Go Back  Bike Forums > Bike Forums > Fitting Your Bike
Will a short stem ruin bike handling?
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 11-20-13, 09:49 PM
1938 Autocycle
Arrow Will a short stem ruin bike handling?
I picked up a full Durace Lemond TSX that is a 58cm from a friend for a great price. I have fallen in love with the ride quality of this bike. The problem is I am only 5'10" and fit really well on a 55cm bike with 90mm stem and the Lemond is way to big for me. Can I just put a really short stem on the Lemond or will it adversely effect the handling / ride quality? I have been looking high and low for a TSX Lemond in my size but they are always out of my price range.
Thanks for any help
1938 Autocycle is offline
Old 11-20-13, 10:12 PM
bikeme
Quoted: 136 Post(s)
Liked 57 Times in 31 Posts
Thanks for any help
It'll just slow down your steering a bit/make it less twitchy. I did that to my mtb, what is "really short"? What size frame?
bikeme is offline
Old 11-20-13, 10:29 PM
1938 Autocycle
The frame is a 58cm and I like to ride a 55/56cm with a 90mm stem so I will need the shortest stem I can find. Will probably try a 60mm stem (hopefully that will be short enough)
Old 11-20-13, 11:15 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
SR made 40mm stems. My '91 Bianchi Eros came to me with one, and I was able to ride the bike just fine.
You might consider switching to handlebars with less reach and drop while you work on your flexibility.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 11-21-13, 01:40 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
handling , how? fast slalom , criteriums, or JRA and touring .. what is your goal?
what is the top tube length? size does not say much about length.. short on details..
fietsbob is offline
Old 11-21-13, 08:06 AM
1938 Autocycle
Just using the bike for genral riding no racing etc. I just don't know much about road bike setups and wanted to ask some questions before I started making changes.
Thr top tube is 57.5cm per the Lemond catalog and I prefer a 55cm top tube with a 90mm stem so it looks like I can run a 70mm stem and get this bike to fit. Other then a tall stand over hight that is not a big problem for me.
Old 11-21-13, 10:08 AM
fietsbob
Bikes: 8
what actually effects the way the bike steers , the trail dimension, on the ground, does not change,
head tube angle + fork rake/offset..
I only note, [ '75, I built an oversquare bike frame) .. 60tt, 58st, was the front end felt lighter
due to the wheel being a bit further from the C of G, a bit ..
It now has a big front porteur basket, resolving 'too light' , carrying stuff..
fietsbob is offline
Old 11-21-13, 01:10 PM
ThermionicScott
LeMonds are known for having an extra-long top tube -- being stretched out was the plan.
RUSA #7498
Old 11-21-13, 10:19 PM
1938 Autocycle
Good call. I don't know why I did not think more about the bars. The bar on the bike have a long reach and deal drops. Soma highway one bars will be the ticket
https://shop.boxdogbikes.com/products...-short-shallow
Getting really pumped to get this bike to fit me so I can put some miles on it
Old 11-21-13, 10:23 PM
zonatandem
zonatandem's Avatar
Quoted: 77 Post(s)
Liked 19 Times in 11 Posts
Is the frame too big?
Would wear shoes that are too big???
zonatandem is offline
Old 11-21-13, 10:37 PM
1938 Autocycle
If the shoes felt as nice going down the road as a frame made from TSX tubing does I might.
I normally would just find a bike that fits but all the high end TSX bikes are out of my price range and I think this bike is going to work out fine with the bars and stem changed
Old 11-22-13, 10:29 PM
bikeme
Quoted: 136 Post(s)
BTW, Dimension makes inexpensive stems in both quill and threadless for 26mm and 31.8 bars in either silver or black. I saw ones from 60mm to 120mm, maybe longer. 60mm could be more than short enough for you.
bikeme is offline
Old 11-22-13, 10:31 PM
bikeme
Quoted: 136 Post(s)
I just got a Soma Highway One--I love it. I think it might be the same as Easton's--dims are match exactly.
bikeme is offline
Old 11-23-13, 11:33 AM
fietsbob
Bikes: 8
and good thing the OP never mentioned the top tube length measurement, to make that clear..
Yea a lot of handlebar benders , began making a short ramp drop bar
since Brifters, to get all the Mech inside, are so Long.
fietsbob is offline
Old 11-23-13, 01:22 PM
Dang
Dang's Avatar
I own a 86 centourion myself. Naturally it's a tad to big for me also so I did switch out the stem with a shorter one.. Didn't notice any difference in the ride but it felt kinda awkward at first. I like it.
