New member single speed question
Hey folks, just made an account and have a couple of questions. I've been riding a Redline Monocog 29er for years. Love it and in fact I've had a few over the years and always come back to them. Anyway, recently discovered that I have easy access to loads of dirt\gravel roads in North Texas so I've been out exploring those on the Monocog. I've had Origin8 Space Bars on it for a few years and really like them but I've always wanted to try it out with some drop bars. Looking at loads of monstercross builds has pushed me to the point of wanting to go ahead and give it a go. I'm thinking of getting some Salsa Cowchippers in 44 or 46m ( I have fairly wide shoulders) and fitting them with Sram 500 brake levers. I'm running rim brakes with Kool Stop pads. Would these parts work well with what I've got? Is there something that I'm not thinking of that might cause an issue or am I overthinking and just need to buy the parts and get after it? Thanks for any insight or advice. Take it easy.
Quoted: 2952 Post(s)
Liked 3,106 Times
There may be an issue with whether the brake levers pull enough cable for the brakes you currently have. Are they cantilevers?
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times
If you are running cantis or road caliper brakes the S500 lever will work great and if you add in some high quality cables and housing you will have great braking. Those are my preferred levers for single speeds or situations where my shifting is not at the lever and it is not a vintage bike with original 7400 brake levers. I cannot speak to the bars as I like a bar with a flat top section and a lot of these gravelly bars don't have that but I have heard good things about them.
I remember a housemate of mine had a Monocog and it was a fun ride.
Thanks all. The brakes are the standard mountain rim brakes that the bike came with. I've just swapped out the pads. This is the biggest question I've had is whether or not the drop bar brake levers will be compatible with the brakes I have on the bike. I'm not 100% opposed to using mechanical disc brakes (BB7s are something I've used in the past) but I'm liking the simplicity and frugality of using what I've got currently . I may try this in the "Bicycle Mechanics" forum as was suggested, or........I may go CRAZY and just continue to ride the piss out of my current setup. Thanks folks.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
If V-brakes (fairly likely) then get Cane Creek Drop V levers. There may be other long pull drop bar levers too.
If cantilevers, there are plenty of options in short pull road levers.
Likes For LesterOfPuppets:
