Anyone Still Remember Araya Rims & Suzue Hubs?
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
What do you guys think of them? Vintage single walled 27x1.25 goodness. I have since overhauled the rear hub, changed out the rear tire and replaced the front rim with a 700x38 setup.
I've found the rear rim to be extremely strong. I can ride as hard as i want (at 220lb) without worrying about anything more than some mild bending.
I've been thinking of polishing up the rim/hub and spokes with steel wool or something. Opinions?
Quoted: 2323 Post(s)
Liked 4,988 Times
I've had Araya rims before and they seemed fine.
Using steel wool on the spokes and such is normal practice for me on any bike I've recently picked up. I like bringing the shine back. I also use Mother's aluminum polish a lot of hubs and sometimes the rim. It just get's to be a lot of work on a rim if doing it by hand. Can restore a grey, powderly looking rim to a mirror shine thought with some effort.
Steel is real...and comfy.
Quoted: 1372 Post(s)
Liked 1,751 Times
I have a lovely set of those wheels, fitted with new tires and a Regina freewheel, They came fitted to an early sixties Torpado Professional. Great wheels even though I have no bike to use them on. Anyway...
Alloy and steel wool are not a thing to mix, in my opinion. A plastic scrub pad, soap and hot water works well on alloy rims. As for dirty spokes, be they stainless steel or just galvanized, can be best cleaned by rubbing with a piece of crumpled up aluminum foil - give it a try on oxidized chrome plating also. Results always amaze me...
Quoted: 981 Post(s)
Liked 1,844 Times
Yes, don't rub aluminum with steel wool, as steel is harder than most alloys and will scratch it easily. As a rule, always use a material for scrubbing that will give way faster than the object that is being scrubbed! It takes longer, but it greatly reduces the risk of damage.
-Gregory
-Gregory
Quoted: 1142 Post(s)
Liked 1,739 Times
I've been using auto wheel cleaner on wheel crud, it's not a degreaser but it does clean cranks and brakes that are encrusted rather quickly. One thing though, the cleaner can harm the tire branding, so one could be careful around the labels.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I've never had a problem with using medium or fine steel wool on ANODIZED aluminum surfaces, the steel wool seems not to affect typical satin anodized finishes at all.
I prefer not to use steel wool on galvanized spokes though, since it will effortlessly strip off whatever protective zinc that remains, and this zinc is what keeps the electrons flowing in the non-rusting direction in damp conditions. I vote for the nylon scrubbie pad on galvanized spokes.
Also, on rusted fasteners and other cheap hardware, soaking in oxalic acid or even vinegar can strip off some of the non-chrome platings faster than the rust will come off, so if you see any bubbles, then assume that's the plating foaming off.
I used some prolonged rubbing using steel wool to remove the logo from this Kalloy-made stem, and it left absolutely no evidence of abrasion on the presumably anodized finish:
Sandpaper and ScotchBrite pads are another story, because their abrasive media is much harder than any steel wool. Scotchbrite will strip anodizing with enough rubbing.
One more warning, steel wool rubbed over a dirty surface will take on whatever abrasive dirt/dust is present, so can really scratch up chrome in a hurry, yet I often use steel wool on clean chromed surfaces without any such damage.
Likes For dddd:
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
Drip, Drip.
Liked 193 Times
I'm loving my rear Araya rim. I've heard that suzue hubs are super durable.
I rehauled mine while replacing the bent axle recently. Smooth as butter.
Quoted: 874 Post(s)
Liked 2,287 Times
Araya made quite a few wheels back in the seventies through the eighties and I’ve never had a problem with them . I’ve never run Suzue hubs but I’ve had Sunshine hubs that are very similar. Like any of those cone bearing type hubs , maintenance is key to longevity and performance. Be careful not to over tighten the cones , always check them after loading them with skewer tension on the frame. Most of my bikes have stainless steel spokes so I just wipe them with the same polish I use on the wheels and hubs, Mothers Polish .
Quoted: 637 Post(s)
Liked 1,281 Times
Totally off the original topic, but I spent a few minutes scrubbing one of those Kalloy stems with steel wool today, and was surprised by the result. The stem had a really cheesy chrome finish, and I thought I’d just take some shine out of it. Instead, the chrome came right off and I found a tan primer. Seems like a good candidate for some black rattle canning. Anybody come across this before?
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Not totally unrelated but Suzue are still making hubs. I have a nice chrome set of disc hubs laced to Pacenti rims which look sharp.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Drip, Drip.
Liked 193 Times
My suzue hub seems to be a little bit loose. At first it was perfect. Then it became pretty loose. Tightened the cones. There is now a tiny little bit of play but it doesn't seem to be getting worse this time around.
any suggestions?
any suggestions?
Liked 1,295 Times
Sounds like a very slight bearing cone adjustment is in order, just be sure that there is at least some play in the axle before flipping the quick-release lever or the resulting axle compression will leave your bearing over-tight and binding roughly (as felt through the bars with the wheel off the ground and turning).
It is usually impossible to detect a rear wheel bearing's roughness due to the ratchet turning unless the chain is held free of the sprocket while the wheel is turned.
Drip, Drip.
Liked 193 Times
Always better a little loose than tight!
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
Yeah, that’s where I’m headed. If it was a home job, it was really pro. Weird that someone would go through all that trouble for a cheap stem. Of course, here I am going through the trouble to remove it!
Likes For JacobLee:
Liked 1,295 Times
I rotate pitted cone surfaces against the corner of a flexible "unitized" or "de-burring" wheel (essentially a grinding wheel made from compressed Scotchbrite).
This smooths pitted cones enough to improve my ability to achieve a serviceable adjustment, though perhaps good enough for only a few thousand miles before requiring additional attention. I make the cone turn opposite the wheel's turning direction and flip the cone on it's axis once during this procedure to let the abrasive attack the edges of surface defects in both directions.
Usually when i see that issue the Axle is bent. I usually will strip the axle bare and roll it on something nice and flat to see if there is movement . a slight bend can be hard to see but will cause the binding like you are describing.
Drip, Drip.
Liked 193 Times
I've managed to accidentally bend my current axle a bit , but its not too bad. Im a little hesitant to replace the axle again.
Someone suggested to me to try using a chromoly axle. Other than stretching the frame apart and using a wheel with a cassette, not many other options.
Liked 1,295 Times
I've switched to a 10mm solid axle with nuts to replace a hollow quick-release axle or 3/8" (9.5mm) solid axle. Much harder to bend these(!), even my WalMart MTB holds up to hard riding using a 7s freewheel since I replaced the 3/8" solid axle with a 10mm solid CrMo axle and cones.
Drip, Drip.
Liked 193 Times
The freewheel design tends to place quite a lot of stress onto the axles and bearings, due to its design.
Might be a silly question, but how common is a cassette with a solid axle? Im going to search up how the inside of a cassette hub looks like.
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
I still use a 1970 old school Array 27" rim on the rear wheel of the UO-8, and it has held up well over the years. These were pretty heavy for aluminum rims, and one had to be careful with the spoking pattern, because the spoke holes were forward-back and left-right bias-drilled, so only one spoke lacing pattern made sense. Unfortunately, on many of them, the valve hole came up between two same-direction holes, i.e., between left and right side spokes that run parallel instead of diverging apart.
