René Hubris Treat-a-Trek
Old 06-15-19, 07:39 AM
unterhausen
Randomhead
Liked 33 Times in 30 Posts
looks good. Good penetration where it matters, got a little cold around the edges. Smooth and no pinholes. The gasflux bronze is really nice to work with. A lot of people suffer with lfb they get from the local welding supply, who knows what is in that stuff, lots of pinholes. My first canti boss fixture was a flat piece of metal that I cut a slot in by hand. Worked pretty well.
I'm pretty sure I have told people they could use something like the turbo torch, air/propane. People usually want to use a regular old plumbing torch, which doesn't get as hot. But the issue is that the less heat you have, the more likely you are to overheat things, which seems counter intuitive. It sounds like you have a lot of brazing experience, so that's not as much of an issue. I'm pretty sure you can drive a rosebud with a 5l/min oxygen concentrator. Doug Fattic talks about rosebuds, there is a oxy/propane thread near the top of the framebuilding forum right now.
The problem with not using glasses is that you will get cataracts.
unterhausen is offline
Old 06-15-19, 11:55 AM
scarlson
Bikes: Ron Cooper touring, 1959 Jack Taylor 650b super touring tandem, Vitus 979, Joe Bell painted Claud Butler Dalesman, Colin Laing curved tube tandem
Quoted: 46 Post(s)
Liked 29 Times in 22 Posts
When I did my first frame work, for my buddy Chip up in Vermont, he got me some lfb (low fuming bronze) from his Harris guy. I told him to get me the same spec as the Gasflux C-04 but he returned with something different so I had to buy the Gasflux rod from Framebuilder Supply. The commonly-sold lfb is RBCuZn-C, which is all the Harris guy could get. The Gasflux C-04 is RBCuZn-B. The difference between these specs is that -B has nickel and -C doesn't. In addition the Harris RBCuZn-C doesn't list lead or manganese in the composition either. I've never tried to do bike stuff with the RBCuZn-C.
scarlson is offline
Old 06-17-19, 03:59 PM
bark_eater
Bikes: Road ready: 1989 Centurion Sport DLX, "I Blame GP" Bridgestone CB-1. Projects: Yea, I got a problem....
Quoted: 161 Post(s)
Quick question about Mapp gas Turbo Torches. Would a bigger "Tip" burning more gas be better for doing brass brazing jobs like cantilevers?
Victor Turbo Torches have interchangeable tips. The largest is a 1" T-6. The specs are here:
  • T-6 tip pipe sizes (Soft Solders): 1-1/2" - 4" (38 - 102 mm) for Propane
  • 1-1/2 to 6" (38-152 mm) for MAP-Pro
  • T-6 Pipe sizes (Silver Brazes): 3/4" to 2" (19 - 50 mm) for Propane
  • 3/4" to 4" (19-102 mm) for MAP-Pro
  • T-6 tip gas flow: 2.10 scfh @ 24 psi (Propane)
  • 2.5 scfh @ 42 psi (MAP-Pro)
The 1/2" T-4 looks to closer to a standard torch tip specs:
  • T-4 tip pipe sizes (Soft Solders): 1/4" to 1-1/2" (6.4 - 38 mm) for Propane
  • 1/4" to 2-1/2" (6.4-64 mm) for MAP-Pro
  • T-4 tip pipe sizes (Silver Brazes): 1/4" to 3/4" (6.4-19 mm) for Propane
  • 1/4" to 1-1/4" (6.4-32 mm) for MAP-Pro
  • T-4 tip gas flow: 0.39 scfh @ 24 psi (Propane)
  • 0.48 scfh @ 42 psi (MAP-Pro)
bark_eater is offline
Old 06-17-19, 10:42 PM
gugie
Crapmaster Emeritus
gugie's Avatar
Bikes: JP Weigle'd Raleigh Competition reconstruct, 73 Raleigh Competition 650b'ed, 96 Bike Friday NWT, 83 Lotus Classique, 78 Centurion ProTour, 73 Raleigh Grand Sports
Quoted: 2216 Post(s)
Liked 45 Times in 34 Posts
I'm not an expert on tip variation, but for brass on cantilevers, I was taught that you want a tight flame and get it in close - I think a smaller tip keeps the meat just where you want it without overheating the rest of the tube. But note that I'm basing this on an OA setup.
gugie is offline
Old 06-18-19, 06:04 AM
bark_eater
Quoted: 161 Post(s)
Poking around I found a BTU calculator that gives the following with Propylene and the different flow rates.
T-6 5,927.5 BTU
T-4 1,138.08 BTU
I'm still not sure what it all means, but I've read about "hearth brazing" with propane which seems to be a lower temperature, high BTU process.
Old 06-18-19, 07:57 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 657 Post(s)
Liked 55 Times in 41 Posts
T-6 5,927.5 BTU
T-4 1,138.08 BTU
Hearth brazing uses a brick enclosure to reduce thermal conduction to the air and keep the work piece temperature up for faster and smoother brazing. It's essentially a cross between furnace brazing and torch brazing.
