Campagnolo 10 Speed index down tube shifter conversion
Old 11-29-14, 09:22 AM
Michael Angelo
Michael Angelo's Avatar
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 63 Post(s)
How to Convert Campagnolo 10 speed bar shifters to Down tube. Some of these pictures are from the net some are mine, the result is the same.
Start with some 10 speed index bar ends. Remove them from the pods save everything except the pods and shifter post. Removing the rubber covers will expose very nice Campagnolo Shifters. Very similar looking to 8 speed down tube shifters. The 10 speed have better internal G- springs.
The only item you need are some shifter stops from most any C-Record area DT shifter. NOte, the stop have to be at the mid way point of the square. Earlier stops like NR/SR will not work they are too small and have the stop in the wrong position. I used the ones on the right.
Put the new shifter stop plate on.
Then the same brass washer and both small thin washers from the bar end shifter
Then slide on the bar end shifter.
Use the same screw plate from the bar end shifter, some of you may not want to use the rubber "O" ring I didn't.
Install the screw plate assy.
Installed, right side.
Same for the left side, stop plate and then everything that came off the left bar end.
My install on the CIOCC, works great. No missed gears, shifts perfect.
Michael Angelo is offline
Old 11-29-14, 09:44 AM
repechage
Quoted: 936 Post(s)
Liked 13 Times in 11 Posts
Thank you, pretty straightforward. The cost is the backing plates from a C Record earlier index shifter set... Besides the 10 speed bar end shifters, I guess one could take the other parts and create a lower count bar end shifter set?
repechage is offline
Old 11-29-14, 11:00 AM
Michael Angelo
Quoted: 63 Post(s)
Stop plates from any C-Record era shift lever will work. You could put 8-9 speed index rings in the levers too.
Old 11-29-14, 12:30 PM
John E
feros ferio
John E's Avatar
Quoted: 699 Post(s)
Liked 21 Times in 21 Posts
Pretty slick -- thanks for posting.
John E is offline
Old 11-29-14, 06:57 PM
photogravity
Hopelessly addicted...
photogravity's Avatar
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Yep, slicker than deer guts on a doorknob.
photogravity is offline
Old 11-29-14, 07:01 PM
embankmentlb
embankmentlb's Avatar
Bikes: Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 19 Post(s)
Very cool hack!!
Is that extra knob some sort of micro-adjuster?
embankmentlb is offline
Old 11-29-14, 07:16 PM
Ex Pres
Ex Pres's Avatar
Quoted: 345 Post(s)
Liked 7 Times in 6 Posts
Originally Posted by embankmentlb View Post
Very cool hack!!
Yes
I kept my set from my ill-conceived [for me] TT rig. Now I know how to put them to good use.
Ex Pres is offline
Old 12-04-14, 06:28 PM
Michael Angelo
Quoted: 63 Post(s)
You can also use this open style of stop plate. Just make sure the stop is at the midway point of the square.
Old 08-15-15, 06:34 AM
Michael Angelo
Quoted: 63 Post(s)
Bumping old thread.
Old 08-15-15, 07:14 AM
rootboy
rootboy's Avatar
Quoted: 493 Post(s)
Liked 5 Times in 5 Posts
Missed this thread first time around. Yes, great fix, MA. I only have one other comment. In those pics, your finger nails are too clean, man! How do you do that?
rootboy is offline
Old 08-15-15, 08:47 AM
Michael Angelo
Quoted: 63 Post(s)
i have finger nail brushes at work and at home. Being an Automotive technician for more than 40 years, getting your hands clean becomes an art form.
Old 06-17-19, 10:08 AM
brooklyn6640
Campagnolo bar end shifter to DT
Hi , many thank,s for the pics. I have 1 question n the pic # 4 the brass washer have 2 diferent faces , witch one go to the frame ? many thank,s.
brooklyn6640 is offline
Old 06-17-19, 05:55 PM
RobbieTunes
Half drunk? Finish!
RobbieTunes's Avatar
Quoted: 346 Post(s)
Liked 60 Times in 50 Posts
My conversion went well and works grandly. Opens up a whole new search for Campy brake levers.
Just remember, it's not just 10-sp. It will shift that interval all the way around the shifter boss. If I just had, say a 140 rear, I could get a bunch of 10-sp spacers and cogs, and maybe have a 2x15, downtube shifting, perfectly working..... Ha.
I think it's been asked before, but can the innards from those 10-sp shifters go into the Synchros?
Robbie ♪♫♪...☻
I have unfinished business.
RobbieTunes is offline
Old 06-17-19, 09:02 PM
styggno1
Steel is real
styggno1's Avatar
Bikes: A lot - accumulated over +30 years
Quoted: 198 Post(s)
Liked 10 Times in 5 Posts
Most of the stuff get answered here:
https://www.bikeforums.net/classic-v...retro-fun.html
styggno1 is offline
Old 06-20-19, 12:30 PM
Michael Angelo
Quoted: 63 Post(s)
later 8-9-10 speed DT shifters are not Synchro.
Old 06-20-19, 02:39 PM
styggno1
Steel is real
styggno1's Avatar
Quoted: 198 Post(s)
No, they are not, but/and as I wrote in the post I linked to above the insert fits into the syncro shifters - they just do not index strong enough to work properly. You will need the three spring shifters a la 8 speed Veloce or 9/10 speed bar end shifters for the conversion. Or do the 10 speed syncro hybrid sollution I did - if you want a 10 speed index with a friction option.
styggno1 is offline
Old 06-21-19, 12:15 PM
mrjav
Girardenghista
mrjav's Avatar
Bikes: Tommasini SL, Ciöcc SL, Somec MS, Rossin Ghibli, many many more
Quoted: 31 Post(s)
Hi all,
I have modeled and 3D printed the spacers to fill empty Ergo levers for a do-it-yourself (and not spend $250 on eBay) Campagnolo brake-only levers. I modeled them after a set I pulled out of what was marketed as TT brake levers back in that day. They're not the cheapest part (the store is not mine, but from a buddy, and the printer charges for the amount of material used), BUT they're still WAY cheaper than those original levers are going for. I'll do a separate post with the store link once the modifications are made and ready!
I'm currently running this 10v downtube shifter on 3 bikes. They all shift great. Braking is with Delta's. Two with these modded Ergo's and one with the vintage Record levers for Deltas.
mrjav is offline
Old 06-21-19, 01:28 PM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
So I guess the answer to my question as to whether they'll fit is uh...No.
Bummer. I was envisioning another couple of 10-sp setups....using my Synchro shells.
Robbie ♪♫♪...☻
Old 06-21-19, 01:31 PM
RobbieTunes
Half drunk? Finish!
Quoted: 346 Post(s)
Originally Posted by mrjav View Post
Hi all,
Very cool. Reading your post, thought the spacing was off.
When I read it again, I understood it. Great tip. I'll keep that info in mind.
Robbie ♪♫♪...☻
concernicus
Singlespeed & Fixed Gear
1
03-02-06 08:28 PM
swaco
Road Cycling
1
12-30-04 11:51 PM
slone130
Introductions
0
11-25-04 01:59 PM
MoshB
BMX
0
03-20-02 12:43 PM
