Am I shrinking, wising up, or just getting old?
Old 05-06-19, 09:26 AM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 346 Post(s)
Liked 60 Times in 50 Posts
OK, so I've ridden 56cm for 15 years. Slow, fast, climbing, indifferent, always the same. Never any issues; thought I had it "dialed in" with a 56cm TT and 70mm stem, classic bars. And I rode the drops most of the time.
And now it's not working.
double-*&^%$#!!
My 54cm builds, including a very recent one, are um, for lack of a better word, below orgasmic as far as fit, but much better.
I'm inches from selling my 56cm fleet off (and it was slowly built and collected).
Do I hang weights from my ankles and hang by pullup bars? Maybe stretch it out a bit?
Do I go to zero-setback posts and slide the saddle up?
Or should I just hide my 56cm pride in proportions and ride the 54's?
What is your experience, as you age, re: sizing and fit?
Deteriorating minds want to know.
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 05-06-19, 09:30 AM
repechage
Quoted: 936 Post(s)
Liked 13 Times in 11 Posts
Gravity strikes back.
From my tallest point, some 40 years ago, I have 35mm less in stature.
Its all in the top tube. (effective length- forward of the vertical line passing through the bottom bracket)
You could always buy inversion boots...
My latest purchases have 15mm shorter top tubes than what I would ride when young.Really don't want to go under a 10 cm stem if possible.
repechage is offline
Old 05-06-19, 09:33 AM
horatio
Hump, what hump?
horatio's Avatar
Bikes: See signature
Quoted: 183 Post(s)
Liked 22 Times in 19 Posts
What’s hurting when you ride the 56’s?
horatio is online now
jetboy
jetboy's Avatar
Bikes: centurion ironman, look hinault 753, Zunow z-1, 83 stumpy sport, look kg96, various others
Quoted: 624 Post(s)
Liked 3 Times in 3 Posts
are you riding more in the evening or morning? you do shrink during the day... so 56 in the morning, 54 in the evening time!
jetboy is offline
Old 05-06-19, 09:34 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
Had a bad experience with them, pull-up bars, and tequila. I still get the dry heaves thinking about it.
BTW, my recent "smaller" build from Damiano is one of the flies in the ointment.
Robbie ♪♫♪...☻
Old 05-06-19, 09:37 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
On C&V bars, mostly Cinellis and Nittos, not getting as much flex on my arms on the hoods.
I can't decide if I was tougher then, and dealt with it, or shorter now.
I swear I used to be able to read the front hub on a 56cm. Now I can't even see it.
Robbie ♪♫♪...☻
Likes For RobbieTunes:
Old 05-06-19, 09:38 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
I can't think of a better excuse to keep the fleet....
Robbie ♪♫♪...☻
Old 05-06-19, 09:40 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube, M Alloy Pro, Sprint 76; Amp Research B4; Colnago Crystal; Klein Pulse; Litespeed Catalyst
Quoted: 295 Post(s)
Liked 38 Times in 25 Posts
In my >20 yrs on the road, I've always preferred to be stretched a bit, and at least to have that option, and 59cm has been where I'd start for a road bike. But I've now got three 57cm frames and they're fine too, but I do feel more on top of the front wheel and the bike is a bit more twitchy.
If you're feeling too stretched and can't make enough minor adjustments to suit, then yeah I'd say go for what feels right and stick to that smaller frame.
ridelikeaturtle is offline
seedsbelize
Refugee
Quoted: 4727 Post(s)
Liked 33 Times in 26 Posts
I rode 58cm for twenty years and am now finding the orgasmic ride on 60cm Treks.
seedsbelize is offline
Old 05-06-19, 09:43 AM
gugie
Crapmaster Emeritus
gugie's Avatar
Bikes: JP Weigle'd Raleigh Competition reconstruct, 73 Raleigh Competition 650b'ed, 96 Bike Friday NWT, 83 Lotus Classique, 78 Centurion ProTour, 73 Raleigh Grand Sports
Quoted: 2216 Post(s)
Liked 46 Times in 34 Posts
In a Seinfeld episode Elaine throws Jerry under the bus for buying wider pants, but writing over the size on the patch so that they're still 31 inch waist...
Buy a tape that measures long, call it a 56 if anyone asks...
gugie is offline
Old 05-06-19, 09:44 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
I heard they're more grateful.
