Ideas for Gravel Grinder Bikes
after doing my first gravel grinder, notice many of the gravel bikes were old beaters almost, racks and everything
so suggestions of a good gravel grinder, thinking of doing more gravel races, and do it properly
i have an old hard tail MTB with 26 rims on it, could i use that
or would a 700cc be better
Suggestions of agood gravel bike? would finding an old roadie be ok or is the BB to close to ground?
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
a hardtail mountain bike with fast-rolling tires is a great place to start. suspension is probably unnecessary, so an old bike fitted with an appropriate rigid fork might be better. a 29" tire or large volume 700c tire-bike might be even better. any cyclocross bike would work great. A hybrid with semi-knobby tires would work too. an older road bike with fat tires might work, but you need to be sure that the frame and fork can accommodate tires with enough girth for your terrain. I have seen tires marketed as "gravel" tires that only have a width of 28mm, but I found that even 32mm tires were too narrow for my taste on gravel roads in central Texas. I rode 42mm Continentals for the second two races I did and it was better, but I think Conti under-sizes their tires, so 42mm Conti's are more like 38mm.
there are "gravel bikes" that are being made specificially for this kind of riding but they will cost a bit more than fixing up an old mtb- Surly Straggler, GT Grade/ Corsa, Salsa Warbird, Specialized AWOL/ Diverge, Trek Cross Rip, Pake C'mute, Soma Double Cross disc, etc. these bikes are often marketed as "all-road" bikes, because they are designed to handle all kinds of roads. they usually have a wide gear range, room for 35mm+ tires, relaxed geometry, etc.
29" and 700c are tire sizes that fit on the same rim, actually. a really narrow 700c tire might not fit on a wide rim intended for 29" tires, and a fat 29" tire might not fit on a narrow road rim, but the actual diameter of the rims is the same. 700c is a tire size. 700cc is cubic centimeters, which has nothing to do with bicycles.
Quoted: 5888 Post(s)
Liked 3,471 Times
Rigid mtbs are cheap and plentiful. They won't be as "fast" as a purpose built gravel grinder but they can take a plenty fat tire and can be rigged with drops if need be. Makes a good commuter later if you decide to invest in a purpose built gravel bike later.
It's pretty tough finding one of the bridgestone xo series bikes (nearly impossible to find an XO-1) but some of the XO bikes make very good gravel bikes since they are road bikes that take a pretty fat 26 inch tire. I built my Bridgestone XO-2 to be a gravel grinder.
n00b
Quoted: 428 Post(s)
Liked 466 Times
fitting a drop bar on a bike that was not designed to be ridden with a drop bar is much easier said than done. a lot of careful planning would be involved.
Bikes: Cannondale Slate 105 and T2 tandem, 2008 Scott Addict R4, Raleigh SC drop bar tandem
Quoted: 22 Post(s)
I have an early 90's GT Timberline with 700c wheels and drop bars. I put a steel SOMA cyclocross fork on it and a Cane Creek 40 headseat and it is awesome on the gravel. With that frame, I can go crazy wide on the tires but am currently running 32's and they are fine until the gravel gets deep.
Liked 3,471 Times
Old. Slow. Happy.
Quoted: 5 Post(s)
I, personally, prefer low BBs. Even on my road bike, which sees plenty of dirt and gravel, have I rarely smacked a pedal/crank on something. If it's rocky enough to be concerned about pedal strikes, I'm probably going to bork my wheels/tires first.
Quoted: 22 Post(s)
^ The drop bar conversion on an older, threaded MTB does not have to be a struggle. It did cost a few bucks though but does not have to break the budget...some people just clamp a drop bar into the existing stem.
Replace the headset with 1 1/8 threadless, I did this myself with home made tools. Buy whatever drop bars you want. I bought a set of used Salsa Cowbell 2 cross bars. Get a 700c fork and install (or you can decide to keep the 26's). Then, you can decide what stem length you need. I used an 80mm stem with a rise that suits me perfectly. I bought new 8 speed STI's on ebay for under $20 each. The only trick I needed for the 700c conversion on a GT was a front Nashbar long reach caliper that I mounted backwards and inside the rear triangle (after flipping the brake pads around).
