Premium Valve Cores
Premium Valve Cores
Old 06-17-19, 05:29 PM
CliffordK
CliffordK's Avatar
Quoted: 8512 Post(s)
Liked 69 Times in 61 Posts
Originally Posted by woodcraft View Post
Do your car tires have to be reinflated regularly?
Usually every time I drive. Sometimes a couple of times between uses too.
Of course, I just got my Blazer back on the road for the first time in 4 1/2 years.
Tires, Tubes, whatever, will leak down slowly.
The thicker the tire/tube, and with the more volume the slower it will leak down.
The thinner the tire/tube, and the less volume, the faster it will leak down.
On my bike, I'll monitor the pressure regularly, but will only pump up once a month or so. But, I also let the pressure vary considerably, probably somewhere in the range of about 50 to 110 lbs.
CliffordK is offline
Old 06-17-19, 05:51 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1636 Post(s)
Liked 58 Times in 49 Posts
Originally Posted by kovacsa View Post
Thanks, Do you have the link for the site you mentioned? I was considering Presta, but my rims are Schrader. I have a feeling that Presta is better at keeping the pressure.
Google Sheldon Brown. Easy to find. Now I don't know where in the website the info might be. (Don't have time to do this now.)
Ben
79pmooney is online now
Old 06-17-19, 06:02 PM
CliffordK
CliffordK's Avatar
Originally Posted by Retro Grouch View Post
I don't think that most of that is true. Schrader valves are found lots of places besides relatively low pressure automobile tires. Trucks, for instance commonly use around 100psi tire pressure and they use Schrader valves. How about your home air conditioner? Lots higher pressure and they are expected to not leak at all.
I have to agree, I can't imagine Schrader valves being any worse than Presta. Plus, they have the spring to help keep the valve closed, when the Presta uses internal air pressure alone to keep it closed (plus that screw on cap which really isn't necessary).
I do like the Presta on bikes, but there really isn't a good reason.
There was a discussion recently about Continental brand tubes (maybe other brands too) that come with a stepped nut. Apparently simply turn the stepped nut upward for Schrader, and downward for Presta.
There may be other Presta/Schrader adapters, but it probably isn't necessary as long as there aren't any burrs in the hole.
Old 06-17-19, 06:14 PM
Rick
Quoted: 147 Post(s)
Liked 28 Times in 24 Posts
This is true and loss of air through the tube annoys me. I put the largest volume tube that will fit my tires in. I only loose 3psi in over two weeks this way. I purchased a very expensive touring bicycle over 5 years ago and had similar leakage as kovacsa. I have 26X2 tires and managed to put in 26X2.3 to 26X2.7 Conti freeride tubes.
Rick is online now
Old 06-17-19, 06:17 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 652 Post(s)
Liked 46 Times in 42 Posts
"It seem to be an issue with any tube I've used to date (different brands, etc)."
Somehow I don't think that they are all defective. One or two here and there, maybe. All of them? Nah.
dsbrantjr is offline
Old 06-17-19, 06:47 PM
CliffordK
CliffordK's Avatar
Oh, another thing. Sealant can make a mess out of just about anything.
Not saying it is bad, but just one has to be prepared. Remove and clean the core and stem?
Old 06-17-19, 07:14 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1160 Post(s)
Liked 31 Times in 23 Posts
Originally Posted by Last ride 76 View Post
You have presta valves that require threading the chuck onto the valve stem? How strange, I've never seen one.
You're right I should have said pushed onto the valve stem. I don't have to do that when I pump a Schrader valve tire with my air compressor.
Actually, I take it back. You thread a needle so I don't think my use of that word was incorrect at all.
Retro Grouch is offline
Old 06-17-19, 09:18 PM
FiftySix
where's the gas tank?
FiftySix's Avatar
Bikes: Norco Cityglide, Schwinn Jaguar, Schwinn Willy
Quoted: 223 Post(s)
Liked 94 Times in 72 Posts
I have had valve cores leak, but it's very rare. Usually you can see a valve core fail the water dunk test by the bubbles coming out.
Of course, one could buy a set of the metal valve caps with the seal inside the cap if your really concerned about cores leaking.
Permeability of tubes was mentioned as well. I can say that in my limited experience with thick thorn resistant bicycle tubes that they hold air much longer than the standard thin tubes.
FiftySix is offline
Old 06-18-19, 05:52 AM
freeranger
freeranger's Avatar
Quoted: 36 Post(s)
Liked 21 Times in 14 Posts
I have had different brands of tubes lose air at different rates. My wife's road bike (presta valved tubes) loses air quicker in the front tire than the rear. Neither tube has been patched, neither has any sealant, tires and rims are free of anything which would cause a leak. Isn't major enough to replace the tube which loses air more quickly, but it's noticeable after the bike might sit for a while. The only thing I can figure is that the tubes are dif.brands and lose air at dif.rates (don't remember brand names). Maybe you could try a different brand of tube?
freeranger is offline
Old 06-18-19, 08:45 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 537 Post(s)
Liked 19 Times in 16 Posts
Usually, a leaking Shrader valve is an indication it just needs to be tightened into the stem a bit. A core removal tool can be used to do it.
Dan Burkhart is offline
Likes For Dan Burkhart:
Old 06-18-19, 11:13 AM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 3895 Post(s)
Liked 61 Times in 46 Posts
If you want the ultimate in simple operation presta heads, this is it. Easier than ANY Schrader chuck. Before first use, you set the rubber washer compression.
Then you just pop it on and air it up. No levers, no screwing,
LesterOfPuppets is offline
Old 06-19-19, 05:49 PM
Last ride 76
Last ride 76's Avatar
Quoted: 138 Post(s)
Liked 29 Times in 27 Posts
3
R G -
I would not consider uttering "incorrect" and thereby contradict you, but might we not be able to agree that certain less erudite folk,* find "threading" a somewhat unusual usage of the term in the example above ... For is one not actually using thread when one "threads a needle"? Thus perhaps one might use in this way, the phrase "chucking a valve", to describe the action of enclosing a valve stem with a chuck, prior to pumping?
Yours in pedantry, Last
*Amongst whom I must, with downcast eyes, take my rightful place.
Last ride 76 is online now
Old 06-19-19, 06:06 PM
Last ride 76
Quoted: 138 Post(s)
I would imagine that a gentleman going by the name of "Retro Grouch" is probably familiar with a Silca type pump head.
Regarding ease of inflation...I think that was his point, if one has a hose that is connected to an on demand compressor, like at a gas station, Schrader heads/valves are quicker, potentially, as they provide instant inflation just by making proper contact, whereas the Silca type as pictured would require an additional mechanism to prevent the air from escaping when not inflating the tube. ( Think NASCAR pit stop for reference.)
Old 06-19-19, 06:49 PM
Last ride 76
Quoted: 138 Post(s)
Originally Posted by baconshakes View Post
Instantly inflates Presta or Schrader just by making proper contact...
Aha, winner, winner, chicken dinner. I'll keep my eyes open for a used one.
Old 06-20-19, 12:36 AM
rollalongnow
My wheels have schrader valves and I debated a long time using grommets to go presta. Then I stumbled on the Continentals with the metal stem. I’ve been very pleased with the results holding pressure. Maybe try a couple. They are not for 28 as the label appears to indicate when you look at it. I used it with 32s, and when I tried to put them into a 28 the tube was too large and had folds so I stuck with the 32. May have been that specific tire, but it was a pretty good size fold for the 28.
rollalongnow is offline