Robbie ♪♫♪...☻
Old 05-06-19, 09:47 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
I just keep remembering the Dairyland Dare with @hodgykins and the Hilly Hundred with @steelbike guy, and the bike (54cm) was pretty much non-existent under me.
Robbie ♪♫♪...☻
Old 05-06-19, 09:48 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
Maybe I'll just stop talking to people. That should ease it some.
Then again, for Elaine, yeah, I'd suffer.
Robbie ♪♫♪...☻
Old 05-06-19, 09:54 AM
horatio
Hump, what hump?
horatio's Avatar
Quoted: 183 Post(s)
Have you tried narrower bars?
Old 05-06-19, 09:57 AM
seypat
Quoted: 927 Post(s)
Liked 40 Times in 37 Posts
I have found the shrinkage in direct proportion to gaining weight. If I gain 10lbs, my @ss gets bigger. The cushion between the sit bones and saddle is bigger so I have to lower the saddle. Same for the gut. If the aero belly gets bigger, I cannot extend/stretch out as far. Like you, I have to go to the smaller frame or make some adjustments. This is measurable on the stationary bikes at the gym. I move between 2 settings depending on the amount of junk in my trunk.
seypat is online now
Old 05-06-19, 10:01 AM
curbtender
curbtender's Avatar
Quoted: 502 Post(s)
Liked 13 Times in 12 Posts
I'm seeing a turnover of the fleet.
curbtender is offline
Old 05-06-19, 10:03 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
You are really killing my buzz with all this common sense. The sad thing is I understand it.
Robbie ♪♫♪...☻
Old 05-06-19, 10:04 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
Robbie ♪♫♪...☻
Old 05-06-19, 10:05 AM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
Yes. Did not help. I'm not exactly aero.
Robbie ♪♫♪...☻
Old 05-06-19, 10:17 AM
jlaw
Bikes: 2015 Spec. AWOL Elite, 2007 Spec. Roubaix Elite, 2003 Spec. Big Hit 2, 1998 VooDoo Zobop, 1985 Trek 410, 1984 Trek 620
Quoted: 219 Post(s)
Liked 35 Times in 21 Posts
An hour or two per day on this thing and you'll be trading up to a 58cm fleet.
(At least this guy seems to think so)
jlaw is online now
Likes For jlaw:
Old 05-06-19, 10:18 AM
markwesti
markwesti's Avatar
Bikes: 84' Centurion Comp TA , 86' Centurion Ironman , 84' Centurion "track bike" , 84' Bianchi Alloro
Quoted: 418 Post(s)
Liked 18 Times in 16 Posts
Have you tried 165mm cranks ? I have 170-172 on my 58's , I would love to get some 165's . And + 1 for shorter stem and no set back on the post .
markwesti is offline
Old 05-06-19, 10:21 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2028 Post(s)
Liked 98 Times in 81 Posts
Dang, I'd offer to buy one of your 56cm Miami Vices if you still had one.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 05-06-19, 10:24 AM
horatio
Hump, what hump?
horatio's Avatar
Quoted: 183 Post(s)
There’s got to be something you can modify besides the frame. 2cm is less than an inch. That Battaglin has a very short stem, BTW.
Old 05-06-19, 10:31 AM
stardognine
Turquoise gatherer.
stardognine's Avatar
Bikes: 1985 Cannondale ST400
Quoted: 329 Post(s)
Liked 16 Times in 16 Posts
You guys just kill me. I've worn a 32-34" waist Levi's since I was 16, because a proper 33" is very hard to find. And don't hand me no "baggy" pants, the normal ones are baggy enough. 🤪😁
stardognine is offline
Old 05-06-19, 10:39 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1539 Post(s)
Liked 12 Times in 11 Posts
@RobbieTunes, possibly you were formerly in the habit of stretching more than you do now? I ask 'cuz at various points in the last five, ten, fifteen years, I have made a point of doing a lot of stretching, like getting to the point where I could put the palms of my hands flat on the floor when standing up, then stretching my neck so i could look as far forward/up as possible. It's always painful, but after doing that (and similar things) several times a week for a few months, I get a lot more flexible.. and this helps fitting the bike. I'm out of the habit now, and I see I like my handlebars higher now than I did a few years ago. Not a good sign!
I put new leather on ruined saddles like Brooks, etc. You can reach me by private message.
rhm is offline
