How close is too close?
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
Having several low end Raleighs, I'm familiar with the mystery threading in the eyelets in the rear dropouts. I know a 5mm screw will go in there, but not exactly tighten up very well. Most of my bikes have rear racks, and I usually insert a 5mm Allen head, button head screw from inside the dropout, and then use a nut outside the rack leg. I'm trying this on the Super Course I'm currently working on, and using a 6 speed Shimano freewheel. There's a point when -- passing from the smallest rear cog to the second smallest -- the chain only has about a 1/16" clearance from the button head of the screw. Is that enough? Is a miss as good as a mile? How much minimum clearance do I need?
Quoted: 1608 Post(s)
Liked 2,216 Times
If it works, it works. If it doesn't , it doesn't. I would try it out. If it becomes a problem, use a short screw from the outside and lock tight it.
Quoted: 834 Post(s)
Liked 2,126 Times
In this case, a miss is a miss in my book. I have a couple bikes where the chain in the high gear barely clears the inside of the dropout. I know it's not quite the same situation, but there's negligible flex between the cogs, chain, and dropout--unlike clearance at the rim or bottom bracket, where frame/wheel flex can turn a miss into contact. The only slight concern I might have is if you get a stiff link that impacts the nut. Perhaps file a bit off the nut. Alternatively, you could drill out the eyelet and tap it to 6mm.
Quoted: 50 Post(s)
Liked 18 Times
I'm probably going to try riding it like this, and I guess time will tell. Just wondered if anyone had any specific reason not to trust the close tolerance.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
I've had the same type of issue on some bikes. On a tour I noticed that every once in awhile the chain would hit the head of a screw that attached the fender to the dropout. When the outer link just lined up wrong, it would hit. Solution was to swap out the screw for a button head. Maybe 100 microns of clearance in the worst case, but it never hits now.
How much clearance do you need? Just enough.
Likes For gugie:
Likes For tricky:
Quoted: 887 Post(s)
Liked 335 Times
You and I are at least at the right distance.
