Early 70s TA Cranks...Can I mod to Mid Compact?
Old 06-18-19, 09:32 AM
chainwhip
Quoted: 97 Post(s)
Liked 12 Times in 9 Posts
Recently bought this:
1973 Raleigh Competition
_________________________________________
Exploring if I could fit a 36T 110bcd x 5b inner ring to convert this from a 52-42 to a 52-36? :
Original TA 52-42 Crankset
Thanks for input.
chainwhip is offline
Old 06-18-19, 10:48 AM
noobinsf
Bikes: '04 Felt SR91, '82 Univega Competizione, '72 Motobecane Grand Record, '72 Puch Bergmeister
Quoted: 313 Post(s)
Liked 13 Times in 11 Posts
No, you can't -- this crank has three holes and a 116mm bcd, so it's not compatible with the chainring you mentioned. You'll need to try a different crank, unfortunately. Cool bike, by the way...
noobinsf is offline
Old 06-18-19, 11:01 AM
Ex Pres
Ex Pres's Avatar
Quoted: 344 Post(s)
Liked 7 Times in 6 Posts
A 116BCD will accept a 36t ring, maybe even a 35t - IF YOU COULD FIND ONE.
(You won't)
Ex Pres is offline
Old 06-18-19, 11:06 AM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1055 Post(s)
Liked 40 Times in 32 Posts
Well, there's this:
116 bcd rings
If you can get the price down to say $50 by ordering a batch of 35T rings, you might make a few new friends here.
Reasons to be cheerful!
non-fixie is offline
Old 06-18-19, 11:10 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 343 Post(s)
Liked 44 Times in 29 Posts
Beautiful TA Crank. Sell it and buy one more suitable to your needs.
Moe Zhoost is offline
Old 06-18-19, 12:10 PM
verktyg
verktyg
verktyg's Avatar
Quoted: 502 Post(s)
Liked 20 Times in 18 Posts
Scarce as hen's teeth
About 10 years ago, I changed the TA "Pro 3 Attaches" chainrings on my late 60's Bertin C37 from 52-42 to 50-37.
36T was the smallest chainring TA made for these cranks and after months of searching I finally came up with a 37T.
You can probably find a 36T 116mm 3 bolt chainring but it needs to be arced to fit closely on the crank web plus the holes counter bored in the rear. These cranks take special chainring bolts with a large diameter head and a smaller diameter than standard chainring bolts. They tend to be brittle.
They break EASILY if overtightened and replacements are hard to find (been there - done that). I wouldn't trust those bolts just to hold a non fitted (non arched) chainring onto the back side of the large ring.
verktyg
Things aren't always what they seem... Don't believe everything you think!
Chas. ;-)
verktyg is offline
Old 06-18-19, 12:14 PM
chainwhip
Quoted: 97 Post(s)
116bcd
Thanks.
Didn't feel I was getting an accurate bcd measurement, but it looked larger.
Completely missed my 3 vs. 5 oversight
Old 06-18-19, 12:25 PM
chainwhip
Quoted: 97 Post(s)
verktyg
Sounds like I'd be wise to learn from your pain.
Beautiful bike!
Old 06-18-19, 01:49 PM
jeirvine
jeirvine's Avatar
Bikes: '72 Moto Grand Record, '72 Gitane tandem, '72 Raleigh Super Course, '73 Raleigh Gran Sport, '73 and '76 Colnagos Super, '76 Fiorelli Coppi, '78 Raleigh SBDU Team Pro, '78 Trek 930, '81 Holdsworth Special 650B, '86 Masi GC, '87 Panasonic DX5000
Quoted: 427 Post(s)
Liked 17 Times in 10 Posts
Well, there's this:
116 bcd rings
Couldn't hurt to ask! 35T and of aluminum instead of titanium, and the price may be reasonable.
jeirvine is offline
Old 06-18-19, 01:53 PM
seypat
Quoted: 920 Post(s)
Liked 39 Times in 36 Posts
If you wanted to keep it French, you could go with a Stronglight 99. 86BCD will go down to 32T, I think. Might go to 30T. There is a 99 sitting on the Bay currently as well as some cheap rings including a 36T. Sakae/SR also made a 86BCD crank as well. Some of those might be available as well.
seypat is offline
Old 06-18-19, 02:18 PM
TenGrainBread
TenGrainBread's Avatar
Quoted: 655 Post(s)
Liked 54 Times in 40 Posts
Search on eBay for Stronglight Touring Sport chainrings. This was another 3 arm 116bcd crank of the era and I find that smaller chainrings for this are more common. They'll fit the TA Pro cranks you have but you will have to drill the chainring holes larger to accept the TA chainring bolts. This is what I'm currently running on my Sports Tourer.
TenGrainBread is offline
Old 06-18-19, 02:19 PM
crank_addict
crank_addict's Avatar
Quoted: 1062 Post(s)
Liked 17 Times in 12 Posts
As mentioned above, 36t is the smallest to fit but a challenge finding TA branded ring. Though chances are better finding another brand 3 bolt and modify to attach. I like the minimalist style and would certainly attempt a modified ring before changing the crank.
There are adapters 3 hole to 5 (possibly 6 as well) hole but unfortunately defeats your purpose. Those adapters are for 45 tooth.
This leads why the TA Cyclotourist cranks were and still desired today.
