BP & cycling?
BP & cycling?
Old 01-14-14, 06:36 AM
bruce19
bruce19's Avatar
Quoted: 837 Post(s)
Liked 79 Times in 51 Posts
BP & cycling?
Just wondering if anyone has any insight into this. My BP has always been near 120/80, maybe a bit higher on occasion. And, when I was in the hospital in July it was actually a bit lower than 120/60. But, in the past month or so it has consistently been around 137/93. I have to find a new PCP (mine moved out of the area last week) and when I do BP will be the first order of business. I realized that since I got back into cycling about 10 yrs. ago my BP has gone up not down. Is that because of aging? Why wouldn't riding 100 mi a week do just the opposite? How bad is 137/93? FWIW I feel great and have lost 12 lbs since July. But, I am told high BP has no obvious symptoms.
bruce19 is offline
Old 01-14-14, 07:27 AM
one_beatnik
one_beatnik's Avatar
Bikes: Waterford 1200, Raleigh Record converted to a single speed.
That's slightly higher than the norm, but not a lot to worry about. Go ride!
one_beatnik is offline
Old 01-14-14, 08:01 AM
RonH
Life is good
RonH's Avatar
Bikes: 2001 Litespeed Tuscany, 2018 Lynskey Helix Pro
Quoted: 519 Post(s)
Did you check it several times during the day?
When I go to the doctor mine is always around 150/90. Then after being in the examining room for 15 minutes the doc checks it again and its 125/72. At home when I'm relaxed its usually in the range of 120-128/60-70.
The LORD is merciful and gracious, slow to anger, and plenteous in mercy. - Psalm 103:8
RonH is offline
Old 01-14-14, 08:37 AM
jth1959
Go find a new PCP and ask them to do a 24 hr blood pressure monitoring. You wear the cuff around your arm and clip the monitor to your belt, it takes readings every 20 minutes during the day and every hour at night. The PCP will then be able to determine whether or not you have an issue.
I believe the criteria for meds is being over the recommended BP 30% of the time.
jth1959 is offline
Old 01-14-14, 08:43 AM
Terex
Terex's Avatar
Bikes: Specialized 6Fattie, Parlee Z5, Scott Addict
Quoted: 20 Post(s)
http://www.nhlbi.nih.gov/health//dci...BP_WhatIs.html
Terex is offline
Old 01-14-14, 09:24 AM
Dudelsack
A might bewildered...
Dudelsack's Avatar
Bikes: Bacchetta Giro ATT 26; Lemond Buenos Aires
Quoted: 80 Post(s)
Glad to get here before the conspiracy theorists show up.
As the blood pressure creeps up, the question is whether or not there is evidence of it hurting anything.
Easy things to measure are kidney function and heart size. If the heart starts to compensate by enlarging, that's not a good thing. Kidney damage is obviously a bad thing.
If there's no evidence that mild hypertension is causing a particular individual harm, therapy can be pretty conservative.
I may talk to my own PCP about ambulatory BP monitoring. It sounds like a good idea if it isn't too costly.
We are on earth to help others; what on earth the others are here for I donít know.
Dudelsack is offline
Old 01-14-14, 09:27 AM
CommuteCommando
CommuteCommando's Avatar
Bikes: KHS Alite 500, Trek 7.2 FX , Masi Partenza, Masi Fixed Special, Masi Cran Criterium
Quoted: 15 Post(s)
All things being equal, exercise should lower BP. If yours is going up, something else is probably going on. Look at your diet, and have your cholesterol checked. High cholesterol doesn't necessarily cause BP to go up, but it can.
I have a wrist cuff BP monitor that I took to a doctors visit to calibrate against theirs, and it's pretty accurate. Doc's told me to get one (and to bring it in to check calibration) due to my history of heart disease. BP is not a problem for me but cholesterol is, so I keep an eye on BP to make sure it stays low.
Mine was under $100
http://www.heartratemonitorsusa.com/...FdRufgodNA8ALg
CommuteCommando is offline
Old 01-14-14, 10:20 AM
bruce19
bruce19's Avatar
Quoted: 837 Post(s)
Mine was under $100
I just got one via Amazon and have been using it for the past two days. I don't know if/how pulse rate is connected but mine is pretty consistently between 54-60 bpm.
bruce19 is offline
Old 01-14-14, 10:25 AM
bruce19
bruce19's Avatar
Quoted: 837 Post(s)
Just did a quick search and apparently there is "no good correlation" between BP and pulse.
bruce19 is offline
Old 01-14-14, 02:33 PM
tigat
tigat's Avatar
Bikes: 2018 Trek Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 41 Post(s)
After an adult lifetime of being 90-100 over 60-70, a routine work screening last Feb. brought me in at 145 over 110. The same or higher numbers repeated over the next few weeks, even though lipids and blood sugars were all their usual low selves and I was five lbs lighter and in better shape than I had been for years. Freaked me out. Why, all of the sudden, with only positive lifestyle changes to factor in?
A month and a half later, with no change other than no longer adding salt to cooked food, I was back down to 100-110 over 65-75, which has stayed my new normal. Thank goodness. My plan b, based on literature and doctor input, was to throw out the alcohol.
tigat is offline
Old 01-14-14, 03:40 PM
Shamrock
Quoted: 11 Post(s)
My bp is always higher on the electronic - digital monitor .I always ask for the manual and it is lower.