Spend some time on the Mountain bike drop bar forum for inspiration. I have posted my GT there.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
It would be a shame if we all got so anal-retentive about this sport that we turned it into yet another "approved bikes only" event.
Liked 2,568 Times
Old. Slow. Happy.
Quoted: 5 Post(s)
Gravel grinding is all about finding what works best, and challenging yourself to build skills riding on rough terrain. Despite what the bike companies would have you think, it's not about buying their very specific "gravel" bike, so you shouldn't be surprised to find a wide variety of stuff on these rides.
From what I've seen gravel bikes seems to be a matter of personal preference and intended use. Multi-day racing will require a different bike setup that an afternoon at touring speeds. If you are going bike shopping a cyclocross or light touring frame would be better choice than a road bike since the cantilever brakes will allow you to run tires in the 30-38C range.
Liked 3,471 Times
Liked 3,471 Times
Liked 2,568 Times
Some food for thought.
Quoted: 75 Post(s)
I've got a 1993 Trek 700 that is my all around bike and it has served me well on a lot of mixed surfaces. This summer I did a gravel grinder that took me through some sandy areas and minimum maintenance roads rutted with washouts that left me wanting more than the 40mm x 700c tires. Enter my old 820 frameset now equipped with 2.1 Schwalbe Smart Sams. Now with a little research, I should be able to decide which bike for a given event.
Liked 3,471 Times
This is my 1993 Bridgestone XO-2. The combination of road geometry and 26 inch wheels (I'm running 26 x 1.5 tires on it but it can take up to a 1.9 tire) is, I think, a pretty smart design. It's a great all around bike and I find myself riding it more and more as we move into fall in IA. It's comfortable and deals well with all the leaves that are starting to accumulate on the MUPs I regularly ride on:
Liked 3,471 Times
All my MTBs are vintage with super laid back geometry. That's what's nice on the XO series. They have 26" wheels and road bike geometry.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
My 1994 Trek 750 multitrack has been a lot of fun on gravel these past few weeks. It was a hybrid basically with mtb geometry and 700c wheels. I put 38s on, moustache bars and bar ends and that has been the extent of my "building up." I posted some pics on the MTB drop bar conversion thread over on C&V but they're not very good closeups of the bike, mainly just scenery.
I'm not sure how far I would be comfortable riding it -- I've done a couple 40-ish mile rides and it was fine but it's a little slow so I think a century or more would become unpleasant. It's got a 42 tooth big ring and I may increase that at some point but it's pretty low on my priority list.
Point is I think pretty much any non-department store rigid steel MTB is a great choice for gravel. I didn't think the handlebar conversion was that tough and I'm not a very good mechanic.
I bought the nashbar steel cross bike because I wanted something a little faster for a looong gravel ride & a weeklong tour I'm planning next year, but I haven't had much chance to test it out yet because of lightning this week and work.
Quoted: 55 Post(s)
Liked 32 Times
I used to ride my 1995 Trek 730 quite a bit on gravel roads back in the 90's. This was with the stock "38mm" tires that were for all practical purposes, slicks and nowhere near 38mm in width. They have reasonable top-tube lengths (my 53.5cm bike has a 57cm ETT) and would be great for a drop bar conversion for gravel grinding.
If you are patient and not in a one of those communities where used bike prices are thru the roof, you can pick up an old Multitrack for not much more than $100 or so.
Bikes: 1970s Peugeot UO-8, 1980 Peugeot PXN10E "Super Competition", 1985-86? Miyata 610, 2012 Trek 3500 Mtn Bike, late 1800s project build/bike (will it ever get finished?..your guess is as good as mine! HA!),etc...
Noctilux.95
20
07-17-18 09:41 AM
bikemig
20
05-02-18 05:53 PM