TenGrainBread is online now
Old 06-19-19, 03:18 PM
scarlson
Quoted: 46 Post(s)
Mine's got about a half inch nozzle, so probably similar to the T-4 tip. It seems like it consumes more gas than half a pound per hour, but I have no idea what pressure the regulator (and yes, the shutoff of the cheap turbotorch I have does have a regulator, not just a needle valve) is putting out.
I got the canti posts pretty hot for a longer time and kept the heat on the frame to a minimum, just drawing it over until the bronze flowed well and I achieved proper penetration. I used this technique because I knew the posts had the most thermal mass, so they'd require more time to get up to temp, and it's less critical if you overheat whatever mild steel they are made of. I'd think you wouldn't want a tip that's larger than the posts, if you wanted to use this technique.
Ron Cooper has spoken about his time at Gillot's and mentions that the old guard learned to braze on a coal-fired forge. Oven brazing was also used by Rudge in Nottingham (see video, about 5:00). These were thicker walled tubings no doubt.
I am trying to do things similar to what I've seen framebuilders do with oxy-fuel. With a little adaptations in technique, it seems acceptable. I see a similar heat-affected area to what I've seen from professionals.
scarlson is offline
Old 06-25-19, 08:01 PM
scarlson
Quoted: 46 Post(s)
I raked out the fork using a hastily-made plywood tool I created with a jigsaw. It went ok. Offset (rake) is now 70mm. I overshot my goal a little, but it should be similar to the Soma Grand Randonneur, with about 30mm trail.
Then I did the braze-ons. First, canti posts.
Then, the low rider eyelets.
Now I am on to little bits and bobs. I have cable stops and bottle bosses and fender mounts and other stuff that I've done but haven't photographed yet, plus a little surprise that is NOT finished yet; I will post about that later after I've done it!
scarlson is offline
Old 06-25-19, 08:04 PM
scarlson
Quoted: 46 Post(s)
Originally Posted by jeirvine View Post
Could you post pictures of the blocks and results? I'd be interested in doing this on a bike or two.
Thanks,
-J
Here at long last, I have not forgotten about you
Chainstay squeezing blocks, I filed them with the raspy part of a cheap 4-way file, which is a little domed so it helped to make a round divot. I made the inner one flatter because, well, I wanted the inside of the chainstays flatter.
And here's the resultant squashed chainstays. I probably could have taken better care of the outside to not indent it so much, but I think it will be just fine. My Colin Laing tandem is the same way from-factory and it looks fine.
scarlson is offline
Old 06-27-19, 11:10 PM
scarlson
Quoted: 46 Post(s)
Little bits and bobs
Cable housing stops, I brazed with a nice low-buck jig. Basically it is a 1/4-20 socket head cap screw (For those continental types, an M6x1 would also work) stuck into the housing stop and then clamped to the frame with a hose clamp. This allows for good view when positioning and easy brazing without things moving around. These cable stops were put on top tube and downtube with Harris Safety-Silv 56. I also removed the original housing guides and saved them for another build. Hey, they're nice looking. Just not the direction I'd like to go with this one.
I went kind of crazy with the rear fender mounts. First here is the upper mount on the brake bridge. I wanted to preserve the cool Trek brake bridge, which looks to be brazed out of several pieces with a through-tube. I used too much silver and I disgust myself but it is well stuck on there. Basically it's just a stainless donut with m6 threads. I tore the donut out of a clamp for high-performance liquid chromatography (HPLC) valving. Again, science junk is the best junk. Again this is silver brazed with Harris Safety-Silv 56. None of the original brazing filler is melting when I do silver temps. I think I read somewhere that old Treks are made with either silver or nickel-bronze, which basically are the two I'm using here. It looks like mostly bronze, in the work I've uncovered.
The chainstay bridge had no hole and no tube. I put a nice non-threaded tube in. This will allow me to do some experimentation with fender mounting, where a threaded mount would restrict me more. I want to try a wingnut and bolt to perform the same role as the Velo Orange Spring Thing, allowing me to remove the rear wheel without deflating the tire. Or maybe an entire fender that removes with wingnuts for rinko. The concept is not fully thought out, but a smooth hole with built-in washers should be future-proof. All the washers and tubing I used were stainless, so I brazed with Harris Safety-Silv 56. It was a fun exercise.
I had bought some rear brake cable housing stops (to go between-chainstays above rear canti) from Framebuilder Supply, so I brazed one of them on using bronze. These are really hard to braze with the turbotorch, as it turns out. I did OK but this is one of those things for which I'd really have preferred oxy/fuel. It's on there solidly but it ain't pretty. Luckily for the hobbyist on a budget, this is also easily supplanted by a cheap thing from Surly or an expensive thing from René Herse, that hangs on the seat binder bolt.
