Show Your Vintage MTB Drop Bar Conversions
#6451
High Plains Luddite
Thank you for sharing this information. I bet I'm not the only one who learned from this.
I've heard of 1" threadless but haven't seen it before. Recently I was looking at a '95 Trek 990 in my size on craigslist. Like yours, it had its original matching rigid fork (always highly desirable to me) and a stem that looked a lot like the one on your Stumpjumper. I figured someone had used a threaded-to-threadless converter and liked the "slammed" stem look. I would have wanted to put drop bars on it and would have had no idea what I was getting into. Fortunately for me, the seller was asking WAY too much for the bike, but it was fun to think about for a while.
#6452
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
MTBs started using threadless and/or 1-1/8" head tubes way way way before they moved to road bikes. In the 90s it seems like it was the wild west as far as what spec you would find on any particular bike. On the same model years you might find a quill stem with an oddball diameter on one bike, but on a different make you'll find 1" threadless. It was wild.
#6453
What are thoughts on using one of those with a shim?
#6454
Quoted: 76 Post(s)
Liked 76 Times
drops will give you a bunch more hand positions, which is great for those longer rides. personally i run drops higher than i would flats on these bikes, like so that the drops are about where my hands would be height-wise on flats. this gives me a more comfortable up-right position when riding on the tops of the drops, or in the hoods, and i'm still comfortable when going into the drops
#6455
Quoted: 141 Post(s)
Liked 9 Times
follow up on post 6414, some shots of a drop conversion in action. A freind wanted to do the new adventure cycling Arkansas high country loop. https://bikepacking.com/routes/arkan...orthwest-loop/
Since I don't own a real gravel bike, and did not want to ride 240 miles on a flat bar, took the Gary Fischer Marlin. Used my regular panniers. We did it in three days. I lived. The last day riding home was fifty miles of rain, which felt really good on the 150+ mosquito bites. Really, we counted when the swelling went down enough to see them. The other guys got about ten or so each.
DISTANCE
242 Mi.
(389 KM)DAYS
3-4% UNPAVED
51%% SINGLETRACK
0%DIFFICULTY (1-10)
4% RIDEABLE (TIME)
100%TOTAL ASCENT
18,920'
(5,767 M)HIGH POINT
2,511'
#6456
Bikes: 3 Frankenbikes (Stumpjumper, Karakoram, Trek 930), Fuso, Tarmac Pro, '72 Fuji Finest, Soma Saga, El Diente, Cannondale tandem, 2 mountain bikes, more...
Quoted: 13 Post(s)
FYI...
How to get a Road Front Derailleur to work on a Mountain Bike frame...
The 73 mm wide MTB bottom bracket shell prevents use of some road front derailleurs as they are designed a 68 mm road BB bracket shell. This problem is most common for folks trying to use brifters (STI, Ergo Shifters, Double Tap) which work best when used as a complete system including the front derailleur.
The fix I used for this issue was to use larger clamp for the FD and fashion a shim using pieces of old inner tubes to make a shim which would push the derailleur about 3mm farther to the right. It just took a bit of patience and some contact cement...
-OR- for those who want an engineered solution
Check out this Jtek Eccentric Shim:
Jtek Eccentric Shim for Front Derailleur
Disclaimer: I have no association with Jtek but I do think this product is useful for making drop bar mountain bikes.
#6457
Geez, this thread is fantastic! Love the creativity and practicality in these builds. Good on yas!
I’m in the beginnings of putting together my ‘97 MUSA Trek 820 from my college days as a drop bar all-rounder. My 4yo son wanted to paint it so I stripped everything off, stripped the frame, and Spencer and I gave it a pretty good rattle-can paint job. Slowly going back together, and it’s been really special to do this with Spence. Hope when it’s done it rides half as good as some of your builds look!
#6458
Quoted: 823 Post(s)
Liked 1,395 Times
Older 24-in wheel Trek 800 built up with MicroNEW 3x7 brifters for my 12 year old son.
#6459
Very cool, Rusty! Little man will have a blast!
