
Quoted: 355 Post(s)
Sort of the one condition Iíd ever own a car again is if I needed it for work. If it WAS my work ...
Old 05-10-19, 08:29 PM
  #103
Phamilton
Gone
Quoted: 355 Post(s)
I was thinking today, that if I still had a car, Iíd have left my current job by now. Iím not sure if that would have necessarily been inherently good or bad, itís just to say that there have been times when work was so slow I told myself at least I got to ride my bike. I havenít stopped enjoying commuting by bike yet. I doubt Iíll do much more winter commuting here unless itís much shorter, like 3-5 miles one way. For me, itís just too cold, too bleak, too nervous making to do more than once or twice a week. Whether that means I telecommute more next winter or figure out a different employment situation or get a car and drive myself or carpool with someone else - I dunno. But I think another Indiana winter spent on the bike might be a lot. I want to enjoy riding.
Old 05-10-19, 08:40 PM
  #104
Phamilton
Gone
Quoted: 355 Post(s)
My brother has told me that heís picked up several commuters while driving Uber. Thatís very significant in this town.
Old 05-10-19, 08:56 PM
  #105
Phamilton
Gone
Quoted: 355 Post(s)
Reason Iím not freaking out about my knees is I seem to keep reading accounts of BF cyclists who took the winter off and are describing much worse symptoms after their first rides of 2019 than what Iím experiencing. What Iíve ever experienced actually, take all with a grain of salt though.
Old 05-10-19, 09:03 PM
  #106
Phamilton
Gone
Quoted: 355 Post(s)
Comparing current setup of Voyageur to where I started, basically I kept my hands more or less where they were, brought everything else forward 2cm, and my CG down 2cm.
The top tube of the Trek is 15mm longer yet, and I was using a 100mm stem for all the but last month or so before I put a 60mm and then eventually fit it with the flat bar again.
Old 05-12-19, 01:03 PM
  #107
Phamilton
Gone
Quoted: 355 Post(s)
Since I decided to give the Trek to my brother, Iím finding myself worrying about having a backup bike. I have the Collegiate, but itís not a bike I want to ride more than a few miles on at a time.
Yesterday then I was poking around in the garage, looking at at the parts and wheels and stuff and decided to ďfixĒ some things.
The rear wheel of the Raleigh, I busted a spoke on it a month or so ago, and the left crank arm was stripped with a pedal still stuck in it. So I scavenged parts off the yellow Fuji, the crank, rear derailer, shifters, the steel wheels, maybe a couple other things and had it more or less roadworthy but needing tires. All this was a month ago.
I still have the spare set of hybrid wheels I used for studded tires for the Trek and wasnít sure what to do with them as none of my remaining bikes have 135mm rear triangle spacing. The Raleigh, the Fuji, and my Voyageur all have 27Ē wheels, and the hybrid spare wheels are 700C. I have several sets of 700C tires as wheel, and no spare 27Ē tires. So I thought it would be smart to try to convert that spare rear wheel to 126mm spacing. I donít really know if it worked out or not. I used the axle and spacers from another 126mm hub and after a little adjusting and experimenting had it working and fit into the back of the Raleigh but it was still off center. So I then put it on my Voyageur and it was slightly off center but not as far off as on the Raleigh. Also discovered that the Voyageur has 120mm rear spacing (!?). I put the Voyageur rear wheel on the Raleigh and it was just as off center as the other wheel I built.
Old 05-12-19, 01:12 PM
  #108
Phamilton
Gone
Quoted: 355 Post(s)
So in all the rear wheel fiddling and whatnot, I discovered that the rear triangle of the Raleigh is bent. Sighting down the drive side seat stay, thereís a noticeable bend inward starting just below the brake bridge. The non drive side stay looks straight from all angles. The space between the dropouts is 128mm. I think itís bent inward and also maybe up or down, Iím not sure. I donít have any sort of gauge to check it.
Old 05-12-19, 01:26 PM
  #109
Phamilton
Gone
Quoted: 355 Post(s)
Makes me wonder if sometimes frames ever got brazed up a little crooked then bent to within some tolerance and sold.
Old 05-12-19, 01:28 PM
  #110
Phamilton
Gone
Quoted: 355 Post(s)
Moral of the story was I spent basically all day in the garage trying to fix things and just made a mess, discovered that frame is bent, and got frustrated.