Also consider the Stronglight 49D and others with the 50.4 BCD, plus there's adapters for other large BCD rings.. Great options and flexibility.
crank_addict is offline
Old 06-18-19, 02:59 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Just for the record: Miche makes 35T rings with a 116mm BCD. I just bought a couple. €15 a piece. Five holes, so no use to the OP, but if you're going to have them made for lower gearing, one might as well go for the smaller tooth count.
Old 06-18-19, 03:26 PM
Feldman
Quoted: 38 Post(s)
Five possibilities in the real world: Velo Classique in Falls Church, VA, Peter White Cycles in New Hampshire, American Cyclery in San Francisco, Bicycle Specialties in Toronto, St. Johns Street Cycles in the UK. St. Johns has a good website, others are all reachable by phone. The smallest ring you can use with that crank is 36 t. I ran one as a 36/46 for awhile. Good cranks!
Feldman is offline
Old 06-18-19, 05:17 PM
63rickert
Quoted: 478 Post(s)
Liked 18 Times in 15 Posts
I have two of the supposed elusive 116bcd 3 pin 36T rings. Took very little to find them. It's collecting. Work at it.
Stronglight had rings that fit. There are also steel rings to same pattern. 38T to pattern is far more plentiful if that will work.
63rickert is offline
Old 06-18-19, 05:20 PM
juvela
juvela's Avatar
Quoted: 1619 Post(s)
Liked 30 Times in 27 Posts
The Stronglight model 99 & 99bis chainset goes down to 28T, both early and late type.
Anecdote -
Years ago I would run into Howard Sutherland trundling about the streets of Berkeley on his dark blue Jack Bobson. I once inquired of him as to the T.A. Trots Attachees chainset it wore. He replied that he liked it very much. High praise coming as it did from "The Mechanic's Mechanic."
juvela is offline
Old 06-18-19, 06:05 PM
Slowride79
Quoted: 15 Post(s)
The solution to your problem is not a scarce chainring or another crankset but another bike!
Here’s my 1973 that is almost finished (thanks Roger! &#128521
Slowride79 is offline
Old 06-18-19, 06:17 PM
SamSpade1941
SamSpade1941's Avatar
Quoted: 359 Post(s)
Liked 12 Times in 10 Posts
OP if you get a cyclo touriste you can pretty much do any ring combination you want.
SamSpade1941 is offline
Old 06-18-19, 06:34 PM
TenGrainBread
Quoted: 655 Post(s)
Part of the reason these cranks are so loved is the Q factor is very low. The arms are almost parallel to the bike frame.
Old 06-18-19, 06:50 PM
chainwhip
Quoted: 97 Post(s)
Thanks for all the input so far...
I appreciate all of your leads and comments.
A lot to chew on.
Old 06-18-19, 06:56 PM
chainwhip
Quoted: 97 Post(s)
Nice Jubilee RD.
Black cloth bar tape?
22.5" frame?
Very well kept specimen.
Garage queen? j/k
I'm really enjoying the ride quality of this model Raleigh.
Just driven to tinker, I suppose.
Old 06-18-19, 08:02 PM
Slowride79
Quoted: 15 Post(s)
Originally Posted by chainwhip View Post
Nice Jubilee RD.
22.5" frame?
Garage queen? j/k
I was just joking that it’s an excuse to buy another bike
i think a TA cyclo tourist would look great on your bike. Your choice but I would save the original crank in case you or next owner want to change back again.
yes mine is 22.5” , yes black Tressostar cloth tape. Found it in pretty rough shape but thanks to good people in better shape now. https://thecabe.com/forum/threads/‘7...tition.148754/
Old 06-18-19, 08:14 PM
Slightspeed
Slightspeed's Avatar
Quoted: 490 Post(s)
Liked 67 Times in 50 Posts
Tale of three cranks. I bought this Peugeot PR10 back in August with a Stronglight TS with a wonky pedal thread and some kind of acid etching damage on the ring (@ about 1 o'clock in below picture). I had a Sugino compact 52/34 laying around, so on it went a as an experiment. I liked the way it rode, but had several inside chain drops, even after repeatedly adjusting FD. It may have been a chain too long problem. I came across a great deal on a Stronglight 99, 52/40, which restored its Frenchness, and rides pretty well with the same 28t freewheel. I know smaller rings are available for the Stronglight 99, so I may be on the lookout for that. Lots of options, good luck with yours.
As bought, Stronglight TS (50/40 ?), broken (missing) Simplex FD, 24t freewheel.
Sugino GT compact 52/34, added Shimano Exage FD, 28t freewheel. I like the look of the Sugino crank.
Current set up, Stronglight 99, 52/40, IMO, best looking of all 3 cranks.
Slightspeed is offline
Old 06-19-19, 06:16 AM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Palo-Alto/Falcon
Quoted: 171 Post(s)
Liked 11 Times in 7 Posts
Agreed, it's a lovely design. I had always thought that perhaps, having only three arms, it would be more prone to lateral flex. My wife had a set but her bike was stolen. Any chance you can live with a somewhat taller gear?
tiger1964 is offline
Old 06-19-19, 08:19 AM
Salamandrine
Quoted: 1713 Post(s)
Liked 32 Times in 22 Posts
I always loved these cranks to look at. The fact that they spec'd smaller diameter bolts on a 3 arm crank though -- that is just so very French....
I wonder if the same people making titanium chainrings for these are also making replacement bolts? It would make sense. A good machinist should be able to make them, but the cost would be pretty high.
BTW it's very cool that someone loves these enough to make Ti chainrings just for these now rare oddball cranks.
Salamandrine is offline