Working on sorting out the cockpit on the 820. These are Soma Portolas, and they’re a new shape for me. Fiddling with lever position... and the little doodads where the cable housing meets the levers seems an odd size. Housing is loose in the nipple but a housing end seems too big to fit right. Thinking about cable routing too. Both shifter cables run the bottom tube. Rear brake on the top tube. Advice on setting things up appreciated!
Still deciding on what to run for a rack / basket / bag up front. I have Carradice Barley and Pendle saddlebags that I considered hanging from the bars, but with the non-aero levers and the really tall stem, not sure this will work. Leaning towards a rack with either a basket and bag or a rando bag. Thoughts? Anyone have a canti-mount front rack they’re not using?
Bikes are fun, eh?
Bikes are fun, eh?
Likes For RyanAK:
#6460
Quoted: 76 Post(s)
Liked 76 Times
Bikes are fun, eh?
Bikes are fun, eh?
not sure what to tell you on the rack/bag situation, i'll be running a rack on mine for sure. i kind of have my eyes on the blackburn bootlegger rack at the moment, i like a wide rack.
bikes are super fun
#6461
Going to stay with the original Shimano Altus 3x7 for now. Well... Altus except for the Alivio RD. Everything is in good shape now that it’s all been removed and cleaned/maintenance done. Shimano 8sp bar-ends. I originally thought to have the housing exit the bar tape from the drops after a few wraps, but wonder about clearing whatever rack/basket/bag I run. A basket or big-ish bag may get in the way of the big loops running forward and turning back to the downtube. But maybe not...
hmmm....
hmmm....
Likes For RyanAK:
#6463
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 530 Post(s)
Liked 1,004 Times
#6464
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+10 Tire width will get you. 1980s rigid frame MTBs are plentiful, at reasonable to low pricing. And they tend to have more reasonable top tube length. Later MTBs got really long top tubes, making them more of a challenge to convert to drops and get them to fit.
To get cantilever brakes on a road bike, you are talking touring bike, and touring bikes tend to be at the higher end price wise. I've got Fat Franks on one of my conversions, those tires are 2.35 inches wide which is approximately 60mm wide. I haven't seen a road bike that can handle anything close to that.
I have used my Prologue racing bike with 25mm tires on packed gravel trails. Just have to keep your awareness up. Obviously not ideal or anything I would recommend. Had I lost control and wiped out, I would be kicking myself for sure.
#6467
Quoted: 16 Post(s)
Liked 9 Times
Old roadbikes are always being given to me or on the curb but I dont have a need for another roadbike. Now a gravel grinder or old mtb i definitely have a need for.
#6469
Quoted: 1136 Post(s)
Liked 650 Times
Finished this drop bar conversion on a 1999 Schwinn Homegrown hardtail (made in Portland, Oregon).
Fork: Shimano Pro XCR
Wheels: XTR M950 hubs with Bontrager Valiant rims, SimWorks Homage 26x1.95 tires, Paul skewers
Headset: White Industries
Stem: Paul
Bars: Crust 53cm wide drop bars (made by Nitto)
Levers: Cane Creek V levers
Brakes: XTR M950 V brakes
Seat collar: Phil Wood
Seatpost: Dean titanium
Saddle: Schwinn Stinger ti rail
Drivetrain: 11sp XT 11-42 cassette, 11sp XTR rear derailleur, Profile Racing tubular chromoly crank with 40t chainring
Pedals: Crank Bros Stamp 7 platforms
Stem: Paul
Likes For TenGrainBread:
#6471
Quoted: 7 Post(s)
Liked 22 Times
Secondly, I found an old '89 Fisher (pre "Gary" Fisher) Advance on Craigslist in great shape, so I thought it would be perfect for a steel frame drop conversion.
#6474
Quoted: 7 Post(s)
Liked 22 Times
I decided single speed would be the best option at this point, as the Fisher is going to b a 1x7 conversion. I had a 38 tooth SS chainring (unused) laying around and attached it to a set of old school RaceFace Forged cranks that came off my old GT.
#6475
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Welcome.
Don't be that specific. Look around you will find lots of things to interest you and waste your time and money.
I did.
I did.