Finally waterbottle cage mounts. These are easy!! No jig, just drill a 1/4" hole, flux up the mount, tap it in with a hammer and a block of wood, square it with its mate and the frame so the cage isn't lopsided, heat it up until the flux looks good, dab in silver, and you're done.
scarlson is offline
Old 07-17-19, 03:12 PM
scarlson
Quoted: 46 Post(s)
A little something for you koolaid fanatics
I'm making another thing to braze onto my Trek. This one is very high on the BQ koolaid scale.
"Broaching" the subject .... (bad machinist joke right?!)
Ahem. This is a broach. Basically a really hardcore saw or file, for cutting a square hole. You press it through a pre-existing hole and then add a shim. Eventually you come to have a large collection of shims, if you're wanting to square off the ends of a pocket made with a round endmill.
In this case, I'm making this square slot on the diagonal through a piece of stainless steel square bar. Can you guess what I'm making?
Think about what Jan Heine dreams about. Think Rebour drawing. Any guesses?
scarlson is offline
Old 07-17-19, 03:56 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1209 Post(s)
Liked 75 Times in 50 Posts
Decaleur?
tyrion is offline
Old 07-17-19, 04:02 PM
scarlson
Quoted: 46 Post(s)
Originally Posted by tyrion View Post
Decaleur?
Nope! Try again! Even more of all that Frenchness than a decaleur.
scarlson is offline
Old 07-17-19, 04:45 PM
nlerner
Quoted: 1094 Post(s)
Liked 15 Times in 14 Posts
Baguette holder?
nlerner is offline
Old 07-17-19, 04:51 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 964 Post(s)
Liked 17 Times in 15 Posts
Seat tube shifter mount for BB dyno?
clubman is offline
Old 07-17-19, 05:13 PM
scarlson
Quoted: 46 Post(s)
Baguette holder?
Hmm, I should make one of those...
Close!! (it does go on the seat tube)
scarlson is offline
Old 07-17-19, 06:58 PM
t_e_r_r_y
t_e_r_r_y's Avatar
Quoted: 40 Post(s)
Liked 17 Times in 11 Posts
my guess!
t_e_r_r_y is offline
Old 07-17-19, 07:25 PM
scarlson
Quoted: 46 Post(s)
DINGDINGDING We have a WINNERRRR
Yep, I'm doing the thing. This is what too much Bicycle Quarterly will do to you.
scarlson is offline
Likes For scarlson:
Old 07-17-19, 07:27 PM
t_e_r_r_y
t_e_r_r_y's Avatar
Quoted: 40 Post(s)
make me a clamp on one, please!
Old 07-17-19, 07:56 PM
TenGrainBread
Quoted: 657 Post(s)
Super cool. Definitely want to try a suicide shifter FD one day.
Likes For TenGrainBread:
Old 07-17-19, 10:22 PM
scarlson
Quoted: 46 Post(s)
So I had already been thinking about making a clamp-on version, because my Jack Taylor lacks anything remotely original in the front derailleur department. The thing to do is to braze the square tubing to an oversize tube cut from an old MTB, braze in some clamp bolts, and bob's your uncle, as they say.
It would be nice if someone would mass produce one. I hear all the time that people want things like these, Nivex rear derailleurs, dropout chainrests you can shift onto, the list goes on. BQ readers want to be like Jan! I suppose the problem with this design is that it requires custom filing the slot that the handle goes through to your particular "throw" distance. This becomes your "limit screws" of sorts. A screw based limiter could be attached, but it's more steps and more complexity.
They are really hard to make. I wanted the derailleur to be all stainless to avoid necessitating any hydrophobic rust protection (oil or grease), which would attract dust. The stainless square tubing I could find in a decently robust wall thickness said it would fit my 3/8" square inside. However, when I bought it, I found that it has a visible welded seam running down the inside. This meant a lot of file work to remove the weld, which was also harder than the base metal. This was drudgery. Eventually I also filed down the pushrod a bit.
I have to think that René Herse must have used a square broach to make this hole the proper size and uniformly square so he could use milled square stock. I could too, and it would make cleaning up the inside of the tube really quick and easy. But square broaches are expensive. I think I'd be paying between $50 and $100 for a used one, making it the most expensive cutting tool I own, although it's a monotasker. Doesn't feel good.
I've got other ideas, too. We have a waterjet cutter here, so if I had any kind of measured drawing of a Nivex derailleur I could make reproductions. It's only stamped sheet metal after all. Ironically, that will probably require less initial investment in tooling than mass-producing this thing would!
scarlson is offline
Likes For scarlson:
Old 07-17-19, 11:21 PM
nazcalines
Quoted: 55 Post(s)
Why not use round tubing instead of square?
nazcalines is offline
Old 07-18-19, 12:32 AM
scarlson
Quoted: 46 Post(s)
I did have this thought. Round tubing often is available in nice seamless telescoping sizes and can be easily cleaned inside and out with reamers and drills and lathe tooling. Production is, indeed, easier. Singer did it this way. However, square locates the derailleur in torsion. The handle should indeed do this, but I thought that a "belt-and-suspenders" redundant approach was appropriate since I'll be brazing it on.
scarlson is offline
