First Tool Kit Question
What is a good way to get a first bicycle tool kit. I know absolutely zero about bike mechanics but I've become addicted to riding and want to learn. Instead of purchasing individual tools would something like this park tool kit be a good way to go?
Thanks
OB
https://cgi.ebay.com/NEW-PARK-TOOL-AK...#ht_3449wt_911
Thanks
OB
A lot of the basics you can buy for a lot less money than Park charges. With the basics, like allen key sets and metric wrenches and socket set, out of the way you can buy the Park or Zefal tools that you need rather than a kit that will have some stuff that you may never use. For example if you never need to do a threaded headset you won't need the big flat wrenches that are needed for them. And if you just buy as you need then you can build up the kit slowly and with some added focus.
A few things that you SHOULD get right away would be;
For a fairly new bike with threadless headset and a square taper style BB setup this is about all you need to work on the bike besides the more normal handtools that most home shops would have anyway such as assorted screw drivers, pliers, cutters, etc. If you don't have ANY of that stuff you'd need to expand a bit on the list above to fill in the missing links.
- All three sizes of spoke wrench. Get the nice plastic dipped ones.
- The flat cone nut wrenches used for cup and cone wheel bearings.
- A BB tool to suit your bike(s). Although this can be put off until you need it.
- Crank arm remover. Again it can be put off until needed.
- Thin pedal wrench.
- Tire irons of course.
- and the basics, metric allen key set, metric wrench set from 8mm to 19mm. And a 1/4 and 3/8 combo ratchet set isn't a bad idea as well.
Quoted: 5791 Post(s)
Liked 2,581 Times
Rule number one. Acquire skill before you acquire tools. Rule number two buy only those tools you know how to use, and suitable for jobs you'll actually do.
One of the best ways to waste money is to spend it on tools you can't or won't use. That's as true of bike tools as it is for overly powerful computers, or any other gadgets that get little use between the point of purchase and the scrap pile.
Start small, learn to fix flats, adjust gears and brakes, repair or replace a chain. That'll be 90% of what you need to know to enjoy cycling for years, and can be done with $5-20.00 worth of tools, some of which you might already own. Then you can expand your knowledge and buy more tools as your interest, time available, and budget dictate.
FB
Chain-L site
FB
Chain-L site
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Packaged tool kit = Bad move.
Do a search, it has been discussed many times. Acquire only the tools you need, when you need them. Some tools (chain tool, cable tool) need to be good ones. Other tools, pretty much any brand is good enough. I have a $6 pedal wrench for example, but a $50 Shimano cable tool. You don't have to go that good on the cable tool, unless you plan to work on quite a few bikes (I work on bikes every week).
Overpriced. I picked up one of these not 2 weeks ago as my first tool kit:
https://www.nashbar.com/bikes/Product...2_10000_200501
