Unusual Saddle Sore - Advice Needed
Old 06-18-19, 12:54 PM
canklecat
canklecat's Avatar
Quoted: 2771 Post(s)
Liked 141 Times in 115 Posts
Originally Posted by UniChris View Post
Yes, however, I suspect that this may weaken skin and remove protective oils, as that's effectively how it works. Showering with that several times a day to solve a specific issue before a ride a week ago contributed, I think, to a much greater general soreness during and after the subsequent ride beginning almost from the start; granted it was my longest of the season, but only by around 15%. It was successful, in that the trouble spot was okay for the ride, and I didn't develop any new ones, but it seems like it came at a cost. So my new strategy absent an issue is to only do that prophylactically once or twice in days immediately after a lot of time in sweaty shorts, and absent a specific issue not do it in days resting up before a long ride.
The good acne washes don't strip skin oils. They use gentler surfactants than most soaps. And the salicyclic acid helps remove dead skin and schmumph that clogs pores. Using this inexpensive stuff, I've had far fewer problems with psoriasis on my hands and scalp and fewer minor skin irritations around the groin caused by irritated hair follicles.
There are harsher acne washes, but this stuff uses the same ingredients as pricey face treatments like Eucerin: primarily glycerin, sodium laureth sulfate, with the addition of salicylic acid.
For folks with sensitive skin, first try it without scrubbing -- no washcloths, loofahs, buff puffs, etc.
canklecat is offline
Old 06-18-19, 01:13 PM
UniChris
UniChris's Avatar
Bikes: 36" Unicycle
Quoted: 345 Post(s)
Liked 59 Times in 51 Posts
The thing is that salicylic acid is not gentle. It actually works by weakening skin. The effect with a facial product is less because the concentration is limited, but it's actually the very same stuff as in corn remover. Put some on your face and realize that the "tight" feeling is actually a low-grade chemical burn; that's literally how it works to strip away the dead skin and other pore-clogging gunk.
UniChris is offline
Old 07-13-19, 09:12 AM
UniChris
UniChris's Avatar
Bikes: 36" Unicycle
Quoted: 345 Post(s)
After seeing earlier issues fade away in time to get in some long rides last month, I've been being annoyed by some heat-worsened groin-crease irritation on both sides even with only taking one short ride in the past week, and with an upcoming plan for a long ride, decided to give up any pretense of dignity and try some zinc oxide diaper rash ointment.
So last night after concluding a streaming TV binge I grab the tube out of the shopping bag, and thinking of a long ago visit to grandparent's when my siblings were younger and a half asleep parent grabbed the wrong tube from the travel toiletries to squeeze onto a toothbrush, start applying my purchase in the applicable area.
It has a creamier and less greasy consistency than expected, but no matter, I rub it in to the skin.
A moment later I notice that is has a very "fresh" feeling.
Actually it kind of stings.
Not "kind of" but quite a bit.
It's then that I realize that I'm holding the new tube of salicylic acid acne wash that was the other part of the plan
That's how I ended up taking a shower at almost 3am...
No conclusion yet on the actual zinc oxide beyond wondering how it will ever wash off, kind of wonder to what degree (if any?) it differs from sunscreen.
UniChris is offline
Old 07-14-19, 09:43 AM
63rickert
Quoted: 481 Post(s)
Liked 19 Times in 16 Posts
If you get saddle sores routinely something is wrong. Goal should not be to alleviate the current round of exceptional sores but to quit getting sore entirely.
Real basic. Stand on the pedals. If not sitting on saddle no saddle sores. Version 1.1 of standing on pedals is less weight on saddle, more weight on pedals. Yes, this means you are working harder and going faster. Not a bad thing.
Most common cause of saddle sores (no, I do not know this is OPs problem) is a high saddle. High saddle means hips are rocking and butt is dragged side-to-side over the saddle. No saddle, no shorts, no chamois cream is good enough to alleviate that abuse. Instead of measuring and consulting charts and formulae and experts, have a friend make a short video of yourself riding. Camera directly behind pedaling rider. Hips should be level and sit still. If hips are rocking the source of problem is found. If camera shows hips are still, well, there is more investigation to do.
63rickert is offline
