Trek "investment-cast" lugs from the '80s/'90s...strong and trouble free?
Bikes: '02 Litespeed, '99 Bianchi Alfana. '91 Fuji Saratoga, '84 Peugeot Canyon Express, '82 Moto GR, '81 Fuji America, '81 Fuji Royale; '78 Bridgestone Diamond Touring, '76 Fuji America, plus many more!
Quoted: 181 Post(s)
Liked 224 Times
Has anybody had long-term experience with older Trek frames that used investment-cast lugs? I was looking at the seat cluster on one, specifically where the seat stays come into it. Looks beautiful, but will this thing hold up over the long haul?
Quoted: 659 Post(s)
Liked 595 Times
I have never heard of a problem as long as they were under normal and expected use. I have loved, appreciated and used the Treks with IC frames for 12 seasons.
Can you share more about your bike in question?
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
If you figure Trek started using that style of lug socket things on most bikes in 1985... if there were any sort of trend of them failing- you'd see it after 30 years. Unlike the Ishiwata cast fork crowns on Trek's 600 series bikes from the early/mid 80s. Those definitely did have problems.
The most I've heard about the investment cast pieces is that there are those who feel that it takes "craftsmanship" out of the building process. *shrug*
Commence to jigglin’ huh?!?!
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
They hold up just fine. Where they were used on the seat cluster, I think they look rather nice in an 80's sort of way. That's always a location where builders have to do something to make it all come together.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
I left Trek in 1986, when the lugs had been in use for a couple years (they were phased in starting with the high-end models, and the version used on the model 360 pictured above was slightly different than the ones used on the high end models), but I was Trek's Warranty Inspector at that time and don't recall any particular problems.
SP
OC, OR
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
That is a functional improvement. It makes your bike cost less.
Genesis 49:16-17
Genesis 49:16-17
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
It makes your bike cost less TO MANUFACTURE...FIFY
So Trek is "positioned to leverage" those increased profits to acquire stuff...like say Bontrager, Klein and Gary Fisher.
THAT's "investment casting" of a sort...
Disco Infiltrator
Liked 2,105 Times
Hoho yes ok very droll. Prices do go up, but not as fast as they should from inflation and exchange rates, because there's competition between companies.
Trek doesn't always make a killing, either. I was just reading a thing about how their 1990's tandems went on clearance a few months after they went on sale, and stayed there for years until they ran out of frames.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 4236 Post(s)
Liked 2,949 Times
Well, it makes it cost less for Trek to produce it. For you at the store, maybe not.
Edit:Tried to post but then my internet cut out for half an hour, came back and found someone had beat me too it.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Quoted: 1608 Post(s)
Liked 2,216 Times
The seat stay attachment of brazing to the seat lug on the sides was always a curiosity to me. I is the only place where the "tube" attachment has a shear loading. This design, like all "fast back" configurations, put the seat stay in compression at the joint. Makes a lot more sense to me, from a structural integrity perspective.
Also, you are less likely to pop a seat stay when trying to remove a bonded seat post by using the frame as a lever. So you might be able to apply more torque before you pull out the hack saw!
Old fart
Liked 3,401 Times
The irony is that Trek invested in the tooling to make all these pieces just as steel frames were passing out of fashion, so I don't know if the labor savings ever amounted to enough to recoup the cost of the tooling.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Trek advertised that these lugs strengthened and stiffened the frame. I think that they were very reliable, and the cost-savings that they offered lent itself particularly well to very large-scale production.
Perhaps there was some weight penalty? They certainly have some things in common with other styles of cast tube end fitments, but would seem to further cut down on the number of brazing operations per frame.
I still come across quite a few Trek MTB's with the cast seat cluster, typically with a QR lever clamping the seat post.
And am I the only one that has found that cast seat clusters on a road bike seem to require a bit of extra torque on the pinch bolt to secure the post?
Old fart
Liked 3,401 Times
I've been using mine since I bought it in '87, no problems with the frame at all.
Marc
Marc
Lakerat
Classic & Vintage
5
10-11-17 10:42 AM
tsegu
0
08-19-10 03:18 PM