Shamrock is offline
Old 01-14-14, 04:13 PM
wthensler
wthensler's Avatar
Bikes: 2012 Giant Defy 0, 2012 Trek Domane 6.2 P1, 2018 Spec Roubaix Expert (coming soon)
Quoted: 98 Post(s)
I've never had a physician tell me not to exercise as part of a health routine, but i do respect that some folks may have limitations. As I am now in my mid-late 50s, I am more health conscious and do monitor my BP at home. After a good hard ride, I shower, relax a bit and stick on the cuff. It'll drop to 110 / 70 which leads me to believe that cardio workouts are having a beneficial effect. High salt and excess alcohol? Forget about it ( at least for me).
wthensler is offline
Old 01-14-14, 04:38 PM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6838 Post(s)
Liked 217 Times in 180 Posts
so .. not a tar ball tour of the Gulf coast..
fietsbob is offline
Old 01-14-14, 06:55 PM
Terex
Terex's Avatar
Quoted: 20 Post(s)
Sorry, you're just a little dehydrated. As soon as your fluids get topped off, it will revert to your normal BP.
Terex is offline
Old 01-15-14, 01:51 AM
stapfam
Time for a change.
stapfam's Avatar
Never worried about BP or Heart rate Till I had a routine check at the docs. Resting HR was around 70 so not too bad but BP was 165/80 and I queried it. Nurse said it was fine and within limits but I asked the doc about it when I saw her. She was not unduly worried but in view of the cycling and gym work I was doing- I was. Around that time there was a thread running on BP and most were around 120/70 so I felt that this was a bit too high. She agreed so put on Ramipril to bring BP down and it is now around 135-140/70 and although not good- it is lower than it was so better mentally for me.
Don't feel any better now I am on the meds so did I have a problem in the first place?
Spike Milligan
stapfam is offline
Old 01-15-14, 02:39 AM
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 44 Post(s)
I'm still a punk at 48 but am already a curmudgeon (if you ask my wife).
When I first went to my doctor's new office and met his new nurse, she took my blood pressure and pulse and thought there was something wrong with me... my doctor had the same reaction when we met more than a decade ago as my numbers were nearly the same then save for a lower resting pulse.
My resting pulse was in the mid 50's and BP was it's usual 110/70... my doctor explained the whole cycling thing to her.
My wife's BP usually runs a little higher because of the medications she has to take although they are still within safe limits.
Sixty Fiver is offline
Old 01-15-14, 06:38 AM
bruce19
bruce19's Avatar
Quoted: 837 Post(s)
This morning I used my new BP wrist device on my right wrist and got 149/101. So, I immediately took it again on the left wrist and got 130/85. ??? FWIW I too feel great. I'm 12 lbs. down from what I was in July (only 3 lbs. over what I weighed at the end of Basic in 1969) and rode my rollers yesterday and felt better than ever.
bruce19 is offline
Old 01-15-14, 07:37 AM
NOS88
NOS88's Avatar
I agree with those who indicate that your should get it checked. My PCP always reminds me that worrying about BP can, in and of itself, raise it.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
NOS88 is offline
Old 01-15-14, 07:51 AM
bruce19
bruce19's Avatar
Quoted: 837 Post(s)
Searching for a new PCP today.
bruce19 is offline
Old 01-15-14, 08:02 AM
NVanHiker
NVanHiker's Avatar
Bikes: 2008 Giant FCR2, 1992 Raleigh hybrid, my son's old mountain bike
Quoted: 12 Post(s)
OK, I give up - what's a PCP? (Wasn't that a '60's drug?) Is that what we call a GP (General Practitioner) in canada?
NVanHiker is offline
Old 01-15-14, 08:07 AM
NOS88
NOS88's Avatar
Primary care physician. It's kind of amazing how quickly we fall into using terms like this, and then assume everyone else knows what it is.
NOS88 is offline
Old 01-15-14, 09:03 AM
OldsCOOL
OldsCOOL's Avatar
Quoted: 414 Post(s)
Liked 7 Times in 7 Posts
Thank you. I was beginning to have flashbacks.
OldsCOOL is offline
Old 01-15-14, 04:39 PM
Bikey Mikey
Bikey Mikey's Avatar
Bikes: Diamondback Edgewood LX; Giant Defy 1
Doc took my BP this AM, well PA took it, and it was 104/60.
Bikey Mikey is offline
Old 01-15-14, 08:05 PM
qcpmsame
Semper Fi
qcpmsame's Avatar
Bikes: '80 Medici Pro Strada, '86 Tommasini Prestige, '12 CAAD 10 Ultegra
Quoted: 985 Post(s)
Liked 16 Times in 14 Posts
Bruce, I think the new physician is a good idea, the numbers you posted are kind of high, not real bad but high. I've managed to get off the BP meds as of last month, thankfully. I am usually around 120/70 +/- a bit on both, depending on the time of day.
Those are good numbers, Mikey, seems the trainer sessions are keeping you in good standing so far.
Bill
I Didn't Choose To Have Parkinson's Disease, I Have Chosen Not To Allow It To Define How I Live
Life Member "Hairy Eared Engineer's Society"
"I Can Do All Things Through Christ, Whom Strengthens Me" Philippians 4:13
qcpmsame is offline
Old 01-15-14, 08:08 PM
Duane Behrens
Duane Behrens's Avatar
Bikes: Specialized Tarmac (carbon), Specialized Roubaix (carbon, wifey), Raleigh Super Course (my favorite), and 2 Centurion project bikes.
Huh? What does a bastardized label have to do with blood pressure?
Duane Behrens is offline