Dang is offline
Old 11-25-13, 01:34 PM
bikebreak
Quoted: 129 Post(s)
It's not too big for you. I ride with a fellow who is 5'9 on a 58.
Tilt your pelvis and stretch out. Read this thread https://www.bikeforums.net/showthread...tion-Discovery
look at the picture in this post https://www.bikeforums.net/showthread...1#post14804011
Also, the higher head tube on the bigger bike will also bring the bars closer to you. For example, I ride a 54 with a 9cm stem and a 55 with a 10cm stem. Huh? The bigger bike is taller in front, so I can use a longer stem since the bars are higher.
bikebreak is offline
Old 11-26-13, 10:56 PM
1938 Autocycle
Great thread, just read it start to end. Interesting timing as I just slammed the stem on my Felt Z4 last weekend and found that my neck and shoulder problems I had been having disappeared.
As you suspected when I dropped the bars played with the seat positioning and got stretched out the Lemond more less fits me. I will more then likely change out the bars for some Soma highway 1 bars and roll it.
Thanks to all for the input and help
Old 11-28-13, 12:56 PM
Road Fan
Road Fan's Avatar
Quoted: 1853 Post(s)
Liked 659 Times in 502 Posts
Ok for the 70 mm, but can you get a handlebar with 1 cm less reach? If so, you only need an 80 mm stem, which is a lot easier to find.
Road Fan is offline
Old 11-28-13, 02:38 PM
1938 Autocycle
Ya that is what I have decided on. I am planning on the soma highway one compact bars and ether a 80mm hiden bolt Dura Ace stem or an 80mm Deda Elementi / Tre Murex Road Quill
https://m.ebay.com/itm/370858226558
Leaning towards the Dura Ace because it would match the rest of the parts on the bike but they much harder to find and the convenience of the removable bar clamp on Deda Elementi is hard to pass up.
Unfortnatly I need to sell my other steel bike to fund the bar and stem purchase.
Old 12-29-13, 11:14 PM
BikeFitPro
Bikes: We love all bikes
Stem length does not change how a bike handles. However it may change how you handle the bike.
If you are better fit you will handle the bike better. So many people get caught up on stem length so beware it is not the big deal many think it is.
I like the handle bar suggestion as well. Go short and shallow and shorter stem if you really want to make this work.
Cheers
BikeFitPro is offline
Old 01-02-14, 12:33 AM
Crescent Cycle
I've ridden on 60-80mm stems, but I kept reading about people who said handling was compromised for stems under 100mm. I'm not sure what that is supposed to mean since reach to the hoods can vary quite a bit, and reach from the tops to the hood varies as well. I never found the 60mm stem uncontrollable on the flats though, but the bike might have been stable due to slack HTA.
Also I thought Lemonds were supposed to have normal fronts, just slacker STAs. They were also sized C-C so the top tube appeared longer for any given size.
Crescent Cycle is offline
Old 02-05-14, 08:07 AM
a77impala
a77impala
a77impala's Avatar
Bikes: 04=LeMond Arravee, 08 LeMond Versailles, 92 Trek 970
Quoted: 28 Post(s)
Liked 13 Times in 8 Posts
I have a Lemons Zurich 57cm, I usually ride 53cm, I put a threadless adapter with a shorter stem, I didn't measure it, I also replaced the setback seat post with a regular one. It handles perfectly!
I have bikes from 53 to 57cm and as long as they measure 20 inches from the tip of the seat to the center of the bar I am a happy rider.
a77impala is offline
Old 02-05-14, 10:02 AM
FrenchFit
The Left Coast, USA
FrenchFit's Avatar
Bikes: Bulls, Bianchi, Koga, Trek, Miyata
Quoted: 361 Post(s)
Liked 25 Times in 18 Posts
I think that's right, unless you legs are unusually long make the adjustment at both ends; keep your center of gravity from going too far to the rear. Most of us probably ride with too much weight on the rear wheels as is.
FrenchFit is offline
BlackTie
Road Cycling
318
11-09-14 04:58 PM
2702
Road Cycling
18
05-05-14 09:02 PM
jyl
Classic & Vintage
28
12-30-12 09:35 PM
Dan The Man
Road Cycling
4
05-29-10 10:33 AM
echappist
Road Cycling
6
05-04-10 10:04 PM
