Strange Flat - What Happened
Old 05-20-19, 05:26 PM
DaveLeeNC
Bikes: 90's Vintage EL-OS Steel Bianchi-2014 Campy Chorus Upgrade
Quoted: 178 Post(s)
Liked 11 Times in 10 Posts
I went out on a ride today and there is a new subdivision going up on the route. I stupidly decided to spin through it just to see it (lots of construction with the inevitable crap on the road). I hit something (sounded like a strip of metal but I never saw it) and then I heard a gentle, almost soothing "SHHHHHHHHHHHHHH...." as the air left my rear tire (why is it always the rear).
I still ride butyl tubes and after removing the tube I pumped a bit of air into the tube to see where the leak was so I could check the wheel carefully in that area. Couldn't find a leak so I just replaced the tube and rode home (close to the end of the ride anyway).
I pumped the tube up with a good bit of air after getting home and it held air just fine. I forced it into a bucket of water and the only air bubbles that I saw were just a few coming from the presta valve stem - those went away when I closed the valve. I honestly cannot say for sure that the valve was closed on the ride. I don't know if this tube will hold 90 pounds of air when encased in a Conti tire, but it certainly holds low pressure just fine.
So either this tube has a high pressure only leak (it was DEAD FLAT) when I removed the tube, or something funky happened regarding the valve/stem. No big deal other than I would prefer to fix and reuse the tube. I just have no idea what to fix.
Thoughts on what happened here? Thanks.
dave
DaveLeeNC is offline
Old 05-20-19, 05:39 PM
ChinookTx
Bikes: Kona Rove Ti., Motobecane Whipshot Ti
Quoted: 89 Post(s)
Liked 39 Times in 31 Posts
Do you have a pump that screws on the valve? Some tubes have a removable valve that may get loosened when you remove the pump. Maybe it was borderline and hitting the bump pushed it over the edge. I'd be curious to see if it holds air when you mount it with a tire and pump it up to full pressure.
ChinookTx is offline
Old 05-20-19, 06:28 PM
DaveLeeNC
Quoted: 178 Post(s)
I have a 'normal' lever type pump that I used (both floor model and the mini on my bike).
I guess that I will experiment putting that tire back on some wheel. But I also play classical guitar and changing a tire is not compatible with good guitar nails. This event ended up tearing my 'c' fingernail off at the base. It will take a couple months to grow that one back. But I might try the tire swap anyway.
dave
Old 05-21-19, 04:25 PM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 129 Post(s)
Liked 6 Times in 5 Posts
I ran into that with a batch of Conti tubes. They were just loose enough that they were fine until you unscrewed CO2 during a ride. Not obvious.
popeye is offline
Old 05-21-19, 05:15 PM
DaveLeeNC
Quoted: 178 Post(s)
That is interesting. This one is a 'CST' tube. I wonder if they make tubes for Conti?
dave
Old 05-22-19, 02:05 AM
smashndash
Quoted: 258 Post(s)
Liked 10 Times in 8 Posts
I carry a valve tool on rides/to races. It's light, compact and a lifesaver. I'd try tightening up the valve core as much as possible (without shearing the valve off the tube) and trying again. Also, if your valve is particularly old or maybe grimy, it could have grit lodged in it that keeps it from "closing" all the way?? Though that seems unlikely in this case. Curious as well. If the tube ends up with a slow leak, you can throw in some orange sealant and it should take care that.
smashndash is offline
Old 05-22-19, 08:01 AM
berner
Quoted: 300 Post(s)
Liked 33 Times in 27 Posts
On two occasions I've had flats that were tricky to track down. Eventually, I found the problem was at the stem itself. Nowadays I check new tubes but inflating them before entering service and hang them over a door overnight to see if they hold air.
berner is offline
Old 05-22-19, 08:20 AM
Riveting
Bikes: '13 Trek Madone 2.3, '13 Diamondback Hybrid Commuter, '17 Spec Roubaix Di2, '17 Spec Camber 29'er
Quoted: 164 Post(s)
Liked 22 Times in 16 Posts
It's typically the rear because the debris (that was lying flat) gets kicked up by the front tire and is still flopping around when the rear passes over it.
Riveting is offline
Old 05-22-19, 09:05 AM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 623 Post(s)
Liked 14 Times in 13 Posts
I've had a very slow leak (from a tiny piece of wire). I had to submerge the inflated tube in the bathtub, then go around it and wipe off the small attached bubbles with my fingers. At the puncture, a small new bubble would form in 15 or 20 seconds, very slow. I then wipe it off and see that another new bubble appears there. It's hard to find. This would be too slow to make a "shhhhh" hissing noise while on the bike, though.
Most punctures can be found by holding the inflated tube up to your cheek, you can feel and/or hear the air leaking. Or they spit out a stream of bubbles under water.
rm -rf is offline
Old 05-22-19, 09:22 AM
curbtender
curbtender's Avatar
Quoted: 502 Post(s)
Liked 13 Times in 12 Posts
Sometimes the seal at the base of the stem tears. Try the water test and move the stem around some.
curbtender is offline
Old 05-22-19, 09:23 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2507 Post(s)
Liked 55 Times in 33 Posts
How could it be a "high pressure only leak" when the tire was "dead flat"? At some point, low pressure air leaked out, right?
I've had a couple of tubes that kept going flat, with no bubbles in the bucket, but I just tossed the tube rather than spend time on it. I think it had to be the stem though.
wphamilton is offline
Old 05-22-19, 11:35 AM
DaveLeeNC
Quoted: 178 Post(s)
I have decided that this pretty much had to be a stem/valve problem.
In retrospect I probably could have just put air in the tire and continued on the ride - an irritating thought.
dave
Old 05-22-19, 12:56 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3034 Post(s)
Liked 115 Times in 93 Posts
one time I was about 2 miles from home on my 17 mile commute & I heard the front tire start leaking air. eyeballed a cozy grassy spot next to a church to swap the tube. as I approached the grassy spot, the leaking air sound stopped. the tire was pretty soft but I wasn't riding the rim. wound up taking out the tube which had plenty of air in it. no sign of debris or tube damage. put a new tube in, rode home & trashed the old tube. God works in mysterious ways ...
rumrunn6 is online now
UnsafeAlpine
Foo
22
10-18-09 10:16 PM
merlinextraligh
"The 33"-Road Bike Racing
100
06-12-09 04:53 PM
dalexand
Great Lakes
0
03-02-08 07:26 PM