Old 05-12-19, 01:32 PM
  #111
Phamilton
Gone
Quoted: 355 Post(s)
I didnít expect the Voyageur to have 120mm rear spacing, despite having a 5 speed freewheel. I could probably have it spread to 126, but 130 seems like a lot, maybe too much. So it will probably never see a cassette hub. Itíd be perfect for a FG/SS, but itís weird to consider the irony of making that out of a touring bike frame. Iíve never seen a fixie with front and rear racks and fenders.
Old 05-12-19, 01:33 PM
  #112
Phamilton
Gone
Quoted: 355 Post(s)
It actually sounds kind of awesome.
Old 05-12-19, 01:34 PM
  #113
Phamilton
Gone
Quoted: 355 Post(s)
Or maybe an IGH, I think they often have narrower hubs ... ?
Old 05-12-19, 01:37 PM
  #114
Phamilton
Gone
Quoted: 355 Post(s)
Not gonna lie, if I felt like I could get the gearing correct, I might really love the Voyageur with a Sturmey Archer 3 speed.
Old 05-12-19, 01:42 PM
  #115
Phamilton
Gone
Quoted: 355 Post(s)
At any rate, the verdict is still out on the Voyageur current drivetrain. The 46T ďsmallĒ ring is I think gonna be too tall for me, unless I have some unforeseen and unexplainable improvement in my fitness level. The 30T granny is too low to do much good around flat here.
I do think the 46/50 half step is really cool, but itís a lot of work, a lot of double shifting, all happening on the downtube. Not super convenient for commuting use.
Old 05-12-19, 01:48 PM
  #116
Phamilton
Gone
Quoted: 355 Post(s)
Ha! Will ya look at that. I canít afford it now, but itís cool to see one.
Old 05-12-19, 02:03 PM
  #117
Phamilton
Gone
Quoted: 355 Post(s)
My Collegiate has a 3 speed hub but itís a nasty clunky Shimano. The spacing between the gears is a little wide. But it looks like you can find close ratio SA hubs, evidently. Iíll have to see what the gearing would look like. I think I could rock 3 gears around these parts if I do like 45, 65, and 85 gear inches, or close to it.
Old 05-12-19, 02:16 PM
  #118
Phamilton
Gone
Quoted: 355 Post(s)
I didnít realize there were so many internal gear options.
I know a lot of the Sturmey Archer models arenít in production anymore but some of them you can seem to find used pretty easily and often cheaply.
I donít know anything about this one, but this is a cool gear spread.
Old 05-12-19, 03:12 PM
  #119
Phamilton
Gone
Quoted: 355 Post(s)
Iím not sure Iíve ever said it before, but Iíve found myself thinking several times over the past several months that it takes relatively little real world bike commuting experience to see that many of the people who present themselves online as bike commuters have very little experience with either.
Old 05-12-19, 03:15 PM
  #120
Phamilton
Gone
Quoted: 355 Post(s)
I mean, thatís OK with me. I just donít always remember that.
Old 05-12-19, 03:16 PM
  #121
Phamilton
Gone
Quoted: 355 Post(s)
I ainít into labels much anymore.
Old 05-12-19, 03:20 PM
  #122
Phamilton
Gone
Quoted: 355 Post(s)
ďAinítĒ is an indulgence for me. I get into a certain frame of mind and seem to channel my dead grampa. Unfortunately this sometimes includes nose picking and flatulence, but you know the old saying ďsometimes the ghosts of your grandparents fart and pick their nosesĒ
Old 05-12-19, 03:23 PM
  #123
Phamilton
Gone
Quoted: 355 Post(s)
My kid made a big deal out of motherís day this year. She started planning like weeks ago. She saved up a bunch of money and got my wife all these perfect gifts, candles and incense and makeup and buttons for her purse and stuff like that. Theyíre at the moment doing some facial masks and eyebrows and makeup and all that stuff they actually enjoy doing together. Itís a really good moms day this year. They even took 15 minutes to help me clean up the aftermath of yesterdayís mechanical misgivings in the garage.
Old 05-12-19, 03:26 PM
  #124
Phamilton
Gone
Quoted: 355 Post(s)
I canít stop thinking about the Voyageur with a 3 speed hub. Iíd put cloth tape on the bars, maybe blue or red or something like that. And maybe a saddlebag, like a canvas one. I donít know if Iíd actually like riding it, but Iíd be very satisfied with the look I think.
Old 05-12-19, 03:27 PM
  #125
Phamilton
Gone
Quoted: 355 Post(s)
I donít know if Iíd change the fenders or not.
